over unity explosions
Kirk
Post by Kirk »
Anomalous strength of plasma explosions
http://nebula.wsimg.com/6c330ccb6fd5ffd ... oworigin=1
John doe
re: over unity explosions
Post by John doe »
Exactly.
This has been around from 1992
https://www.youtube.com/watch?v=4zMpM-j ... VviQihzaQY
high voltage, high frequency conversion.
I expect you have seen this from the BBC equinox programme. It is near the end of this youtube video.
John doe
Post by John doe »
Wow
John doe
Post by John doe »
If there were parents involved would they still be valid? Wouldn't they go to the next of kin? Also wouldn't the information on the patents be available to the public from the patent office or through the freedom of information act. I realize I may be a bit naive concerning the operation of the government and its respective branches.
And here it is...
https://www.google.com/url?sa=t&source= ... yj_iKiCjTA
Art
Post by Art »
Before you spend too much time studying the details of the patent you need to listen to what Dr Greer says about the patent half way through the video below .
https://youtu.be/uidDHEaxxlE
Trevor Lyn Whatford
Post by Trevor Lyn Whatford »
Hi all,
this technology does not sound that much different than the hydrogen fuel cells, you can make a clean energy that will run a car and such, but the conversion from water requires a energy input to do so, Hydrogen fuel cells are only about 70% efficient. Note the hydrogen fuel cell was not suppressed.
Indeed this Idea requires a high energy input for its conversion. Also, energy inputs are the same problem for a lot of plasma Ideas that seem trendy at the moment.
It would be interesting to find out the energy efficiency of this topics device, but the company that has invested millions into this project is using the wrong physicists, as it says on the video, Personally I cannot believe that.
Andyb
Post by Andyb »
KIRK hi dude ,i myself nearly ended up retro fitting cars to run on water with meyer himself or rather through a francise,any how after years of blowing things up seeing no flame and suffering buzzing ears for a fair bit really, should have worn ear defenders ,i can say a few things here with confidence, there are many gases from water and some of them varying through out the day they are all hydrogen related but theres a monster in there i have seen it, it loves sub pressure on creation then it will implode and then expand this gas as meyer said was hydrogen but there was some thing he did not say and that was a element that he could not figure out as i understand ,this element i believe is duterium sorry about the spelling ,apparently when you split it the nucleus splits and it duplicates it self by being in the right inviroment ie protecting from external magnet fields and propagated in the right voltage this stuff is abundant and is why the joe cell worked as well ,ther was a guy a freind of mine was trying to find he was bought out by some group i forget his name now but he was running cars on a misting system in the inlet manifold coulped with a freqency in sub pressure and off it went ,bought out covered up same old crap ,very interesting gasses though ,once i blew the lid off of a beer keg it went through the workshop roof and came back down on the keg it had left 15 seconds later ,maybe some one could do the maths on that ,what got me and still does to this day is even detonation this stuff goes off as one very quickly the higher you charge it the quicker it burns easy enough to put a rocket in to higher atmosphere i recon, apparently its being done sorry about the way i have written this i know i could do better but i cant be bothered all the best Andyb
Andyb
Post by Andyb »
ME,nice post interesting experiments all the cells i have built except one were built from 3mm stainless the one i built from 1mm ripped itself open and took off three layers of skin in what i could only consider the center of a incident ,interestingly enough i have no scaring from this burn as browns gas replaces the oxygen robbed from the heat of the burn strange but true i am living proof ,i enjoyed the videos cheers for sharing .
Furcurequs
Post by Furcurequs »
I once used traditional electrolysis and captured some hydrogen in a plastic soft drink bottle. I also somehow managed to put balloons over the top of the bottle and squeezed the hydrogen into the balloons.
I think with the first try I accidentally got some water in my balloon, so it wouldn't float for me. I then, of course, decided I had to try to pop it near a flame and so ended up with the a balloon flying around my kitchen like an out of control rocket spewing fire like a blow torch.
On the second try I managed to keep enough water out of the balloon for it to actually be able to float to my ceiling. After awhile, though, it lost its lift.
I, of course, had to try to pop that balloon near a flame, also, but by that time it must have had a pretty good mixture of hydrogen and oxygen inside of it, and so it actually exploded like a bomb above my sink. Talk about flash/bang.
It was all pretty exciting for me, but...
...shhhh... ...please don't tell my landlord.
I prefer working alone.
Art
Post by Art »
Yes , there is something about explosions that makes a permaneant memory trace for later recall!
Not trying to outdo you guys or nuthin but { : ) } when I was a kid and fooling around with calcium carbide (which produces acetylene in contact with water) , I got the bright idea when in my private lab , (which was the outhouse where I stored my 'scientific ' equipment ) , that it would be a good idea to put some calcium carbide in some hydrogen peroxide and see what would happen ! .
I was sitting on the "john" with a glass testube half full of hydrogen peroxide , Pants around my ankles , when I popped a granule of the calcium carbide into the test tube , watched it bubble furiously, and then started to wonder if it was hydrogen that was being given off and whether it would light !
Afterwards I had wished that either I had not had a Bic lighter handy or that I had at least had my pants on , because that test tube just disintegrated in an an enormous bang which left my heart palpitating for about two minutes after I managed to get out of there with a minor injury that I felt I couldn't really explain to my parents who didn't know a lot of stuff about calcium carbide and hydrogen peroxide .
The good old days when you were allowed to take your life in your own hands ! : )
John doe
Post by John doe »
I am not amused.
Furcurequs
...lol
Thankfully, I can still take my life into my own hands and don't have answer to my parents anymore.
That thing about having one's pants on may be something I need to try to remember, though. I guess I've just been fortunate up to now. ...lol
Andyb
Post by Andyb »
Hi all just had to say this, if you seal a electrolysis sell and put a small voltage into it will keep building its pressure until it breaks the cell,my point is that this pressure is infinite from just a small voltage ,a little known fact, hope you find it interesting .
