Fletcher,
I too have looked in and stepped back, to date I cannot disseminate whether we are being dazzled with brilliance or baffled with bullshit!
To reiterate my long term thoughts: Scissor jacks are only another mechanical means of finding one stuck with the latest acronym (coming to my attention) "W4H"...
For the thought experiment what about 2 systems on a see-saw. One Jack extends and extra mv and KE is generated. At the same time the opposite mech on the other side of the see-saw is contracted and reset. Then they reverse actions. IOW's they pump and reset alternatively.
A fine description of linear motion, all we need to capture is: "Whats powering the pump?"...
Hi Ralph .. your W4H is my H4W (Height For Width) ;7)
"What's powering the pump ?" That would be the Reactionless Accelerations (RA's) giving rise to more linear momentum (asymmetric mv) in one vertical direction (downwards) than the other (upwards) that MrV proposes is a mathematical certainty and that conforms to known Laws.
Building a test rig to physically test the reality is another challenge after finding an N3 break to exploit.
However in the interests of clarity if asymmetric mv can be generated and harnessed then that also means that we would have excess KE. N.B. mv doubles KE quadruples etc. AND ... Energy is recognised as Capacity to do Work. Therefore if there is indeed a provable excess of mv (either linear or angular (say attached to a flywheel) then that will automatically translate to excess KE or GPE. Case closed ! MrV is on-the-money.
  • As far as the laws of mathematics refer to reality,
    they are not certain, and as far as they are certain,
    they do not refer to reality.
    ...................................................................Albert
SI units are subject to change.
  • The 24th and 25th General Conferences on Weights and
    Measures (CGPM) in 2011 and 2014, for example, discussed
    a proposal to change the definition of the kilogram, linking it
    to an invariant of nature rather than to the mass of a material
    artefact, thereby ensuring long-term stability.
    ...................................................................wiki
Basing a theory on a relationship between derived
relationships is iffy at best.
I see a bit of irrational exuberance here. When this theory
is up and running on an analog computer, then we'll know.
In the mean time I would like to know who's handling the
bets in this casino. :}
MrVibrating
Post by MrVibrating »
Fletcher wrote:MrV .. I am trying to step back and visualize some type of simple thought experiment that could prove your N3 break and a surplus of mv and KE by default.
Precisely what i used in the calculations - an ordinary elastic collision, unadulterated by gravity - ie. horizontal to it.
Then perhaps that thought experiment could translate into a sim and then real world build as POP ?
Picture a slack length of rope between the two masses. Their internal displacement's 9.81 meters, so make it 9.82 m long.. as soon as the sim ends the rope is pulled taut by the lower mass's higher velocity relative to the upper one's, jerking the upper one into motion and so divvying up the momentum difference, per N3.
I realize that you say it takes either 5 Reactionless Accelerations (RA's) to go from accumulated UU to OU by your reckoning. Why not go for 6 and have internal losses well and truly covered ?
Or 8 for that matter? 200% OU sounds pretty sweet huh?
Anyways, the point being that if you assume the expanding Jack is massless it makes it easier to isolate and simplify. BTW this can pretty much be done in a sim by using massless rods as connections between small nodes (of very little mass). Also you don't need large numbers of cross segments in the Jack. Any linear advantage (accelerations etc) can be duplicated by just two segments, a small one for the Effort and a large dimensions one for the Load. The results are the same as having multiple segments and duplicate what a normal multi-segment Jack does.
Cool tip, will keep it in mind ta.
Alternatively, pulleys fixed to a lightweight linear slider would also suffice - it matters not that the actuator has mass; it's preferable to optimise the ratio of course, but the effect has high margins of tolerance.. like i say, any degree of cancellation of counter-momentum generates a corresponding momentum gain, of speed-invariant cost.
To continue .. usually if you can visualize a rotary system for a design then there is usually also a reciprocating / oscillating variant you could come up with.
I've tried to stress that angular-angular inertias seem the most build-friendly route. I've only been using exaggerated linear-linear displacements for clarity in demonstrating the gain principle. A build could be based on the linear-linear examples, but it'd likely be inelegant, with a poor power density. An angular-angular or angular-linear interaction would also eliminate the need for the lower mass and thus any net change in GPE during the inertial interaction.
