The solution
Re: The solution
agor95 wrote: Wed Feb 02, 2022 2:53 pm
Senax wrote: Wed Feb 02, 2022 10:45 am Even though I tick the "remember me" box I find that I am required to log in every time I want to reply to a post.
Is this a bug -- or a feature. :-)
I find using the 'remember me' of the browser is better than the 'remember me' of the site.
I find in Firefox when you login to a site, you can save the id and password.
This is a good way to forget your password so record it in a secure way.
Good Luck
Senax
Re: The solution
Post by Senax »
Good Luck
Thanks. I have Chrome. I've contacted Scott to see if he can sort it cos it's damned annoying. :-(
Lamb Gyros
with chips. Soda extra.
Senax wrote: Sun Jan 30, 2022 7:42 pm You realise the implications if I'm right don't you.
For one thing, once it is taken seriously the military will arrest me and probably disappear you.
I'm not joking.
Well, I'll tell you this much.
The energy does not come from Gravity.
This has been pretty obvious from the beginning.
So where does it come from then?
It comes from the rotational energy of the earth, from the differential action of a rotating mass going up and a rotating mass going down.
I had all the pieces of the puzzle. I even had experimental demonstrations of parts.
I suppose the final piece was connecting up to Prof. Eric lifting that heavy gyro.
try and get this back on topic. Curious idea.
Re: The solution
No need to remember your login details , to use the "i forgot my password" link ,you need to remember your email (if i remember correct).
Senax
Re: The solution
Post by Senax »
I seem to have found the answer to my problem.
If I log in right from the beginning then I don't have to log in to make a post.
Thanks for your help.
Re: The solution
Senax wrote: Sat Feb 05, 2022 10:32 pm I seem to have found the answer to my problem.
The 'Foe' filter only works after you login. So to reduce excess reading login first.
Ersatz regards
Senax
Re: The solution
Post by Senax »
Fletcher wrote: Sun Jan 30, 2022 8:16 pm Welcome back Grimer .. I was starting to wonder.
With good reason. I had 3 weeks of Kung Flu in December -
without the jab, too. :-)
But as Violet Elizabeth Bott use to say:
"I'm alright now."
Senax
Re: The solution
Post by Senax »
This .gif show two pendulums released from a high angle.
The blue pendulum is released first and the red pendulum is released one second later.
I had a better .gif with a host of pendulums released from an angle of one degree but it seems to have been lost in the forum change over. I'll have to wait for my programmer to come home on vacation from his chem. engineering course at Birmingham Uni.
If any forum member wants to have a go, be my guest. :-)
Unfortunately I can't give you Edwin's code because he won't release it to me. :-)
However, you can see from the .gif that the pendulums are coming together at high angles and moving apart at low angles. If the pendulums are connected together by springs then the springs will be compressed at high angles and stretched at low angles.
This difference in strain energy is symmetrical so not any help in getting the pendulums over the top.
I believe I have found a way of transforming this symmetrical energy difference into an asymmetrical difference which I will explain in subsequent posts.
Re: The solution
I think your ability to post images has been revoked.
https://drive.google.com/uc?export=view ... HQtpuwiGQT
google wants you to sign in.
Senax
Re: The solution
Post by Senax »
WaltzCee wrote: Fri Feb 11, 2022 7:20 am I think your ability to post images has been revoked.
Thanks for pointing out that no one but me can see it.
I think I know the problem. I'll try to sort it.
Re: The solution
right click on the dead "image" icon then click "load image"
Senax
Re: The solution
Post by Senax »
Senax
Re: The solution
Post by Senax »
Has that solved it?
Re: The solution
It has Frank.
This is no new idea. Energies abound in God's creation, there for any to pick.
  • Seed time and harvest.
Re: The solution
Have you squared the circle yet, Frank?
