Perpetual Motion is Impossible
Walt, thx for your invaluable thoughts. This thread started out as "PM is impossible", that entitles me to put in a quick word, which I did. Your proposition to do a drawing is welcome, it might make a refreshing change. End of matter, unless pursued in the manner in which you have initiated it, in which case can somebody tell me where the "ignore" list is please ? Have a great day, and a Happy New year.
Re: re: Perpetual Motion is Impossible
That' interesting. I didn't know that. Have you got a link.Kirk wrote:Your assertion is incorrect. For example, consider a pipe descending into the ocean with an osmotic membrane on the down end. Fresh water weighs less than salt, about 3%. If the column is long enough the weight of fresh water will be such that the pressure differential establishes flow across the membrane. You have a perpetual fresh water fountain. Takes a long pipe, admittedly, but it IS PERPETUAL
Presumably one could get the same effect with a centrifuge.
Mmm... Maybe that's a way to build Jim's wheel. :-)
Who dares to put in doubt the engine to perpetual movement ??
The Perpetuum Mobile is well and truly possible small and large, fast and slow, complicates and simple, white, black, blue and green. :)
It can be used to produce the mechanical energy and electrical, to propel of boats through the oceans or the trains on the rails, trucks and cars, mopeds and wheelchairs, and even the airplanes of tourism.
Aisle the guys, put you to reflect, the future is to you.
Qui ose mettre en doute le moteur à mouvement perpétuel ??
Le perpetuum mobile est bel et bien possible petit et grand, rapide et lents, complique et simple, blanc, noir, bleu et vert... :)
Il peut être utilisé pour produire l'énergie mécanique et électrique, pour propulser de bateaux a travers des océans ou des trains sur les rails, des camions et les voitures, des mobylettes et fauteuils roulants, et même les avions de tourisme.
Allée les gars, mettez vous à réfléchir, l'avenir est à vous.
Look at a compound bow for a spring type, where the spring tension does increase but is steady or constantnicbordeaux wrote:"If I use springs (not the clock type) to drive my wheel, instead of weights (using gravity) would it then be deemed perpetual motion?.
Yes.
no, no, no. wrong. wrong. wrong. Don't tell me how this thread started out. I started this thread.nicbordeaux wrote:Walt, thx for your invaluable thoughts. This thread started out as "PM is impossible", that entitles me to put in a quick word, which I did. Your proposition to do a drawing is welcome, it might make a refreshing change. End of matter, unless pursued in the manner in which you have initiated it, in which case can somebody tell me where the "ignore" list is please ? Have a great day, and a Happy New year.
entitled? Oh, Mighty God. I'm in the presence of an entitled one!
You certainly have your way of seeing things, yet you might take a step back and see things differently. Your call.
Once again, I'm going to attempt to refocus you ADD ones to the point. Now, I'm not going to rely on you to follow a link. I'm going to post the whole thing right here.
How in the world do you propose to make a thing that is never ending in a world that will?Thus, machines which extract energy from finite sources will not operate indefinitely, because they are driven by the energy stored in the source, which will eventually be exhausted. A common example is devices powered by ocean currents, whose energy is ultimately derived from the Sun, which itself will eventually burn out. Machines powered by more obscure sources have been proposed, but are subject to the same inescapable laws, and will eventually wind down.
Please. Do you think I'll believe anything you say?
Now, you had a request of me, nicbordeaux. I feel obliged to help you, caged one. Your question:
I found it. Yes it did. It's very close to your frontal lobe down under very close to your colon.
You're welcome.
This is an utterly silly and pointless question altogether. You are trying to define something yet to be invented according to knowledge which we do not have, eg what "time" and "eternity" mean, if such a thing as eternity does exist. In English, that would be splitting hairs so minute that one could only theorize their existence. In French, it is known as (translated and censured) "B...ing flies"
Bring on the builds, show us some mechanical action :-)
You are a liar. This isn't my definition. Infinity is a well defined concept in mathematics. I didn't do this.nicbordeaux wrote:You are trying to define something yet to be invented according to knowledge which we do not have, eg what "time" and "eternity" mean, if such a thing as eternity does exist. :-)
Don't accuse me of this concept. It never was my idea.
Would that it were, yet I'm not that smart.
Re: Perpetual Motion is Impossible
humm, need to read this . .. .. .
Re:
I want to caution the gentle reader of this thread, there are blatant expressions of mathematics contained herein.
Enter at eWe(R) own risk. You agree to hold the OP harmless.
Shocking, I say. Simply shocking.I always thought that a change in momentum (velocity) equals the energy.
INT(p) dv = INT(m * v) dv = 0.5 * m * v^2
