One for sure MT number
re: One for sure MT number
Leafy wrote:Do you guys think Bessler had many working designs or he just use one design for all of his wheels?
Hopefully there are more than one way of doing it so we have more chance of hitting one of them.
Leafy .. if you haven't done so already I suggest you purchase the digital copies of John Collins books on Bessler. Great research material.
http://www.free-energy.co.uk/html/books_for_sale.html
I did a quick scan thru the books and selected some of the references to 'principle' I think are applicable. I won't highlight what I think is important in each tract, but some thoughtful reading should answer your questions (as well as others that get raised from time to time) and you can make up your own mind.
*** Bessler’s PM principle i.e. excess weight, excess impetus, or preponderance ***
John Collins wrote:GB pg 52 : Among all the wise and learned devotees of the physical, mathematical and mechanical sciences there can be found no one who is unaware of the countless debates that have taken place amongst the scholars regarding this single question, namely : - Is there such a thing in nature as perpetual motion, or a perpetuum mobile? And that therefore, whether it may be possible for human hands to introduce into material bodies, in themselves lifeless, a permanent innate motive force, a constant interchange of rise and fall, of excess and deficient weight, resulting, as it were, in a living machine that might seemingly have been in existence from the earliest days of creation. It’s certainly true that most, if not all, of these people who made countless vain efforts in the painstaking investigation of such mysteries, attempting to fathom the principle of perpetual motion,
AP pg 246 : You will, oh paragon of virtue, be unable to show me printed evidence that a work of art of this nature ever existed in the world before. Therefore, my machine is the only one now in existence that accords to true physical principles.
AP pg 259 : Eventually I came to Prague, and began as early as my first night there to think of the Primum Mobile. For the vision of the roasting-spit would not leave my mind. I thought it might be possible, on mechanical principles, to devise a better machine, and shut myself up to study the matter. One day a Jesuit came to see me - perhaps the most learned priest I'd ever met - and soon we were great friends.
AP pg 339 : The clattering noise you refer to is, I assure you, a phenomenon caused directly by the real motive power of the machine, and nothing else. You also wish me to inform you why the Draschwitz machine did not create a similar noise; well, I'll tell you. The two machines can easily be contrasted, as they worked on quite different principles. The former (Draschwitz) one turned in only one direction, but the latter (Merseburg ) one turned, as everyone could see, both ways. The former was provided with felt
coverings, but the latter was as bare as a bald head. I have many other machines of various types - some, for instance, with weights, others without.
DT pg 190 : The internal structure of the wheel is designed in such a way that weights (page 20) applied in accordance with the laws of Perpetual Motion, work, once a small impressed force has caused the commencement of movement, to perpetuate the said movement and cause the rotation to continue indefinitely – that is, as long as the device retains its structural integrity – without the necessity of external assistance for its continuation – such as the mechanisms which are to be found in other ‘automatics’ – e.g. clockwork, springs or weights that require rewinding. For this concept, my ‘principle of excess weight’, is NOT just an external appendage, an ‘added-on device’ which is there in order to cause, through application of its weight, the continuation of the motion (the revolution) so long as the cords or chains, from which it depends, permit. NO, these weights are themselves the PM device, the ‘essential constituent parts’ which must of necessity continue to exercise their motive force (derived from the PM principle) indefinitely – so long as they keep away from the centre of gravity. To this end they are enclosed (page 21) in a structure or framework, and coordinated in such a way that not only are they prevented from attaining their desired equilibrium or ‘point of rest’, but they must for ever seek it, thereby developing an impressive velocity which is proportional to their mass and to the dimensions of their housing. This velocity is sufficient for the moving and raising of loads applied to the axis of rotation.
DT pg 209 : And in truth it now seems to me that the time is long overdue, now that I have achieved my goal, once known only to God, that I and the world should see this principle, in itself so simple, and yet at the same time so deeply hidden, of everlasting motion, described in total detail and in mathematical simplicity, in praise of God’s boundless wisdom, and for the benefit of the entire world.
DT pg 215 : for their operation (no matter if this operation lasts many years) do not possess the principle of motion internally, rather externally to themselves. They are not per se “mobile�, rather per accidens, so that motion is not inherent to the machine, but to the contingent aspect associated with it, with the result that should this be lacking, the machine would stand still, incapable of moving itself or a grain of dust. Such machines can, then, only be called Perpetual Motion as an abuse of language, just as it would be were I to use the term “perpetual motion� to describe the continued movement of the water screw, the press and the boxes of stones which, I described earlier, I attached to my machine, and which would continue to move via my device, as long as their material endured. (For we are here talking, again, about “accidental� rather than “innate� motion.) (page 75)
DT pg 222 : Thereby, I hope, they will come to appreciate fully the importance and rightness of my work, especially as the effect it produces, now known to a wide public and more than amply described in this document, has never been matched by any other known mechanical device. (Not, of course, that my device invalidates known principles, or renders all existing types of machine obsolete).
DT pg 252 : To Those Who Do Not Believe. The mechanic maintains that Perpetual Motion has hitherto, from known principles of Statics, been considered impossible.
Best.
Leafy
Re: re: One for sure MT number
Post by Leafy »
agor95 wrote:
You are not the first to ask about the $$$$$ signs and you are not the last.
