Gravity motor motto...
re: Gravity motor motto...
.....in an explicit short language , as a " self " spinning lever/age ( due to a continuous gravity unbalance/torque difference ) , in a basic family of :
https://youtu.be/JOLtS4VUcvQ
Anyway , the lever/age is the "root" of mechanics...
Al_ex
Al_ex
.....allegorically speaking , as a simple pendular " composition " , expressing a continuous accelerated wave of motion ...
Al_ex
Al_ex
.....at : www.kuwaitmoto.com/wp-content/uploads/2 ... hm13b3.jpg
Simply , to start a motor ( including a gravity one...) you need to use the ( ( gravity acceleration ...as a ...) gas pedal , nothing more...
Al_ex
Al_ex
A motto--------Where there's a will, there is a way, I always say, Sam
.....if gravity is a natural linear accelerator , let's play an artificial cyclotronic acceleration " arrangement " ...as a manner to obtain "self"-motion ! Al_ex
....simply:let it be (your "mass"...) accelerated !
Or': apply (a "free"...) acceleration to your model,so to obtain a continuous gravity unbalance (pulsing rotational motion ).
The "exit from inertia" can be a cyclical increasing velocity , due to the natural acceleration , we are living "inside". Al_ex
.....as a concise intuition , at :
https://en.m.wikipedia.org/wiki/Self-oscillation
....if we intend to imagine a periodic self-sustaining motion in a source of power ( gravity field ) " that lacks...periodicity ".
Al_ex
Al_ex
.....to understand a possible gravity motor...let's go back to Archimedes,Galileo,Huygens,Newton,,,and maybe...Bessler...regarding lever,gravity free fall,pendulum and inertia.
Al_ex
Al_ex
.....if we play a greater gravity free fall ( PE into KE...),rotational inertia in-out storage and ("self"...) variable arm , or a gravity continuous unbalanced leverage ( make a search on "Google"-images...).
Al_ex
Al_ex
.....can be a "repeating gravity discharge" of a natural energy storage (gravity potential difference...as a mechanical "battery") .....due to a continuous torque difference , on the same side of the fulcrum .....as an alternating continuous "descending " gravity "wave" .....playing the full free fall of an inverted pendulum ("equivalence"...) .....of a possible "self" variable leverage.
Take a look at :
https://en.m.wikipedia.org/wiki/Gravity_battery
www.geocities.ws/iacob_alex/Some_Drafts/text028.JPG
www.geocities.ws/iacob_alex/Some_Drafts/text048.jpg
Simply , we can arrange,set the gravity free fall as pendular incoming "extracted waves " (dc into ac...it's like "pulsed wavering gravity " , nothing more...) at our "cosmic Milky Way shore" ...why not !?
Al_ex
Take a look at :
Al_ex
Hi iacob alex,
I agree with the most of the posts from you above.
In the Besslerwheel we use a parasitic oscillation in a positive feed loop.
Your drawing is always using a fix axle to manipulate the weights movement, this is wrong, I will not offend you, because you have a lot insights and a lot of understanding what is going on in an oscillation.
I will here explain how I will see it: your constructions are bound with the fix axle, so a degree of freedom of movement is not allowed.
Remember Besslers words, and the axle must also be able to move.
This implies a wobbeling axle. The axle is swinging in the room.
The axle can swing up and down, and also from left to right and reversal.
A normal pendulum is generating a simple wave, but we need an overlay of two swingings. This can be done when we also manipulate the fastened point of the pendulum. When we do this periodically, then the amplitude of the pendulum swinging is increased. With this construction you have a self amplified oscillation, but still not a Bessler wheel.
Hi Georg !
Take a look at a possible (not tested...) gravity (and inertia...) "self" oscillatory ( swinging+ rotating ) leverage , at :
www.geocities.ws/iacob_alex/Some_Drafts/text031.jpg
This "three sticks game" is a development of the "two sticks game" (the well known "swinging sticks toy"...with the so old "shadoof" concept ...) , intended to play/continuous pulsed rotation due to a wobbling axis/mobile fulcrum ?!
Anyway , the test first and the comment afterwards...the experiment is one thing you can't get for nothing ...of this triple oscillatory motion.
Al_ex
Al_ex
Hi iacob alex,
yes that is the oscillation what I mean. One thing missing is now that this system must be preloaded with "Gravity energy".
Preload with "Gravity energy" is that the system must be set under stress by gravity, managabe with its own weight.
When we now can create an swinging with an increase amplitude then we can think of creating a circle process.
Hi Georg !
Really , if we test this proposal (let's say the model 001), the first step can be a continuous increasing motion !...like a "black box" with an input ,but missing the output ?
If so , the next step is to introduce a stabilizing network ?
Al_ex
Al_ex
