Why only four pounds?
Furcurequs
Re: re: Why only four pounds?
Post by Furcurequs »
ovyyus wrote:Dwayne, you might like to read the below topic, if you haven't done so already. I'd be interested to hear you views on the matter.
http://besslerwheel.com/forum/viewtopic.php?t=4925
Hey Bill,
I read through the thread again and may have a few things to add to it later. I also finally found an equation that relates to the air resistance, bearing resistance and power loss of a flywheel. I've often wondered how much power was required to just keep the large wheels turning.
It's been quite some time since I've done any fluid dynamics, though, and so I'm not too comfortable just plugging numbers into equations. I'm not even sure yet which system of units this one uses. It was in some "Vehicle Power Management" book I found on Google books (via a post on some physics forum).
I normally don't like using equations that I haven't derived myself or that I've not at least seen derived, and so that I fully know what's going on with them, of course.
I think the equation assumes laminar flow, which may not be the case for something of the size we are dealing with or the materials the wheels were constructed from. Hopefully, I'll be able to review this stuff and then try my hand at eventually deriving the equations myself to check things.
I may at least plug some numbers into the equation I found to perhaps get a feel for things, though.
Dwayne
I prefer working alone.
Post by John Collins »
Fair comment Bill, he might have found it difficult to stop the wheel where a younger fitter man (such as myself!) would have stopped it more easily.
Perhaps, if the wheel was so heavy that Bessler had to remove some or all of the weights prior to translocation, there would be a considerable flywheel effect apparent in the rotating wheel which would make it difficult for anyone to stop it easily.
John, I may have confused Joseph Emanuel Fischer von Erlach with Johann Bernhard Fischer von Erlach?
Joseph was born in 1693 and died in 1742 at the age of 48. In 1721 he would have been 28 years old.
edit: fixed typo
rasselasss
Post by rasselasss »
The Kassel Wheel was inspected and visited by many emminent educated people,and yet measurement values whether disallowed by Bessler are lacking,the Archimede's screw placement angle,pitch,( helix) the diameter of the screw housing even the pulley ratio,to drive JimMich worked from the so called "scaled"sketch which was admirable but nonetheless "assumptions"..eg.where is the axle bearing housing,is it a plain bush as per sketch view,through the support pillars ,yet we are informed it was an open bearing (uncapped)... as it is claimed the wheel was lifted on occasions to exhibit no hidden devices...as per the sketch it would have proved difficult without some dismantling of the support pillars.(what was height of the pillars to ceiling because if fixed to the ceiling it would present more difficulties )... i find it strange that so little "relative"info.was collated by these emminent people,displacement calculations of the "screw"without "sound"measurements is really of little value apart from a rough estimate....J.M.O.
I can tell you that in the case of the Kassel wheel the pillars were bolted to the ceiling.
William Kendrick (1725 -1779) a keen supporter of Bessler, visited Kassel some years after Bessler's death and visited the machine room and observed the remains of the bolt holes in the ceiling to which the pillars were attached.
I should have known anyway Bill, I got confused often enough when researching the matter!
Furcurequs
jim_mich wrote:
Bill wrote: He was 65 years old at the time. He died 2 years later in 1723. Perhaps something to consider in relation to his difficulty handling the big Kassel wheel?
Is this an example of a typical younger persons warped perspective towards older people?
Bessler was age 65 when he died. Same age as Fischer when he inspected Bessler's wheel. Do you suppose Bessler was also weak? After all Bessler died at age 65. But wait. Bessler was building windmills at age 65. So a 65 year old man need not be weak. But then Bessler dropped dead, literally. My point is that age 65 does not imply a person is frail and weak. So I don't think anyone needs to consider Fischer's age in relation to his difficulty handling the big Kassel wheel. Only an ill-informed young person would suggest such a thought. Enough said.
Its obvious we will never know the weight of Bessler's Kassel wheel. But from all indications, its upper upper weight limit might be about 1000 lbs. Numerous times the weight of just the wheel has been estimated. John Collins in PM-AAMS estimated the empty wheel at about 500 lbs. John estimated 192 lbs of weight. You can read how he arrived at his figures on page 173 of PM-AAMS. John assumed weights 2-1/2 inches, which fit inside a 15 inches of interior space of the wheel, making the total wheel about 700 lbs.
But suppose the weights were about 4 inch OD by 3/4 inch thick, thus still weighing about 4 lbs. This would allow 20 weight-disks within the 15 inches, which would increase the weight of the weights to about 640 lbs. Then add the weight of the wheel itself and the total assembled working wheel might tip the scale somewhere around 1140 lbs.
What I take from all this is exactly what Bessler wrote, "the empty wheel was so heavy that it could hardly be lifted to its new bearings. With the weights it would have needed the Devil to lift it."