Just ask yourself how much money did the inventor of A/C power get.
All the Best
You mean Tesla? But I’m not him. The world already has everything. I rather have a big sum of money and live a comfortable life than being a hero. I guess different time create different thinking. How about agor? What is his life like with the wisdom of perpetual motion?
Leafy
Post by Leafy »
Thank you Fletcher,
I would read all about Bessler after I succeed. He is an interesting person. If I were in Bessler time, I would give him all my saving to understand PM.
So back then PM consider impossible from Static viewpoint, but his machine is static.
agor95 wrote:Hi eccentrically1
I am not seeing the problem.
Would you like to clarify the context of your statement; like who is the 'we' in the statement.
All the Best.
We. You and everyone here. Or everywhere. We can’t get weights to gain force from swinging.
We can get the force from the swinging masses, at least I can.
Only build a coupled mechanical oscillator with an amplification.
The amplification will grow endless.
So you have to limit this amplification in a specific range.
If you have this, then you can think over a revolving wheel, because this swinging is more complex.
It is a dynamic system, not static.
George, you cant just add a weight and spring and expect it to increase the amplitude of the swinging weight. With a swinging weight on a rope, you need to pull in at the bottom where CF/inertia works the hardest against you, then release at the top when there is the least pull on the string as gravity works against inertia.
Hi Tarsier79,
i think you are familiar with this two pages
https://de.wikipedia.org/wiki/Mathematisches_Pendel
https://en.wikipedia.org/wiki/Pendulum_(mathematics)
You see also how masses are coupled with a spring.
This are all versions which create a damped vibration.
What I do is to pull on the string during the pendulum is swinging.
When I do this I get an amplified swinging.
The function is a variation of the length of the rope.
This effect you can prove yourself.
Now I substitute my pulling with an additional weight and a spring.
So the weight is now stretching the spring more and shorten the rope length.
The things are coupled in a different way, gravity plays against gravity.
axel
Post by axel »
Whichever one supplies a torque somewhere in its construction, but not an overbalance.
Hi axel,
a pendulum on a rope has a variating force on the rope.
Shortening the length of the rope periodically will result in an increasing amplitude.
axel
Post by axel »
I believe that Bessler’s Wheel was somehow powered by a torque applied to the construction somewhere. Overbalance had little to do with it.
zoelra
Post by zoelra »
Bessler's first wheels were self starters, and since the axle moved with the wheel, there was nothing inside the wheel to push off of, so Overbalance is the only explainable force capable of driving the wheel, and that Overbalance was in the form of torque applied to the wheel.
* I assume the axle turned with the wheel, but I am not 100% certain there is any factual evidence to back that up. If anyone has evidence either way, I would like to see that.
axel
Post by axel »
I’m saying that torque applied to the wheel, then the wheel applied torque to a load.
Hi Fletcher
Each person will have their own take on what is important in the clues.
I am will see if this clue helps. However I am taking the phrase 'known principles of Statics' to mean one thing and I have no idea what it was in his time.
All the Best
fletcher wrote:AP pg 246 : You will, oh paragon of virtue, be unable to show me printed evidence that a work of art of this nature ever existed in the world before. Therefore, my machine is the only one now in existence that accords to true physical principles.
Agor wrote:DT pg 252 : To Those Who Do Not Believe. The mechanic maintains that Perpetual Motion has hitherto, from known principles of Statics, been considered impossible. .. snip ..
Your most obedient servant,
Lotharius Zumbach de Koesfeld,
Doctor of Medicine and Professor of Mathematics.
I think Koesfeld is referring to simple Mechanics as Statics i.e. Archimedes Law of Levers.
And fwiw in a very long letter starting Pg 253 by the undersigned the author goes to great lengths to describe Cornelius Drebbel and his machines. Since this letter was included in DT it proves that B. was aware of Drebbel 100 years earlier.
Valentinus Bögehold
L.S. Professor of History &
Rhetoric in the illustrious
Cassel, 26th October 1719
Caroline College.
Which reinforces the proposition that B's. mechanics are true physical principles and were unique and never before seen, and not those used by the likes of Drebbel and other trifles as described by Bogehold. Because in the same book B. says this ..
"You will, oh paragon of virtue, be unable to show me printed evidence that a work of art of this nature ever existed in the world before. Therefore, my machine is the only one now in existence that accords to true physical principles"
Static, what is it used for ?
it is used for construction of buildings in that way that the building is not collapsing.
Engineers do with their calculation asure that a building will not collaps.
But Bessler want exactly this, a fall over construction.
We look at the engineers again, they make sure, that the building has a solid stand.
But Bessler want this, a moving ground, an instable stand.
A movable ground is the inside of a Hamster cage, the ground is abel to move.
The ground can therefore move in both directions, needed for the bi-directional wheel.
The hamster cage can therefore turn left or right.
A solid stand in the hamster cage you only will have when the weight above is vertical to the axle of the Hamster cage.
Any move of the Hamster cage will cause the weight above off center.
The internal weight will fall to the downgoing side.
It will not hurt any physic law, the ground is moving, because the Hamster cage is turning.
As basic construction you can put stick vertical in a Hamster cage.
How many degrees must you turn the Hamster cage until the stick will fall over ?
The next step is to repeat this fall again and again.
Therefore you need the connectedness principle.