For the thought experiment what about 2 systems on a see-saw. One Jack extends and extra mv and KE is generated. At the same time the opposite mech on the otherside of the see-saw is contracted and reset. Then they reverse actions. IOW's they pump and reset alternatively.
LOL you basically just ninja'd my "MT 143" observation above..
Yep linear-linear systems are defo viable, but frankly the options are almost limitless - we haven't scratched the surface yet. Any inertia in any potential plane or axis (3 of each, 6DoF total), under any static force field (magnetic, centrifugal (ie. mounted to the wall of a horizontally-rotating drum), inertial (ie. atop a rocket), bleedin' knicker 'laccy for all i know; force is force, F=mA, and whichever one's used, no net work's required from it.. it just has to hang there and set the atmosphere for the ensuing inertial interaction, which could be between anything from permanent magnets to solenoids to freakin' fluids), the process is scale-invariant so could be tiny or huge, the potential power densities almost arbitrary.
So look beyond the linear-linear examples - get the concept, and apply it imaginatively to try come up with an elegant implementation. As i've said, much smaller bites of momentum / angle seem the way to go - what would seem ideal would be an angular-angular interaction, possibly featuring a radial component to coordinate the interaction and feed back a CF workload. This could then be segmented around a wheel in the usual manner, also facilitating any interactions between mechanisms that might be useful.
An oscillating system OTOH (per "MT 143" would have to generate and harness all its momentum gain on each alternate stroke, presumably, so won't be able to build up much, unless its amplitude is governed by a spring or something. It could benefit from the single-strike-to-OU interaction i demonstrated above tho.. Prime it to its unity threshold with any kind of PE and generate excess momentum on the first stroke.. and every subsequent one..
If there is a surplus of mv and KE then one side of the see-saw should be able to reset the other, should it not ? Does this get us any closer to a POP concept ?
Strictly, there's no 'excess' of momentum until the moment it's rectified / consolidated.
Prior to that closing elastic collision, there's exactly the right amount of momentum, corresponding to the energy invested.
It's just unidirectional - of one sign only.
And because of that, a subsequent regular N3-consistent collision between them equalises their disparity to a positive sum... That is the gain; when the unidirectional-but-fully-accounted-for momentum difference is equalised between both masses, their new shared ambient velocity has a higher KE value than when all of that momentum difference was manifested on one mass only, due to the v^2 multiplier (increasing energy magnitude when ascending, and decreasing in descent, so 1 kg-m/s more is a greater change in net energy than 1 kg-m/s less).
So it settles the system (of two interacting inertias) into a new equilibrium velocity - instead of say a 10 kg purchase of momentum being served as +5 and -5 kg-m/s portions, ie. a net zero change, we've bought it all of one sign only; +10 on one mass, and fat zero on the other. Thus a subsequent elastic collision equalises that unidirectional momentum between them, and both end up with +5 kg-m/s, accelerating the net system by this amount, and so causing a corresponding KE rise, for the same internal work we'd've done - the same amount of momentum we'd've raised - whether the resulting division of momentum had been symmetrical or not. Either way, we paid for 10 kg-m/s, but obviously, if it's of one sign only then it's worth a bit more (per #RA's / 4 or whatever Marcello's formula was) - and because the RKE is subject to the RPM^2 multiplier, but the inertias generating the momentum gain are speed-invariant, the unidirectional momentum gain is worth more as RPMs accumulate.
The take home point is simply that the energy cost of generating this momentum gain is purely that of the inertial interaction, which costs the same energy regardless of whether it's gravitationally-skewed or not, and regardless of the ambient velocity at which the masses are moving (since inertia's not speed-dependent), whereas the energy value of the accumulating momentum gains are a function of their rising velocity.
By the innate mathematics of nature, 4 consecutive reactionless accelerations applied this way result in precisely the same energy and momentum conditions as would be arrived at via any conventional, N3-compliant form of accelerating mass.
Less than 4 RA's result in an under-unity result, and more than 4, over-unity. 8 make 200% OU.
It is a lot to digest i guess (esp. the way i ramble on) but stick with it, it's actually pretty straightforward, and can be reduced to just two inertias, one of which is subject to gravity during part of a full cycle. The rest is just the energy feedback system.
