Code: Select all
from visual import *
# pendulum
# The analysis is in terms of Lagrangian mechanics.
# The Lagrangian variables are angle of bar
# measured from the vertical.
scene.title = 'Pendulum'
scene.height = scene.width = 800
g = 9.8
M1 = 2.0
M2 = 1.0
d = 0.05 # thickness of each bar
gap = 2.*d # distance between two parts of upper, U-shaped assembly
L1 = 1.0 # physical length of upper assembly; distance between axles
L1display = L1+d # show upper assembly a bit longer than physical, to overlap axle
L2 = 1.0 # physical length of lower bar
L2display = L2+d/2. # show lower bar a bit longer than physical, to overlap axle
# Coefficients used in Lagrangian calculation
A = (1./4.)*M1*L1**2+(1./12.)*M1*L1**2+M2*L1**2
B = (1./2.)*M2*L1*L2
C = g*L1*(M1/2.+M2)
D = M2*L1*L2/2.
E = (1./12.)*M2*L2**2+(1./4.)*M2*L2**2
F = g*L2*M2/2.
hpedestal = 1*(L1+L2) # height of pedestal
wpedestal = 0.1 # width of pedestal
tbase = 0.05 # thickness of base
wbase = 8.*gap # width of base
offset = 2.*gap # from center of pedestal to center of U-shaped upper assembly
top = vector(0,0,0) # top of inner bar of U-shaped upper assembly
scene.center = top-vector(0,(L1+L2)/2.,0)
pedestal = box(pos=top-vector(0,hpedestal/2.,offset),
height=1.1*hpedestal, length=wpedestal, width=wpedestal,
color=(0.4,0.4,0.5))
base = box(pos=top-vector(0,hpedestal+tbase/2.,offset),
height=tbase, length=wbase, width=wbase,
color=pedestal.color)
axle = cylinder(pos=top-vector(0,0,gap/2.-d/4.), axis=(0,0,-offset), radius=d/4., color=color.yellow)
frame1 = frame(pos=top)
bar1 = box(frame=frame1, pos=(L1display/2.-d/2.,0,-(gap+d)/2.), size=(L1display,d,d), color=color.red)
bar1b = box(frame=frame1, pos=(L1display/2.-d/2.,0,(gap+d)/2.), size=(L1display,d,d), color=color.red)
axle1 = cylinder(frame=frame1, pos=(L1,0,-(gap+d)/2.), axis=(0,0,gap+d),
radius=axle.radius*20, color=axle.color)
frame1.axis = (0,-1,0)
theta1 = -2.001*pi/2. # initial upper angle (from vertical)
theta1dot = 0 # initial rate of change of theta1
frame1.rotate(axis=(0,0,1), angle=theta1)
scene.autoscale = 0
dt = 0.001
t = 0.
while 1:
rate(1./dt)
# Calculate accelerations of the Lagrangian coordinates:
atheta1 = ((E*C/B)*sin(theta1))/(D-E*A/B)
# Update velocities of the Lagrangian coordinates:
theta1dot = theta1dot+atheta1*dt
# Update Lagrangian coordinates:
dtheta1 = theta1dot*dt
theta1 = theta1+dtheta1
frame1.rotate(axis=(0,0,1), angle=dtheta1)
t = t+dt
