try to appreciate...
murilo
re: try to appreciate...
Post by murilo »
Look at this!
http://www.keppemotor.com/pt/kmventiladores.php
Sorry if my electricity skills are so bad...
They have translations to several languages.
Opinions?
TC!
Art
Post by Art »
Sounds great all the things you can do with a motor that is 90 % efficient .
One would think all you would have to do is take out the patents , build a fridge that will run off a solar panel or a 9 Volt battery , and I'll be one of their first customers .
You get the feeling there is another agenda in there somewhere !
Not sure I trust schemes that mix philosophy with electricity - could upset the karma of the aether : )
murilo
Post by murilo »
At least, as I saw, they don't used high torque application.
Hard to understand if current motors may have 95% gain of effective power and NOW they say to economize 90% over 'normal' 95% gain.
From inside my ignorance, I thought a lot about the 'form of waves' they look to apply to a DC motor but couldn't reach to nothing.
murilo
Post by murilo »
You are free to protest, but:
http://www.space.com/22271-sun-magnetic ... _264643204
In case of a possible non-agreement, as ever, sure you're able to complain!
TC!
M
getterdone
Post by getterdone »
Sunny side up
getterdone
I think we need more people like this young man
http://www.torontosun.com/2013/09/10/te ... the-oceans
getterdone
The Hamster wheel
Watch through the first closing credits!
http://vimeo.com/25845008
murilo
Post by murilo »
Great you both, guys! 8)
murilo
Post by murilo »
Found this of interest:
http://www.scientificamerican.com/artic ... R_20130920
So much to do with it, besides expend in light technicalities!
murilo
Post by murilo »
This is not for share!
This link is here sent just for my exclusive use:
http://ocw.mit.edu/courses/mechanical-e ... /index.htm
You and all others are not allowed to learn on this treasure, OK?
Grrrrrr! 8(
M
murilo
Post by murilo »
No adjectives to send:
http://www.chonday.com/Videos/the-write ... _276027825#!
I would expend 4 incarnations to build this!
Woooosh...
murilo
Post by murilo »
Aaaaand now... with you... as ever... our sleepless competitorssssss!!!!!
http://greentechnologiesworld.blogspot. ... nique.html#!
This is a patent APPLICATION filed in 2010. This is not an issued patent. This basic concept has been around for a long time. I'm very sure it will not work. And I'm very sure the USPTO will never issue a patent on this.
The reason why these type of devices do not work is because energy is required to insert the float objects into the bottom of the column of fluid. And the fluid pressure at the bottom of the column always equals the force produced by the rising floating object.
See this link for basically the same invention, except simpler. (simpler is always better when it comes to patents)
http://my.voyager.net/~jrrandall/McCoinPatent.html
murilo
Post by murilo »
The draw you sent, as you know, is a classic dream, where the liquid works frontally against bodies insertion.
The link I sent has some variations, ALSO tried by some - me included.
The 'sink' tube for 'falling' weights is occupied by a rising flux of micro blobs, thanks a compressor and/or lower density 'fine powder'. (this has been a theory for the ships that sunk on Bermuda's triangle.)
The experience I did used aquarium compressor and AT LEAST the RETURN of the water was a reality, besides small volume.
The compressor was hard to control and I tried some chicanes.
As ever the quality of my building was very poor... I still think that better model should be done.
