Great finding iacob alex,
Here you can see what happens if you have a moveable axle.
Its about 18:19 in the video. And it is a parasitic oscillation.
Timing of forces !!
https://www.youtube.com/watch?v=MPNm0Ed83j4
Puzzle connections...
re: Puzzle connections...
Hello Georg,
I exchange a few emails with Igor, and I confirm that nothing works. lol.
There are at least a hundred videos on the net that demonstrate very well
that the oscillation goes from one balance to another and vice versa, and that's all, after a few minutes for the most balanced everything stops for lack of fuel. There is no anomaly in the basic physics in this example.
So I don't see the point of such a system apart from wasting time or you show us a demonstration without appeal, but I think we will wait a long time.
For the moment we are in the waiting.
A++
A++
Hi thx4,
I am aware that Igors construction is a non runner.
Nevertheless he made a construction where he can change nearly all paramerters for the oscillation.
The difference what Igor did to my construction is that I use a third oscillation, force.
This change changes the type of oscillation from an parametric oscillation to an
I have discribed that already to you in your thread.
An wave is impressed by an other wave.
An oscillation is carrying an additional oscillation to get an amplified summed up oscillation.
I can't tell you not more how this is managed in my Bessler wheel construction because my patent is in the status pending.
So I am also in the status waiting, waiting for the patent office.
@Georg
I didn't know you had filed a patent, so yes, that makes sense (smile).
I'm happy for you, and I thank you for putting us on the (wide) track. :)
Greetings
A++
Greetings
A++
Re: Puzzle connections...
…..if we take a look at an very old/Middle Ages simplified “wheel” (lever with a single variable arm )
https://www.youtube.com/watch?v=MPNm0Ed83j4 (the “classic”variable hinged arm concept )
…..or we remind a not so old 2003 forum suggestion , regarding a possible self running gravity powered device, due to a continuous long arm-short arm unbalance ( lever with a single mass spring variable arm ) as :
https://besslerwheel.com/wwwboard/messages/657.html ( mass spring/variable arm pendulum concept )
…..our puzzle/polynomial topic , can be “gravity continuous unbalanced lever” , on the same side of the fulcrum , as :
https://www.besslerwheel.com/forum/sear ... ced+lever+
To simplify , need we …to play “ballet”/pirouerre with gravity and rotational inertia ( see “The physics of the *hardest move* in ballet -Arleen Sugano” ) ?!
Al_ex
Al_ex
…..playing ( liquid state…) waves in a swinging box/“viscous waves in swinging box” / , at:
https://youtu.be/ZC235PD7xiE?si=_oy3mneMhxzz6ckZ
…..then playing (solid state…) waves in a swinging tube/“box” with an inner “spring-sliding mass-spring” mass equivalet :
https://www.britannica.com/science/mech ... cillations
All in all…it looks as a beam/rigid rod/lever…but can develop senzitive effects face to gravity and rotational inertia.
Can we evolve this spring leverage beam into a self running one , due to a possible continuous gravity unbalance on the same side of the fulcrum and the”addition” of rotational inertia “effects”…? !
Al_ex
Al_ex
