A binary solution ?!...
path_finder
re: A binary solution ?!...
Post by path_finder »
Dear jacob alex,
you wrote:a)-long arm into a short arm,in the bottom point
b)-short arm into a long arm in the top point
That's the Botafumeiro principle:
http://www.sciences.univ-nantes.fr/phys ... meiro.html
On a pure physical point of view this is named 'the parametric pendulum'.
murilo
Post by murilo »
Botafumeiro is a clever old device!
Would be great if the eccentric auxiliary wheel set could send elongation exactly at straight point.
This 'coincidence' is what makes botafum not linear and with strange reaction.
path_finder
Dear jacob alex,
'short/long' arms are equivalent to 'mobile fulcrum along the seesaw rod'.
You have just to keep the weights equal, and install the fulcrum on a pin rotating around an axle.
iacob alex
Post by iacob alex »
Cher P_F !
Try to simplify the things...
You say:"...a mobile fulcrum along the seesaw rod..."
I say:use the very old/"classic" design of the Middle Ages (a hinged end/0*-180*)...including MT13
So,we have so easy the bottom "self",due to gravity hanging.
Remains to solve/imagine/test the second (top) self:a quick jump,"supplied" by gravity impetus/momentum "via" rotational inertia.
The "puzzle" of a possible PM device,for the moment, moves in a single (top) point:imagine a "self" (short arm must "jump" as a long arm).
All the best! / Alex
cloud camper
Post by cloud camper »
Sounds good Iacob - just design so anything going down counterbalanced by something going up. Vertical com of the overall system must never change. Overbalancing without commutation gives you a balanced wheel or keeling followed by balance.
We can think of this like a battery. As long as the poles (+,-) are separated, we have PE. Shorting our poles together is like our wheel keeling followed by balance.
Commutating our wheel is just like keeping our battery poles separated (binary system).
Keep in mind when we have binary separation, we are dealing with four separate PE fields; vertical lift, vertical descent, rotational lift, rotational descent. All we do is build inertia in one field then trap it in another with a "quick jump".
iacob alex
Hi P_F !
You said: "...short/long arms are equivalent to mobile fulcrum along the see-saw rod."
I say:
-we have two fixed bearings(one for the lever,one for the variable arm)
-we can play Milkovic's arrangement ,if we replace his swinging pendulum,with a rotating variable counterweighted pendulum ("leveraged" pendulum ).
So ,we can play as "swinging sticks" or as a "modified" Milkovic...
The basic idea is the same:variable leverage...
All the best ! / Alex
cloud camper
This is great Iacob, I’m glad you’re still thinking about commutation and variable leverage. If we watch enough WOD clips we can figure this out!
OK so looking at MT138, we can get a big hint. We need to keep something big parallel to something else. He shows if we do that we can get four power impulses for every turn of the wheel. How can we organize the weight paths so that we can bypass the law of levers and at the same time never change the vertical com of the system?
What simple systems can we use from side to side that will provide us with different torque values at the hub? How can we use variable leverage to build inertia in the descent system and then trap it before the system keels?
How can we transfer the weights from the lifting mechanism to the descent mechanism smoothly so a weight is always attached to one side or the other but never both at once?
Why is a binary system necessary? What does having a binary system actually mean for us?
Why does commutation of the weights result in a binary system?
What simple mechanisms might a clockmaker use to commutate and latch the weights to the short and long arms?
iacob alex
Hi Cloud!
You are focusing about MT138...
My application was related to MT13 (see "MT13 digest..." topic).
As I said many times,if we play the lever concept the "PM problem" is minimized:we need two length commutations,only.
The first one(the bottom position) is solved (Middle Ages designs...).
The second one (for the top position) needs to be solved,in some manner...
iacob alex
.....for statics,you can see and think about it, at:
http://www.youtube.com/watch_popup?v=jJ ... &vq=medium
It's a nice performance in gravity and inertia:fulcrum (stabile,mobile...as Alexander Calder"s dynamic sculptures and a serial of levers)
Why not use the binary/lever concept for dynamics? (more precisely,for our topic)
iacob alex
....for an "unclear" magneto-mechanical rotation,you can find at:
http://www.youtube.com/watch?v=-ibSwX8m ... ure=relmfu
Maybe,big shots are only little shots who keep shooting...
iacob alex
.....can be a persuading reason to start your self-evident test.
You can simplify the up-here youtube game :we keep the "bumping" magnet (stator),but we can play with a single rotating magnet (rotor).
We must arrange the variable leverage:
-the "hinged magnet" will play on-off (short arm-long arm).
-the "bumping magnet" will play for the top position,to commute short arm into a long one.
iacob alex
.....this time,'...designed for infinite fluid motion" by Kirk Hunter ,at:
www.youtube.com/watch?v=iGRDD6rX_cQ
This superb kinetic sculpture uses the binary/lever concept for dynamics .
All the Best! / Alex
broslad
Post by broslad »
Do you think the prime movers operated around the axle were they would have the least affect on the balance of the wheel and the reason the wheels were so big is because the shifter weights had to be as far away from them to have the most affect.
iacob alex
Hi !
The "'prime" (and only!) mover is the permanent motion of the air: all kind of these works of art are called "kinetic sculptures".
The artistic impression is the leagage/foliage of a tree and the small,unseen motion of the air :there are no hidden spare parts("movers") !
So,we have a natural model with a tinyl "input",with an impressive "output",transfigured by a skilled artist.
If you type on internet this label , you can find a lot of them.
broslad,
The factors of a mass being further from the centre of rotation:
Increased inertia (takes more energy to speed and slow the wheel)
Increased CF (Related to inertia)
Increased energy for given rotational speed
If you shift a weight vertically 10cm, it will give the same rotational energy to the wheel, regardless of its location and radius on the wheel.
