jim_mich wrote:Four mechanism. Eight bangs per rotation.
Sixteen of part #16 - weights
Thirty-two of part #17
Sixteen of part #18 - cross-bars
Sixteen of part #19 - support post
Sixteen of part #26 - cotter pins
Thirty-two of part #27 - standoffs
Sixteen of part #32 - nylon spacer
Forty-eight of part #33 - nylon spacer
Sixteen of part #39
Total of 208
Hi Jim-Mich,
That is a lot of pivot points you have there, so that is a lot of friction, that is one reason most builders do not use scissor jacks.
I wish you luck though, but I do not see it as a contender for a Bessler's wheel.
The main reason is the Conservation of Angular Motion (CoAM) experiments that prove it, are low friction experiments, the ice skater is low friction, the coat hanger and batteries experiment is low friction, both of which still need muscle energy inputs to prove them, the rest have well over the top energy inputs to prove it that they are not even valid at their power to weight ratios.
My hopes are, that while you are building your design you may find a good gravity assisted mechanism.
Forgive my negativity, but you still have not identified your proposed driving force that will move the weights in your design, to do so would go a long way to get people to understand your design. As it stands all we have is your interpretation of Bessler's words.
Good luck with this build Jim, I hope I am wrong, but I do not think so.