Bessler's empty wheel was probably somewhere between 350 to 500 lbs. This would make it difficult but not impossible to move to its new bearings.
I would put the upper limit for the total weight of the assembled 12 ft "difficult to stop" wheel, to be somewhere around 900 to 1200 lbs. Such would be the line where Bessler's wheel crossed into the impossible to stop realm. If any heavier then the wheel would be become impossible for Fisher or Bessler or Bessler's assistant to stop it.
http://singaporeseen.stomp.com.sg/singa ... 336769.jpg
...anyway...
Having too massive a wheel may not be consistent with other accounts we have about it, though. Remember, according to descriptions by Fischer and 's Gravesande, the wheel would accelerate from a near standstill to its full rotational speed within just two or three rotations - when, of course, it was given a good enough initial push to get it started from a full stop.
If we were to assume some sort of intrinsic motion and/or gravity powered device, it might also then be somewhat safe to assume a limited amount of available energy PER REVOLUTION to accelerate the wheel up to speed. If that limited amount of energy per revolution was approximately equivalent to that which we can determine from the calculated power output in the load tests, then we can perhaps determine an upper limit to the wheel's moment of inertia, too, which would give us an idea as to the amount of mass for a given mass distribution in the wheel.
As an example I'll just grab the figures of 106 watts at 20 RPM for the Kassel wheel from here:
http://www.besslerwheel.com/wiki/index. ... eel_Output
I chose the 20 RPM figure to work with because that just happens to give us a whole number of 3 seconds per revolution.
106 watts times 3 seconds gives us 318 Joules per revolution which is 318 Joules * 0.7376 foot* pounds / Joule or about 235 foot * pounds per revolution.
If we use the above assumptions, then, 2 to 3 times 235 foot-pounds would approximately equal the energy stored in the wheel's rotation at 26 RPM.
So, if we go with three revolutions, we have 3 * 235 foot-pounds or 705 foot - pounds of energy to get our wheel up to speed.
Where 1/2 * I * w^2 is our rotational kinetic energy and w (I'm using that for omega - the rate of rotation in radians/sec) is 2 * pi * 26 rot/min * 1 min / 60 secs or 2.72 radians / sec,
The moment of inertia of our wheel will be I = 705 * 2 / 2.72^2 or 190 slugs * ft^2
If we divide this by our wheel radius squared we get 190 slugs - ft^2 / 36 ft^2 or 5.28 slugs, which is 5.28 slugs * 32.17 lbs / slug or 170 pounds mass.
That would mean that if our wheel had ALL its mass at the rim, it would weigh about 170 pounds. If the wheel were more like a solid disk, however, with the mass distributed equally throughout, for it to have the same moment of inertia it would weigh 340 pounds.
With our 235 foot-pounds of energy per revolution, that's like having 235 foot-pounds / (12 ft * pi) or 6.23 pounds of force applied at the rim throughout a revolution.
So, we can use that force and the equivalent mass at the rim for our calculated moment of inertia to determine the time it takes for the wheel to spin up to speed.
F = m * a, 6.23 pounds = 5.28 slugs * a, a = 1.18 ft / sec^2
V = a * t, 16.3 ft / sec = 1.18 ft / sec^2 * t , t = 13.8 seconds
So, the wheel would take a total of about 13.8 seconds to do it's first three turns.
If it could get up to speed in two turns, of course, it would have a smaller moment of inertia and might be considerably lighter, like I = 126 slugs - ft^2 and 113 lbm if all the mass were at the rim and 226 lbm if distributed throughout a disk. ...and it would take about 9.2 seconds to do the first two turns.
Now, if one could think of a mechanism that provided more energy per revolution at start up and so at slow speeds than under normal operating conditions, one might consider a more massive wheel. ...or, of course, if the energy source was time dependent rather than rotation dependent, like one might have with a hidden chemical combustion fuel source, then the moment of inertia of the wheel could also be greater.
...and just some more things to think about.
Dwayne
Dunesbury
Post by Dunesbury »
Good logic.
Would strength of man matter if he were stopping wheel with weight only?
Frail and weak make no difference as long as arms could support weight.
Imagine grabbing 12 foot wheel going 26 rpm, about 1 rev per 2 second. Rim going about 16 feet per second. From six feet overhead to feet in 1 second.
Now grab through hole in canvas and stop. If grabbed going up can't use strength much. Grab going down applying strength and walking across with it and applying only weight on way up, stop quicker.
Either way, my opinion is less massive estimate.
Dunes
sleepy
Post by sleepy »
If the wheel was twelve feet diameter,that would make the pillars six feet high.I have very little strength with my hands over my head.