As i've shown, we have two basic design options - i'm kinda thinking of them as "2-stroke" vs "4-stroke" - not so much to do with the actual stroke counts, as one's quick'n'dirty and needs a good bump-start, with the other being more controlled and methodical, but also OU from a standing start.
We've all the time in the world to let it sink in and start trying to apply it, just familiarise yourself with the I/O energy asymmetry for now, check my maths, replicate the method and results, error remains possible (if not likely), understand the bounds and flexibilites, and with a little imagination our systems should largely design themselves.
I've tried to give as lucid an account of these findings as i'm able, so while it is a bit a sprawl, if you've any glaring questions there's a good chance i've addressed them on recent pages already, tho anything i can help clarify, just ask..
MrVibrating
Fletcher wrote:Hi Ralph .. your W4H is my H4W (Height For Width) ;7)
See past the GPE interaction - GPE-in = GPE-out.
We would only transgress this condition if some of that GPE actually performed work in causing the momentum asymmetry.
And yet it is entirely passive - all of the KE and momentum contributed by gravity can be repaid in full, leaving only the KE and momentum input to the intertial interaction, all of which is of one sign only.
And again, fully-asymmetric interactions aren't required - the gain is simply directly proportionate to the degree of momentum asymmetry.
Any such asymmetry resolves to a non-zero sum, via any ordinary elastic interaction or collision.
We're in, mate.
Let's stick together, scope it out, try not to get split up..
MrVibrating
My fear is we all are, mate.
As for the specific units, they're irrelevant, all that matters is that they're applied consistently. The real key here is their respective dimensions.
When i say i'm "certain" it just means i've triple-checked, fully integrated and cross-referenced everything i can think of - the sims perfectly matched the original hypothesis, to 5 significant digits, and we're staring into an anomaly of far greater magnitude and implication than any possible margin of error, which anyone familiar with classical conservation principles should immediately be able to grasp - the cause and effect chain is incontrovertible. Well, i can't controvert it anyway. I'm fallible, and i've been wrong on every previous occasion.. but this time, it really looks like it's all fallen into place. We have the keys to the safe..
MrVibrating
From http://www.besslerwheel.com/timeline.html :
1717
Spring
Bessler's last and largest wheel was completed at Castle Weissenstein. It was 6½ ells in diameter (about 12 feet), about 18 inches wide, and turned at 26 revolutions per minute. It continuously lifted heavy stamps for printing and raised water with an Archimedean screw.
November
Prince Karl arranged the most rigorous official test of Bessler's wheel at Castle Weissenstein. Participants included the Court Architect of the Austrian Emperor Baron Fischer and Professor Willem 'sGravesande - a close friend of Isaac Newton. The machine underwent a 54 day test in a locked and sealed room, during which time the examiners were allowed spontaneous entry. At all times the machine was found to be turning at its regular 26 revolutions per minute. The investigators publicly certified that the wheel was genuine and that no sign of fraud could be found.
From http://www.pascalbonenfant.com/18c/weather.html :
1717 (Christmas)
24th/25th December(NS): According to Hubert Lamb, this was 'one of the greatest historically recorded storm disasters on the coasts of the North Sea in terms of loss of life - possibly since the beginning of major dyke building.' About 11 000 people are reported to have died, with the death toll especially high in Germany - there was also a great loss of livestock (90 000 cattle at least). Storm damage/flooding both sides of the North Sea, also on the French side of the Channel - much significant damage to the dykes on the eastern side of the North Sea. (December 1717 was apparently a 'very stormy month', with the sequence of periods of high winds beginning in the last few days of November/NS.)
So the longest demonstration of JB's largest, most powerful wheel coincided with record storms in the weeks immediately following...
Given that we could probably consult maps of humanity's energy consumption as a function of geographical areas, and also Google the mass of the Earth, we could take a stab at estimating the potential impact a Bessler-wheel global economy might have as a function of net thrust over time or whatever... we already know there's 1 kg-m/s of uncancelled momentum per 9.81 J generated, so if we're gonna be piloting this thing we might wanna read the flight manual... dunno. I ain't even got a driving licence TBH.
I'm really starting to think we should put this in lockdown mode til we've got a proper handle-construction on it, type stuff..? Private forum, Fight Club rules? All welcome - the objective isn't to hide it away from the world, so much as protect it from our collective stupidity..
