The solution
Re: The solution
I find using the 'remember me' of the browser is better than the 'remember me' of the site.
I find in Firefox when you login to a site, you can save the id and password.
This is a good way to forget your password so record it in a secure way.
Good Luck
Thanks. I have Chrome. I've contacted Scott to see if he can sort it cos it's damned annoying. :-(
Lamb Gyros
with chips. Soda extra.
try and get this back on topic. Curious idea.Senax wrote: ↑Sun Jan 30, 2022 7:42 pm You realise the implications if I'm right don't you.
For one thing, once it is taken seriously the military will arrest me and probably disappear you.
I'm not joking.
Well, I'll tell you this much.
The energy does not come from Gravity. This has been pretty obvious from the beginning.
So where does it come from then?
It comes from the rotational energy of the earth, from the differential action of a rotating mass going up and a rotating mass going down.
I had all the pieces of the puzzle. I even had experimental demonstrations of parts.
I suppose the final piece was connecting up to Prof. Eric lifting that heavy gyro.
Re: The solution
No need to remember your login details , to use the "i forgot my password" link ,you need to remember your email (if i remember correct).
Re: The solution
I seem to have found the answer to my problem.
If I log in right from the beginning then I don't have to log in to make a post.
Thanks for your help.
Re: The solution
The 'Foe' filter only works after you login. So to reduce excess reading login first.
Ersatz regards
Re: The solution
With good reason. I had 3 weeks of Kung Flu in December -
without the jab, too. :-)
But as Violet Elizabeth Bott use to say:
"I'm alright now."
Re: The solution
This .gif show two pendulums released from a high angle.
The blue pendulum is released first and the red pendulum is released one second later.
I had a better .gif with a host of pendulums released from an angle of one degree but it seems to have been lost in the forum change over. I'll have to wait for my programmer to come home on vacation from his chem. engineering course at Birmingham Uni.
If any forum member wants to have a go, be my guest. :-)
Unfortunately I can't give you Edwin's code because he won't release it to me. :-)
However, you can see from the .gif that the pendulums are coming together at high angles and moving apart at low angles. If the pendulums are connected together by springs then the springs will be compressed at high angles and stretched at low angles.
This difference in strain energy is symmetrical so not any help in getting the pendulums over the top.
I believe I have found a way of transforming this symmetrical energy difference into an asymmetrical difference which I will explain in subsequent posts.
Re: The solution
I think your ability to post images has been revoked.
https://drive.google.com/uc?export=view ... HQtpuwiGQT
google wants you to sign in.
Re: The solution
Thanks for pointing out that no one but me can see it.WaltzCee wrote: ↑Fri Feb 11, 2022 7:20 am I think your ability to post images has been revoked.
I think I know the problem. I'll try to sort it.
Re: The solution
Re: The solution
Has that solved it?
Re: The solution
It has Frank.
This is no new idea. Energies abound in God's creation, there for any to pick.
- Seed time and harvest.
Re: The solution
Have you squared the circle yet, Frank?
