George1
Post by George1 »
To WaltzCee.
You wrote: "No you're not." I can't understand this. Would you be so polite to explain it, if possible?
Sure George. I have no problem helping a dolt like you out.
What it means is I'm going to cause you to bleed profusely from your backside with half my
pecker tied behind my back.
scott wrote:George1, please stop spamming the board with the same post.
Thanks,
Scott
Re: re: IS THIS A REACTIONLESS DRIVE OR A PERPETUAL MOTION M
George1 wrote:Ok. I am stopping. Please excuse me.
George
George1
Post by George1 »
To WaltzCee.
Ok, I understand. But I am really surprised that you are so angry with me because of my short (usually two-lines) posts? Is this such an unfоrgivable crime?
George1
Post by George1 »
Here is an interesting rotational device. Please look at the three links below.
https://www.youtube.com/watch?v=eeZXNo4 ... monHoworus
https://youtu.be/vROdVsU_K80?t=65
https://overunity.com/18599/water-inertial-drive/
Seems to be interesting. What is your opinion?
PeterAX
Post by PeterAX »
A member of another OU forum states: "Sit in an office chair, keep your back straight, swing two masses in front of you in opposite direction. You will be pulled as if someone pushed you. Do it on water, ice, oil or free space, same effect." Is this possible or not? What is your opinion?
PeterAX
Post by PeterAX »
We tried to do the office chair experiment, but we failed. May be we did not do the things in the proper manner. Keep trying. But as if some theoretical calculations have to be done.
MrTim
Post by MrTim »
Instead of using a spring to hold the block to the ramp, I suggest using glue. It is a much more simple solution. Besides, if the lower end of the spring comes loose, the block is going to shoot off into the air... ;-)
PeterAX
Post by PeterAX »
To MrTim.
Hi there,
We are preparing now the simulation/animation presentation of our zigzag principle. It will be ready in the nearest future. But it takes time. It is not easy. Please be patient.
PeterAX
Post by PeterAX »
A member of our team, who is an expert in theoretical and applied mechanics, started writing formulas related to the office chair experiment. Well, the mathematics behind this rotational phenomenon is quite sophisticated. It will take some time to get some correct initial theoretical results.
Is this additional member of your team also named George?
No...George is busy elsewhere at the moment.
PeterAX
Post by PeterAX »
To Tarsier79.
Hi there,
Always glad to see your posts!:)
PeterAX
Post by PeterAX »
A colleague from another OU forum suggests three additional links, which as if could be helpful for understanding of the reactionless drive rotational principle. These three links are given below.
https://www.yumpu.com/de/document/read/ ... echnik-pdf
http://www.borderlands.de/net_pdf/NET0904S25-30.pdf
http://www.evert.de/ap0604.htm
But the texts of the three links above are written in German. Does anybody here in this forum speak German?
Unfortunately this concepts don't work as they are described.
I have build such type of models years ago.
Mr. Steins theoretical description is very good as a basic, but it does not cover the positive feedback loop.
Also the Wuerth machine, it works with the resonance principle in the gravity field.
It is an egging transportation of mass up and down with different speed against, with gravity.
His problem is the sysnchronisation to find correct natural frequency.
Have a look to http://alt.kuenstler-energie.de/
and there Drehmomentspeicher .
Such things are working because they have an technical construction error,
and experts does not build such a device.
If you like to buy the models feel free to contact me. I have extended the latest model by additional free moving masses.
