Heron's Fountain problem solved!
veproject1
Post by veproject1 »
During 20 Centuries Heron's Fountain was unable to work perpetually. The problem is fixed now...
https://www.youtube.com/watch?v=Sv9Jrnn ... ozapl6nMCw
re: Heron's Fountain problem solved!
Are you sure?
Part of the pressure is balancing out through the down tube between the lower tanks as well. The question is did it get a longer run time or did it shorten it. The video is inconclusive and consider the source that has shown many fakes.
murilo
Post by murilo »
I don't believe veproject1 is a clown!
So important as the tube in below is the tube called 'D'.
Guessing: why not one single vase, since those two are unified at top and down?
alfilmx
Post by alfilmx »
I do not understand why, if you are good builders would not it be easier one replication to a question?
congratulations, veproject1
AB, note the similarity between the "source" and our friend: veproject1 & veproject1. He is just pointing you to his latest perpetual replication video. They are all fakes. He states that none of his builds are fakes, but he doesn't mention that although they are true builds, he hides the power source.
Understand why herons fountain works. Then you will see the impossibility of what is shown here.
LOL but I do understand. I just pointed it out why it won't, due to the statement solved. The fluids will equal out up to the point it stops and it will still show to be equal in the lower tanks. But I do like his builds despite being fakes.
Agreed. I dont see the point in this latest vid, with its attached claim. It seems to go against "visual education".
murilo
Re: re: Heron's Fountain problem solved!
Post by murilo »
murilo wrote:I don't believe veproject1 is a clown!
After some view, I guess that this device will stop due to internal atmosphere problems...
Not sure, maybe if it gets a cyclic 'breath'...
