It's Me
It's Me
This is an awkward situation because my work might help John Collins granddaughter to get her life back.
The video shows Bessler's basic principle;
Around the firmly placed horizontal axis is a rotating disc (low or narrow cylinder) which resembles a grindstone. This disc can be called the principle piece of my machine. Accordingly, this wheel consists of an external wheel (or drum) for raising weights which is covered with stretched linen.
https://besslerwheel.com/writings/das_triumphans.html
I have already redesigned the wheel. https://www.youtube.com/watch?v=MtlhoIOkRkA&t=20s. It should work. And if the modifications that I'll be pursuing do work, then maybe both myself and John's granddaughter can have a life again?
With the redesign, I will be increasing the amount of torque.
If you do not understand what Bessler wrote, the frame of the wheel is a grindstone. The external wheel/drum is the retraction disc.
And as I did mention, doctors might not want to do biopsies look for abnormal tissue or for damaged cells. It's a credibility issue. And the only reason I am saying anything is because I do know what she is going through.
edited to correct stuff. And to add, use closed captioning. I have a significant hearing loss and really do hate making videos.
re: It's Me
Hello
I look forward in watching your progress.
I gave 'das_triumphans.' a read and apart of the wheel dimensional information.
What looked interesting to me was the part 'drive on the axis of their vortices loads that are vertically applied.
All the Best
All the Best
re: It's Me
Lol, sock puppet number.....
Re: re: It's Me
agor95 wrote:Hello
All the Best
Thank You. If people consider the video, a pendulum swinging from its axis cannot rotate around the axis of a wheel. It is not possible to shift the swing of a pendulum. And yet I will say that is what Bessler did.
re: It's Me
Hello James
The u*tube is labeled a success and in the comment section you told Sofia
it was a success.
Also, what do you mean by
it was a success.
- How do you define success?
- shift the swing of a pendulum.
Walt, can you explain what you saw? You can't. The demonstration was very successful. In my opinion, it allowed me to know what Bessler knew. How to conserve energy.
When you say
The bob (weight) swinging from the fulcrum rotates around the axle of a wheel. Can you shift the swing of a pendulum? That requires a secondary axis. No one has done that, that we know of.
When you say
Re: re: It's Me
WaltzCee wrote:Hello James
it was a success.
And do you care about how much John Collins' granddaughter suffers? It is a simple question. I suffer and she suffers. And Bessler's wheel might help people like us. Is that simple enough for you? I don't like John or you guys but I really have no need to know what his granddaughter is going through. I've already been there. I really don't care for someone else to go through it. I am that much of an asshole.
p.s., if I can help people like her to get their life back or what is left of it, I will. There are some things that you do not want people to know. I live there.
re: It's Me
@Walt,
Check out the gals from Cleveland, Ohio. Raped over many years. How do you get your life back? With John Collins' granddaughter, it is the same thing. How does she get her life back? She doesn't. She will have to live the rest of her life with the pain she lived through.
There is nothing that will take that away from her. Every waking day she will know what she suffered. Just nothing to be considered. Yet to you it is a joke. I'd love to saw your leg off. That is not pain.And if I get my wish, I will do that to you. That simply isn't very painful.
If that bothers you, you are weak. But we all live for something, right? Are you weak?
edited to add, cutting your leg off ends. That is showing mercy. What happens when it doesn't end? And then we find this forum.
re: It's Me
Hi James (I can't remember your actual name due to the amount of pseudonyms you have had over the time).
Firstly, please keep your posts on topic and don't dwell in the past. You are a talented builder, and this forum is better for that talent.
I built something sort of based on the same principle, but didn't use sliding weights. This build was the first build I could see conservation of gravity in real time. You may not see or understand the linked principles:
https://www.besslerwheel.com/forum/view ... 9800#89800
Anyway, I look forward to seeing more of your builds.
@ Tarsier, a respected forum member said I killed someone. A forum owner in Germany (Stephen Hartmann of overunity.com and overunity.de) made me aware of this. If I am able to get my build working in the next month or 2, then I should be able to have the surgery that I need. I'll probably do a show at Utrecht University with 4 or 5 wheels that I'll need to build myself. The builds that I've done so far is without having a wood shop to work in.
Just watch the video, it does rotate quite well and I know how to increase the torque. So I should be able to get it working. It will take me about another 2 weeks to do the modifications. And if that test shows it accelerates more quickly then there's no reason it shouldn't work. And why I posted in here was to make John Collins aware that if they have done biopsies where Amy is having problems, with a tumor, is it malignant or benign? Have to look at it under a microscope. And if Amy has microscopic scarring causing her problems, then only looking at the tissue under a microscope would allow doctors to see that type of damage. And if doctors haven't don that yet, they need to do it. Taking a sample of her tissue is a pretty basic medical procedure.
And if I am right, then she might be able to teach again. If so, then I think she might like me.
Re: re: It's Me
Tarsier79 wrote:Hi James (I can't remember your actual name due to the amount of pseudonyms you have had over the time).
My real name is Mark James Lindgaard; https://www.presspubs.com/lindgaard-sen ... 14bd5.html
That is what this thread IN MY OPINION is about;
https://besslerwheel.com/forum/viewtopic.php?t=4656
Stefan Hartmann of Berlin, Germany hopes I get over having killed my friend. Feel better? But in 2009 I was 48 years old and not 22. This is what using many names is about and why I was kicked out of this forum in my opinion.
You guys have a link to one of my YouTube videos. Probably at the end of the month I'll probably upload the next test. And if that test is successful then there's no reason why it wouldn't work. What you guys will need to understand is that you understand none of the engineering behind the design. But I will send John a link. Maybe his granddaughter will like it as well as John. And who knows, maybe Bessler's wheel will help her to get her life back. When a person is able to have a life, it's easier to leave the garbage behind. Myself, I am 100% handicapped and that does make it very difficult to get work done.
edited to add; this video https://www. ... NGw46sG6EA is from November, 2015. Close to 6 years ago. Unfortunately a working wheel wasn't good enough for some people which is what the goal is supposed to be. Pretty doesn't matter if it doesn't work. And yet what I am now doing is what I should have been allowed to do 6 years ago. And I am working through a serious disability. That's why it takes me longer to do the same work a healthy person could do much more quickly.
And if you look at the first video I posted, I rotated the disc 90º and got excellent retraction. What I'll be doing next should be more efficient. And if you notice, I'm not doing a "pretty" build. I need surgery so hopefully I can be healthy again. Kind of why I'd like to see Amy healthy again. I do understand what she's going through because of how bad my own situation has been. There is nothing easy about working through significant trauma and pain.
edited to add; an animation I made of what I built. The video is as long as the song
https://youtu.be/QuBs2csXOfo
re: It's Me
I do understand it, but I don't know how you plan to release the rope.
I also understand that it will not self perpetuate. It does not for the same reason this doesn't:
https://www.youtube.com/watch?v=bmjBTSdCiVg
re: It's Me
Tarsier, the new ABHammer! Better you than me my friend! Lol
