Thx Machine II
re: Thx Machine II
https://youtu.be/_XCLLqe6A-s
Some defects in the video, but hey...
Could a pendulum do better than a cam?
A++
A++
re: Thx Machine II
re: Thx Machine II
re: Thx Machine II
Hi thx4 ,
WOW ! , - really nice work .
Its pretty hard to keep me up at night these days but your pendulum version (https://youtu.be/zgQ1pPS8sxM) might trigger some good dreams ! : )
That looks pretty close to a small amount of "overunity" in view of the inescapable friction in the setup .
Very impressive !
Very impressive !
re: Thx Machine II
Hi thx4,
very impressive work but you know it will not work this way.
What is needed is a 2 stage oscillation, a parasitic oscillation.
You can modify this easily.
In the middle part you can fasten some pendulums as shown in the picture,
This will allow you the 2 stage oscillation.
You still have to modify the rope length of the pendulum so that the swinging is synchronized.
The length of the rope has an huge effect.
Test it, and you will see the result.
Good luck !!
Good luck !!
re: Thx Machine II
@agor95 Thanks, I'm glad. :)
@Georg,
Small problem with the balancing weights, I don't doubt that you can do it but at home, it doesn't work for X reasons...
https://youtu.be/KQHrXeO8x7o
https://youtu.be/yZktVYKrjK4
I move on to something else while waiting for better. :)
What's next:
1) Continue to lift the small 12 h mass...
2) You have to lift the small weight around 10h or 11h, it weighs 50 grams and when you have lifted it in a certain way, you erase 50 grams on one side and "it's won". you must not lift it as we do, the support point costs us too much, you have to lift it "on the big nut side of the weight", that is to say outside the big wheel, it's more complicated, but I may have an idea.
A++
@Georg,
What's next:
A++
re: Thx Machine II
Hi thx4
Having quality development is good to see.
It does allow the known issues to be reviewed.
As we know rotational energy is being used to lift the weights back to their original position.
Also we know changing direction of a masses uses up energy.
Notice. If you lock all the weights in the radial position then
the main wheel will acted like a fly wheel.
When you unlock the weights the wheel will slow down quicker.
The good news is when we look at the fundamental cause one can look at revering the cause.
A++
A++
re: Thx Machine II
Hi agor95,
I am working on a solution, I hope it will be the right one. :)
A++
A++
re: Thx Machine II
We look forward to your solution.
It is best not to look for a right solution, but an improvement on a current solution.
Right or wrong is not a good evolutionary path.
Therefore seeing how the new solution improves the first is useful.
A++
A++
re: Thx Machine II
Improve a current solution? Precisely what the hell is that, a current solution?
Presently most members of the animal kingdom discharge a substance known to the US
government to be bad, nasty and in need of eradication from the atmosphere.
I wonder 2 things.Biden's climate envoy John Kerry says we need to 'remove carbon dioxide from the
air' and criticizes Trump for leaving the Paris climate deal without 'facts or science'
- How could life ever have evolve when the animal half subsists off the
waste of the plant half & likewise photosynthesis requiring animal waste?
Who put these people in charge?
re: Thx Machine II
re: Thx Machine II
re: Thx Machine II
alcohol is a friend who wants to hurt you. lol
A++
A++
re: Thx Machine II
Hi thx4
I am away form today. So to get things back on track 'in the animal kingdom'.
Using a flywheel device as out base system. We can test for how long it rotates for a given input of energy. In your case to have included an extra inertial geared wheel.
Then replace with the weights radially fix and test again. You get air resistance of cause.
Next allow movement of the weight. You are using energy from the rotating wheel to move the weights. So it slows down even more. That is fine for it all part of a learning curve.
We all appreciate an acceleration is a result of a force of energy; be taken from it?
Well as we know if you take you also have to give back.
So what about swinging the weights in your device down and around instead of just up?
à tout à l'heure.
à tout à l'heure.
