The Shortest way there is the Longest way round
This saying is very old and I hope we can use this to assist in two active threads.
The question we have 'Where does the energy come from?'
https://en.wikipedia.org/wiki/File:Brachistochrone.gif
So a ball starts at the same height, mass and zero momentum.
Then end with same height mass & different momentum?
All this happens due to it's path.
Does that mean they have the same input energy and finish with
different output energy?
re: The Shortest way there is the Longest way round
I would like to see the same test on a rotating platform.
agor95 wrote:Then end with same height mass & different momentum?
Wrong.
This has been discussed a number of times here on the forum.
Two equal objects following different paths but which end up moving at a same horizontal height will have a same horizontal velocity.
The object simply arrive at different times. They take different amounts of time to fall because of their different path angles.
@Jim_Mich
I remember the post around 8 years ago on this topic.
Hopefully we have some new members & guests.
So it is good to keep members on the right track.
If you had not stated there was no difference in momentum then I would have done so.
So with hard geometry in a static frame of reference this is true.
Note. A question is never wrong.
@AB Good point.
Also the Rotating Frame needs to vary.
