MrTim
Post by MrTim »
I am asking you (PERSONALLY!) my question for the 11th time: Is Prof. S. L. Srivastava's solution correct? Yes or no? Only one word -- either "yes" or "no"!
I am waiting for your PERSONAL(!) answer for the 11th time. Only one word -- either "yes" or "no"!
You have been answered with NO. At least twice.
Repeating yourself will not change that answer.
You are not worthy of any further response.
Ciao! ;-)
PeterAX
Post by PeterAX »
To MrTim.
If your answer is NO, then you simply reject the basic axioms of electric engineering and electrochemistry. And therefore you are simply a stubborn ignoramus. How to discuss serious science with an ignoramus?
Re: l'm drawing a blank
this is a test
I just love a dumpster fire.
PeterAX
Post by PeterAX »
To WaltzCee.
My tremendous respect to your fantastic scientific qualification!:) You must be awarded twice by the Swedish Academy of Sciences! You must be awarded two (and even three!) Nobel Prizes in a row!:)
george, do you feel rewarded that your stolen, half baked, incorrectly applied ideas and incomplete circular logic have no traction here? No one wants to engage with your rudeness and arrogant superiority complex. This bot routine is worse than the amateur Q-Basic AI programs of the mid 80s. Your programmer needs to try again.
I give him an F.
PeterAX
Post by PeterAX »
To Tarsier79.
Hi Nobel prize winner number 3,
You missed me so much!:) Did you take your medicine this morning?:) No? Take it immediately! Double dose!:)
Waiting for your fresh technology ideas!:)
PeterAX
Post by PeterAX »
The text below is a copy of our post of April 13, 2021, 5:32 pm. (The text below has been published many times in this forum topic.)
Have a look again at the book "Solved Problems in Physics", 2004, Volume 2, p. 876, solved problem 12.97. The author of this book is Prof. S. L. Srivastava (Ph.D.)
The same book can be found at the link https://books.google.bg/books?id=rrKFzL ... 22&f=false
For your convenience I am giving below the text of the problem and its solution.
12.97. In the electrolysis of sulphuric acid solution, 100 mg of hydrogen is liberated in a period of 20 minutes. The resistance of the electrolyte is 0.5 Ohm. Calculate the power consumed. Electrochemical equivalent of hydrogen is 1.044 x 10 -8 kg/C.
SOLUTION.
Prof. S. L. Srivastava's solution is given below.
Prof. S. L. Srivastava's solution consists of two lines only.
LINE 1. Current through the electrolyte is given by I = (m)/(Z x t).
LINE 2. Power consumed = (I) x (I) x (R) = ((m)/(Z x t)) x ((m)/(Z x t)) x (R) = 31.86 W.
Prof. S. L. Srivastava stops here his calculations.
(The related solution's set of equations is not given here in order to save time and space. This set of equations however can be found in the book or in the link above.)
WE DEVELOPED FURTHER PROF. SRIVASTAVA'S SOLVED PROBLEM IN A NON-STANDARD MANNER.
OUR FURTHER DEVELOPMENT OF PROF. SRIVASTAVA'S SOLVED PROBLEM LED TO COP > 1.
HERE IS THE ESSENCE OF OUR APPROACH.
1) Let us calculate the inlet energy, that is, inlet energy = (31.86 W) x (1200 s) = 38232 Ws = 38232 J.
2) The Joule's heat, generated in the process of electrolysis is given by
Q = (I) x (I) x (R) x (t) = ((m)/(Z x t)) x ((m)/(Z x t)) x (R) x (t) = (31.86 W) x (1200 s) = 38232 Ws = 38232 J = outlet energy 1.
3) HHV of hydrogen is 142 000 000 J/kg. Therefore the heat H, generated by burning/exploding of 0.0001 kg of hydrogen, is given by
H = (HHV) x (m) = (142 000 000) x (0.0001) = 14200 J = outlet energy 2,
where
m = mass of the released hydrogen
HHV = higher heating value oh hydrogen
4) Therefore we can write down the equalities:
4A) outlet energy 1 + outlet energy 2 = 38232 J + 14200 J = 52432 J
4B) inlet energy = 38232 J.
