Bill wrote:Jim_Mich wrote:So explain why the hammer-mill calculation matches the hundred-weight lifting calculations...
Easy. Following your example of selectively manipulating Bessler's scale drawing, all I need to do is assume the size of these components was drawn wrong by whatever factor I might make up :D
From AP, published by Bessler in October 1719:
I state this since I once -
1. Attached a cord or rope to the wheel’s axle, and led it over two pulleys out of the window. With the aid of this arrangement I was able to raise a chest full of stones, weighing approximately a hundredweight, as high as the height of the building itself would permit. (page 22)
2. Attached some planks of hard solid wood, average cross section (shaped like the outline of the prismatic solids) five inches, and length 7 feet, to the device; these were then moved and raised by arms attached to the axle by means of a type of cradle similar to those found in fullers’ –or paper-mills.
3. Used the motive power in the spinning peritrochium to drive an Archimedes Screw standing in a large reservoir of water, thereby raising the water and creating a veritable cascade.
The hammers-mill stampers of the Kassel wheel were 5 inch square by 7 feet long, according to Bessler's own words. This makes each hammer stamper volume to be 1.215 Cu.Ft. European red oak weighs about 46.8 lb/Cu.Ft. This makes each hammer weigh about 56.875 lbs.
The hammer stampers are drawn to scale when compared to the 12 foot wheel. By scaling the drawing the hammers were lifted about 11 inches. Two such hammers are shown. Each hammer stamper was lifted twice per wheel rotation. Thus the total lift each rotation = 11 inches × 2 lifts × 2 hammers = 44 inches = 3.666 Feet of lifting per wheel rotation.
3.666 feet × 26 RPM = 95.3333 feet of hammer lifting per minute.
95.3333 ÷ 60 = 1.58888 feet of hammer lifting per second.
HP = weight_lbs × lift_speed_per_second ÷ 550
HP = 56.875 × 1.58888 ÷ 550
HP = 0.1643
Converted to Watt = 122.5 Watts.
No fudging was done. The only estimate was the lift height each stroke and the assumption of which type of wood was used. The stamper size was straight from Bessler's own documents.
So, don't anyone dare claim I am manipulating the scale to suit my pet theory. Just don't ever say that again. I'm getting really fed up with such accusations.
So once again I ask you to explain why the hammer-mill calculation matches the hundred-weight lifting calculations, but then the water screw calculations are off by a factor of about 4 or 5 from the other two calculation.
My answer, which you ridicule and reject, is that the water screw or the pulleys were not drawn to scale. My answer is that the water screw was about twice the size shown, -or- the driving pulleys were not the size shown, thus causing the water screw to rotate about 4 or 5 time faster. Also, water screws and primitive vee-belt pulleys are terribly inefficient and produce a lot of friction.
Edit: Friction of a water screw and primitive belt and pulley could easily consume many Watts of energy. Remember that energy was originally figured out by using paddles stirring water. A water screw is one BIG paddle doing a lot of STIRRING.
