What have I invented?
helloha
re: What have I invented?
Post by helloha »
Can the control board be programmed/built to detect/sense the water level (or detect the rise/fall of object),
and if water level reach a certain height, it open a valve (or lock an object);
and when water level drop a low height, it close the valve (or unlock an object) ?
‘If you can’t explain it to a 11-year-old, you probably don’t understand it yourself.’
For simplicity is genius.
Yes, helloha, it can easily do that, but so can any microcontroller. I could help you, or if you wNt to do the research yourself you could try a small "arduino" with a relay board. You have to decide on the hardware to do the latching.
helloha
Post by helloha »
Awesome that you can help, but unfortunately the basic experiment I'm trying out keep failing lol ..... maybe later :)
