Hello. As I have mentioned before I have "infiltrated" som RC groups to see if they follow the code "regime" I found in Besslers writings and that I found was applied before and after him.
The basic idea is that Gematria and Geometry is hidden in plain sight, and has "always" been.
When I have time I will post about Saturn, Mars and Jupiter, the invisible "tool" in his drawings and how this method leads the the first discovery of a mechanism/part/function, then I will show a little of how Bessler points us to Squaring of the Circle. I would like to show how it seems he want to show us a special tool (invisible to the naked eye..iow in form of a "code"). As his second portrait text say:
A tool is perfect (vollendet) when it's neither praised nor seen (sehendet)
Attached is a facebook feed example from the closed group "Council of Masons, Rosicrucians and O.T.O."
Some letters and values related to old "English" Gematria seems to match those observed in Besslers books. And those values seems to match numbers seen in Masonic art and in Pythagorean geometry. And even figures found in Bessler's birthday-card to Karl, and in Shakespeares 1st folio.
The attached is just an example to show how such a tradition could possibly live on, hitherto undetected by outsiders.. And if and when the method is accepted it can be used to confirm the use and location of special geometric figures, for example in Besslers work. And it can then be used to sort out the reason for this or that in Besslers books/MT etc.
OES = Order of the Eastern Star O+E+S = 37
I am also pretty sure that this is also why King James (from King James Bible) was written Iames as i+a+m+e+s = 37 (i = 1 if we follow the notations of MT.)
Bessler knew any secret writing for sure, and royal secrecy and printing..for sure. If, so if King Iames got his Pythagorean/Masonic "praise" on the King Iames Bible, then it would also be well in place for Bessler to put one in the Birthday card to his patron Karl !! (IMO).
It has been a long road, but a fun one, but I'm pretty sure I now also can tell what the basic principles of Besslers mechanical secret was and how a set of codes and geometric routines can outline a hidden symbol, geometric figure or a single simple mechanism.
Until then..
Best
ØR
Moden social media Rosicrucianism versus Bessler writings
www.orffyreuscodes.com
re: Moden social media Rosicrucianism versus Bessler writing
Very nice Oystein .. looking forward to it.
Bout time someone had a smoking gun !
HI ,
No need to infiltrate the Free Masons online , just infiltrate Trevor's topic , much more mysteries and secrets .
I myself keep secrets hidden deep , very deep .
Since you figured it out I'll take a wild stab at what I think the answer is.It has been a long road, but a fun one, but I'm pretty sure I now also can tell what the basic principles of Besslers mechanical secret was and how a set of codes and geometric routines can outline a hidden symbol, geometric figure or a single simple mechanism.
Until then..
I think the overarching principle is over under or out of balance.
Given different mechanical apparatuses can behave the same way I suppose a mechanism
is irrelevant. It is possible the only thing important is the motion or one motion relative to
another.
Finally, there could be different ways to cause an out of balance. I suspect there are at least
two different ways of doing it. One way requires a prime mover, the other way doesn't.
Some scoff at the idea of code. I never have had much of an opinion of them. You have
convinced me of their significance, Oystein. Why would a skilled artesian such as Bessler
make such blunderous wood cuts?
Also I just generally remember how to use one alphabet led you to a possible answer, but
the use of another (older?) alphabet led you to the right answer. Maybe Bessler was like
Rain Man.
Looking forward to your next post.
- Wubbly
The overarching principle has nothing to do with secret symbols, hidden geometry, or even physics. It is clearly dark magic, hexes and jinxes known only to Lord Voldemort.
Oystein is one smart fellar
a Romantic seeking to find the link to powering the planet