While we're still awaiting independent corroboration, if my maths are correct - and i've double and triple-checked - then we could be even more more stupider than even we would ever have even granted ourselves credit for..
So my main concern is that we only release deliberate warp drives, not inadvertent ones.
"Momentum pollution" sounds nuts, but no previous energy revolution has posed such a hazard. We're struggling just to keep our little wet bubble of gas habitable as it is, without having to worry about steering it too..
And before you suggest controlling it via deliberate geoengineering, remember we have to keep the moon in perfect tidal lock, if we don't wanna open up some flood basalts etc.. and i'm not just talking about up there...
These is big boys toys...
The great storm of 1717 is doubtless coincidence... but if it's not enough to unnerve you, you haven't quite got your head in the game yet. History will judge us harshly if we knew the risks and ignored them.
Don't wanna be needlessly melodramatic, but better that than naive or reckless..?
Just have pairs of machines MrV - one entangled on the opposite side of the world ;7)
Furcurequs
Post by Furcurequs »
MrVibrating,
Sorry to be a party pooper, but I need to address some of the problems with your idea.
You seem to be rather high on your own made up rhetoric, and apparently in more ways than one, but sadly at the same time you are showing us that in some things you simply don't have a command of the correct language nor an actual working understanding of the basic physics.
In the parts where you are relaying what your simulation has told you, you don't seem to be too far off, but when you start talking about collisions and the division of momentum and whatnot, you go off the rails.
Linear momentum is a vector quantity that has both a magnitude and direction and yet you talk of it as if it were but a scalar quantity.
In your linear example, you have pushed the descending masses apart, so they are moving away from one another even though they are both moving in the same direction. They are not on a collision course with one another.
To change the direction of motion of one or both of the masses so as to place them on a collision course with one another requires the altering of their linear momenta - which means they have to exchange momentum with something else, and in this example most likely the earth.
If you want them to (for the most part) conserve their kinetic energy while altering their direction of motion, that's doable, but you should be talking about them maintaining their SPEED and not their momentum. It, of course, is possible to manipulate their direction of motion while keeping most of their speed and kinetic energy, but this will change their linear momentum because it changes their direction of motion.
Now, let's talk collisions. During a collision all of the (macroscopic) kinetic energy can be lost, or at best most of it can be conserved, but it can also be anything in between, and yet momentum is conserved in all of these interactions! That's why we need to know whether the collision is perfectly elastic or perfectly inelastic or otherwise know the coefficient of restitution or something.
Let's say you've actually altered the momentum of each mass so that they are both headed in the same direction and the faster mass is indeed on a collision course with the slower moving mass that it is overtaking (and maybe this is done horizontally at the same height above the earth).
If you let the equal masses collide in a perfectly elastic collision, their total energy is conserved, but THE TWO EQUAL MASSES DO NOT END UP WITH THE SAME SPEED AND THE SAME MOMENTUM. YOU HAVE INTRODUCED A SCENARIO THAT JUST DOES NOT HAPPEN!
The situation is like with a Newton's Cradle. The faster moving mass becomes the slower moving mass and vice versa.
The collision scenario in which both would end up with the same speed and thus the same momentum after collision would be with a totally INELASTIC collision in which they end up stuck together. Energy is lost in this type of collision, though.
In other words, you have just matter-of-factly introduced a magical scenario that just does not happen.
If you can't now address and properly explain how you are supposedly accomplishing this bit of magic, this supposed energy producing collision, there's really not more to say about the subject. You would appear to be just confused.
Again, when calculations are done correctly, all energy is accounted for and any excess energy is just that which you are adding internally.
Dwayne
I prefer working alone.
Grimer
Post by Grimer »
I am confident that harnessing Beta-atmosphere energy will be as benign as harnessing hydroelectric power.
You are being paranoid, MrV. Understandable I suppose if you think you have solved a 300 year old riddle. Talking of which I've just noticed that 2017 is the
tercentenary of 1717.
