The most important thing Bessler revealed is the existence of “the prime mover�. Why not talk about that?
re: The most important thing Bessler revealed is the existen
@Waltz: Your cry for additional details is received and noted.
you are such a desperate pathetic soul.
It would be a mistake to use yourselves to judge me by.
Raj wrote:
This start energy can be transformed in a torque of a wheel.
I will give you an example with fuel.
Fuel is an energy storage, being in a tank standing on the ground it does not move. So the fuel is not the prime mover.
if you put this fuel as a mass to the wheel, it is also not a prime mover.
It will be only a prime mover if you put the mass on the wheel with the correct angle.
Only then the wheel will begin to turn.
So you have 2 possibilities..
the mass has an offset to the center of gravity and a potential energy.
in other words you have stopped the wheel, when you remove the stopper the wheel will start to rotate, the wheel rotating is self starting.
The second condition is you have mass above the turning point in the form of potential energy.
In this case you need the action, starting with a push/pull to get an offset to the center of gravity, to let the wheel start the rotation.
The prime mover is connected inside of the wheel with the wheel and is the driver of the wheel.
But not as you think, the prime mover is pulsating.
The prime mover has already energy, movable energy,Would it been placed inside the wheel?
If yes, was it connected physically with the whee?
If yes, no way it could have move before the wheel, and therefore, could not have been the prime mover.
axel wrote:
I don't want to come into conflict with your discovery
If your discovery is not driven by a parasitic oscillation, then it will be different to mine, and I will go on.
My question is how long should I wait to reveal more information, or can I go on ?@Waltz: Your cry for additional details is received and noted.
@Raj and Georg.
Out of courtesy I will give you this: the prime mover I have discovered is not pulsating or oscillating.
Hi Axel,
thanks for your answer, then your principle is different to mine.
I will prepare a picture for ovyyus
because he asked
To achieve this amplification the pendulum must swing and the rope must be pulled and released periodically. That is basic physic.
In the right picture we set the system under stress by gravity.
That corresponds to Bessler's words, the bow spans and also to
the weights act in pairs, one is arranging the other.
Now you have a pump frequence, driven from gravity.
There are some boundary conditions.
The mass M1 must swing and M2 must be less than M1.
That is a parasitic oscillation, a two stage oscillator.
You have 2 floating, oscillating loads.
because he asked
In the left picture you will see how an amplified amplitude will be managed.Georg, where is the demonstration of two self oscillating pendulums?
A picture is not a demonstration.
It is funny how you say that like it is a fact, rather than a personal theory.
An apple is not an orange.
I will demonstrate this apple by depicting an orange.
http://www.besslerwheel.com/forum/files ... as_356.jpg
The secret of the prime mover is hidden in the plain sight of . . .