5) Therefore COP is given by
COP = 52432 J/38232 J = 1.37 <=> COP = 1.37 <=> COP > 1.
IMPORTANT NOTE. Constant pure water and cooling agent supply could keep constant the electrolyte's temperature, heat exchange, mass and ohmic resistance, respectively. Besides 0.0001 kg of hydrogen (and the related amount of the already split pure water) is small enough and can be neglected as a factor influencing the electrolyte's temperature, mass and ohmic resisitance.
And one more interesting fact.
Literally the same solved problem can be found in an old Russian (still from the Soviet times) book "&#1057;&#1073;&#1086;&#1088;&#1085;&#1080;&#1082; &#1079;&#1072;&#1076;&#1072;&#1095; &#1080; &#1074;&#1086;&#1087;&#1088;&#1086;&#1089;&#1086;&#1074; &#1087;&#1086; &#1092;&#1080;&#1079;&#1080;&#1082;&#1077;", 1986, p. 130, solved example problem 71. The authors of this book are &#1056;. &#1040;. &#1043;&#1083;&#1072;&#1076;&#1082;&#1086;&#1074;&#1072; and &#1053;. &#1048;. &#1050;&#1091;&#1090;&#1080;&#1083;&#1086;&#1074;&#1089;&#1082;&#1072;&#1103;. In the Russian version the data is a little different, that is, time is 25 minutes, the amount of generated hydrogen is 150 mg, Ohmic resisitance is 0.4 Ohm and the calculated power is 37 W.
Russians also stopped their calculations at 37 W.
Our further development of the Russian version led to the same COP = 1.37, that is, we have again the same COP > 1.
IMPORTANT NOTE. The text above must be evaluated (SOLELY AND ONLY!) by highly qualified experts (Ph.D.) in electric engineering. Otherwise nothing will come out of it.
Please read carefully and thoroughly the text above.
"Siri, Shut Down"
Not sure if it is tuned to my Australian accent.
PeterAX
Post by PeterAX »
To Tarsier79.
Hi there,
Hi dear colleague:),
1) Firstly, let me remind again that it is a great pleasure for me to correspond with you!:) You are simply a genius and all members of this forum can clearly see this simple obvious fact!:)
2) Secondly, it is also obvious that you have a lot of free time and you don't know how to use it. Why don't you waste some time and sit down and read carefully and thoroughly some beginner's manual in physics? The latter is a very interesting field of knowledge and you will feel a real pleasure while reading this physics manual. (Not pressing, only suggesting.:)
Regards,:)
PeterAX
Post by PeterAX »
COP = 1.37 <=> COP > 1. Still no comments? No one here in this forum wants to save some small amount of electric energy? :)
PeterAX
Post by PeterAX »
COP = 1.37 <=> COP > 1. Still no positive comments? :)
Still no proof. Still parroting someone else's work. Still working with flawed assumptions.
It is positively a waste of everyone's time. Please invade another forum with your not.
PeterAX
Post by PeterAX »
To Tarsier79.
Where do you see parroting in the text below, you old cheater? You have never read my posts! Read carefully the text below!
SOLUTION.
where
Where exactly in the text above do you see any parroting and/or stealing of ideas, you old rogue?
You are simply a professional uneducated hater and you are talking only because of talking itself! Or you are simply a paid agent of the official science mafia, who tries to manipulate the audience in a clumsy and unskillful manner! In any case you are simply an unworthy person! Shame on you!
I am asking my question again: Where exactly in the text above do you see any parroting and/or stealing of ideas?
this is a test
PeterAX
Post by PeterAX »
To WaltzCee.
Hi Nobel prize winner number 3,:)
Perfect! Nice comment!:) It seems to me that in the nearest future we (you and me) will become great friends, dear colleague!:)
Regards,:)
