Gravity Wheel
silent
re: Gravity Wheel
Post by silent »
Calloway
re: Gravity Wheel
Post by Calloway »
dradford, This is what I think is unique with this design. The pendulums are not transferring their weight or taking from the slider weight because they make contact from the side of the pendulums. No weight is transferred between the two. The pendulums touch nothing on the wheel except the slider weight at the glove. So the wheel is undisturbed an keeps turning as normal. I'm seeing some interesting things from this wheel. Cheers
justsomeone
re: Gravity Wheel
Post by justsomeone »
Connected weights in a fast spinning wheel may want to stay in their position due Centrifugal force. More effort would be required to shift them than one might expect.
Calloway
re: Gravity Wheel
Post by Calloway »
justsomeone, It won't spin fast. 40 to 50 RPM tops. The speed of gravity is rather slow at the earths surface.
<The term g is based on the pull of gravity. An acceleration equal to the acceleration of gravity, 980.665 centimeter-second-squared, approximately 32.2 feet per second per second at sea level; used as a unit of stress measurement for bodies undergoing acceleration.>
Cheers
silent
re: Gravity Wheel
Post by silent »
dradford
re: Gravity Wheel
Post by dradford »
Here is a free pendulum simulator that may be useful - unfortunately it doesn't measure forces at the pivot, which is what I'm looking for.
http://phet.colorado.edu/sims/pendulum- ... ab_en.html
I haven't had any spare time (I have a full time job, like a lot of members here no doubt) to play with Algodoo, I'll try to spend time on it tonight.
The force transmitted through a rod that might hurt your hand is a vibration that is damped in a cord. The gravitational pull on a cord is the same as it would be on a rod. So the pivot would experience the same force in either case.
Calloway's design rests on the pendulums lifting themselves (inward against centrifugal force, not gravity since they are balanced by the opposite pendulums) in the 6-9 quadrant. Dradford's animation is not an accurate picture, imo.
silent
Post by silent »
Calloway
re: Gravity Wheel
Post by Calloway »
eccentrically1, Would you kindly explain to us how the pendulums act on a wheel? You say in your opinion that dradfords animation is not accurate. Please tell us why. Cheers
It's not accurate because it's an animation of how he thinks the pendulums would act on a wheel.
Look at it again. Page 9. The pendulums are lifting themselves inward (around 7-8) while at the same time lifting the two sliding weights and the connecting rod.
justsomeone
re: Gravity Wheel
Excellent observation Ecc. as always!
Calloway
re: Gravity Wheel
Post by Calloway »
eccentrically1, So the mistake is, the pendulums don't swing in at at 7:00 or 8:00. Correct? Cheers
Correct. Sort of. Depending on the rotation speed, they would either oscillate like normal, or swing outwards.
Calloway
re: Gravity Wheel
Post by Calloway »
eccentrically1, Turn out? Completely wrong. Oscillate? You need to get a wheel with pendulums and actually see how they act. Don't put anything else on the wheel. Just pendulums. Dradford made a animation that is close enough for folks to get a good idea how the design works. It's certainly not perfect. But maybe it helped some. Cheers
re: Gravity Wheel
Where's Crazy Dave (the pendulum wiz) when you need him. He's got some nice vids of his experiments on YouTube. Can't remember where to find them now.
His handle here is FunWithGravity2
Found one of them. MrJudgeFreed
https://www.youtube.com/watch?v=Oy0gKtWc6Bc&t=38s