Grimer
Post by Grimer »
Furcurequs wrote:MrVibrating,
Now, let's talk collisions. During a collision all of the (macroscopic) kinetic energy can be lost, or at best most of it can be conserved, but it can also be anything in between, and yet momentum is conserved in all of these interactions! That's why we need to know whether the collision is perfectly elastic or perfectly inelastic or, otherwise, the coefficient of restitution.
Dwayne
Congratulations on your heroic attempt to get to the heart of what MrV is on about.
I'm afraid I gave up long ago due to sheer laziness I'm afraid.
MrVibrating
Dwayne
Hi mate.
So your big reservation here is that there's something magical about dividing two masses' momentum difference between them?
You could use a rope or an angular trajectory as i've mentioned, sure that'll burn off some energy but even if it's 50% lossy, momentum's still conserved and equally divided.
The effect only depends upon using a static force to skew the initial distribution of momentum.
Example: a 1 kg mass is floating east at 1 meter/sec, so it has 1/2 a Joule and 1 kg-m/s of momentum. If a second such mass is stationary, and a 50% elastic rope is pulled taut between it and the moving mass, each ends up with 1/2 kg-m/s and 1/8 of a Joule.
It does not matter that we've dissipated 1/4 of the net KE, because the exploit depends upon incrementally nudging up the net momentum, from a workload internal between the two masses.
Consolidating / accumulating that gain doesn't thus need to be fully energy-conservative. The point is simply that this second interaction between the two masses equalises their momentum difference.
Again, the linear-linear example is just a proof of principle to keep the principal clear, and probably not the best option to try incorporate into a design.
I've been keeping the system lossless for simplicity, to focus instead on trying to show how input and output energies have different scaling dimensions - losses are initially an unnecessary complication, especially when investigating potential symmetry breaks. Obviously a real-world build will have losses, but the gain margins here square with velocity..
So the energy gain principle is a consequence of the momentum gain principle, which simply requires initiating an inertial interaction in which the distribution of momentum is rendered unequal by the presence of a second static force being applied to the system.
That momentum difference can then be equalised between them, via a rope or inelastic collision (OK?), with an interaction unaffected by that static field.
Then it can be repeated.
A completely automated interaction - generating and consolidating a momentum gain over two or more cycles - is the current design challenge, which hasn't yet even begun - no-one's posted an example yet anyway. I think an angular-angular or angular-linear implementation, with much smaller bites of momentum per angle, is the way to go, but have barely begun looking into it yet.
If you'd like, though, we could run a series of sims in which each end with a length of semi-elastic rope being pulled taut between the two linear masses, equalising their momenta, and then beginning each subsequent sim with those final conditions from the previous one. But that's a lot of GPE to subtract using the current method LOL.. and it's obvious the same gradient's going to fall out.
I am fallible and this is all still theoretical until physical tests are done. What's exciting though is the appearance of this break in symmetry between the respective dimensions of the input and output energy terms. Things like losses, basic N3-compliant interactions or the standard KE terms, i'm taking for granted rather than establishing independently from first principles. The only magic i'm asking for is that we can slowly ramp up momentum using the suggested principle. If so, then this OU energy gradient is wide open to us.
Look forwards to your reply, cheers.,
MrVibrating
Fletcher wrote:Just have pairs of machines MrV - one entangled on the opposite side of the world ;7)
Yeah, thought of that too, just stretch it instead.. not so bad i guess..
MrVibrating
Grimer wrote:I am confident that harnessing Beta-atmosphere energy will be as benign as harnessing hydroelectric power.
Defo para, still, if there was a net upwards acceleration of say 10 kg-m/s of the entire earth towards a non-falling mass just above the ground in Kassel, throughout November and into the first weeks of December, then all the oceans and atmosphere would lag behind that acceleration due to their fluidity, inertia and viscosity etc.
At the end of the test, that force is suddenly removed, and so the acceleration ends, and so all that fluid immediately sloshes back up and floods the point of origin of the acceleration..
Additionally, forces applied to earth are de-syncing the lunar cycle and thus destabilising tidal equilibria..
Almost butterfly effects - tiny changes with potentially big impacts.
But yeah i'm being all histrionic. It's probably just totally free energy and momentum from nowhere, without any consequences, and everything's gonna be super-fantastic.
Grimer
Post by Grimer »
It's not energy from nowhere. It's energy from the Beta-atmosphere, the atmosphere that holds materials together.