In John Collin's book, PM-AAMS, he speculates a platform was used, and the men simply lifted the axle of the wheel by letting it rest on their shoulders. Farmers and tradesmen know that they can carry maximum weight when it rests on their shoulders. Thus no need to lift the weight of the wheel "over" your head.
Another thought is that some sort of overhead winch system may have been used. Just because such was never mentioned does not negate such a possibility.
Sorry Dwayne, but your logic is not logical.
You can't use the net wheel output to calculate gross wheel weight. All that you have done is calculate how heavy of a wheel the net wheel output could accelerate. The actual wheel gross output accelerated the full wheel weight-mass up to a speed of 26 RPM in about 3 turns. The output also accelerated and lifted the "hundred weight" (about 112 lb) load a distance of about 22 feet. That calculates out to 24 seconds to make the lift.
With some of the wheels it was stated that the load-lifting was done without slowing down. A heavy wheel would act like a flywheel and so not much slowing might be observed in the approximate 24 seconds (10.4 rotations) of lifting
Implying that the wheel had a rim mass of only 170 lbs or 113 lbs totally defies all known information about the wheel. Your math may be accurate, (I didn't check) but the logic behind your math is totally flawed.
A 1 inch thick rim, 12 foot diameter, 18 inches thick wheel, would contain 8086 cubic inches of wood. Assuming white oak (0.029 lb/cu/inch), the weight of the rim alone would be about 235 lbs. Then we must add the ribs/spokes of the wheel. And we must add the weight of the axle (though it would not add much to the momentum of the wheel). And we must add the weight of whatever mechanisms. And finally we must add the weight of the actual working weight-masses, be they 8 four lbs weights, or 192 four lbs weights.
Any which way you crunch the numbers for a real wood wheel with some real internal mechanisms, its mass comes in at 300 to 500 lbs, not counting the weights.
Dwayne, I mean no disrespect. But you need to look at the logic behind your calculations, rather than simply crunch numbers.
Dunesbury
Post by Dunesbury »
dwayne wrote: If the wheel were more like a solid disk, however, with the mass distributed equally throughout, for it to have the same moment of inertia it would weigh 340 pounds.
So let me get this straight, since if I'm wrong then I'm bashed unmercifully.
Bill wrote:John, I may have confused Joseph Emanuel Fischer von Erlach with Johann Bernhard Fischer von Erlach?
Joseph was born in 1693 and died in 1742 at the age of 48. In 1721 he would have been 38 years old.
My math must be failing me, because I figure he should have been age 28 in 1721, at the time he and Gravesande inspected Bessler's wheel. He died about 21 years later.
It seems that Bill's original mistaken reference implying a weak and elderly Fischer was in error when first he posted it and is still in error as to his Fischer's age at the time he, "stopped the wheel with much difficulty."
Dunesbury
Post by Dunesbury »
jim-mich wrote:Any which way you crunch the numbers for a real wood wheel with some real internal mechanisms, its mass comes in at 300 to 500 lbs, not counting the weights.
dwayne wrote:If the wheel were more like a solid disk, however, with the mass distributed equally throughout, for it to have the same moment of inertia it would weigh 340 pounds.
340 is good logical estimate in my opinion. 400 lbs with weights.
3 1/2 hours to relocate wheel is not good logic in my opinion.
jim-mich wrote:Removing and then replacing close to 200 weights is a much bigger job than say with 16 or 32 weights. If the time required to remove a single weight is about a 1/2 minute, and the same time was needed to replace the weight, then it would take about 3-1/2 hours to relocate the wheel.
jim-mich wrote: And finally we must add the weight of the actual working weight-masses, be they 8 four lbs weights, or 192 four lbs weights.
This would make mass to stop by single man 340 to 500 + 768 = 1108 -1268 lbs.
Big wheel only lifted 112 lbs from axle. If wheel had 1100 lb. mass, why only 112 lb? That isn't logical, jim-mich.
daanopperman
Post by daanopperman »
Hi all ,
If I had a CW over balanced wheel , with more weight on one side of a wheel , the mechanism would play itself over and over to relocate the weights , if I slowed this wheel down , the mechanism will slow down accordingly , and if I stopped the wheel , the mechanism would hold its place .
Now if I were to reverse this wheel , the mechanism would play against the reversed wheel , that means that the mechanism would still bring the weights into a over balanced state on the same side of the wheel as before . If I let go of the wheel it would start to turn CW .
How is it possible to contemplate a bidirectional wheel with a back to back overbalance mechanism if the CW mechanism keeps the weights in a overbalanced CW state . Not even a ratchet could give this freedom of movement .
I believe the unidirectional wheel was of the same weight as the bidirectional wheel , it was just the mechanism that wanted the broader wheel , the dia was just for for show , was it made in USA , JB would have put Gondulas on the rim .
