Updates
Clim
Updates
Post by Clim »
I'm making John Collins and Scott Ellis aware of this as well. I might be able to demonstrate a working wheel this week.
Unfortunately people do not understand how a swinging weight can help to generate force. It's a magician's trick or
slight of hand.
[url]https://youtube . com/shorts/nRafzpQD7Ww?feature=share[/url] and [url]https://youtu . be/dYIDCXxcvOQ[/url]
It is a lot of work. And what would a working wheel allowed to be considered? Can this [url]https://overunity . com/19028/hmmm-can-a-hydrogen-fuel-cell-and-generator-be-enhanced/[/url] be used to allow for an economical means of seawater desalination?
Also a working wheel would help me to pursue an experiment that I've been wanting to see tried. This is my webpage
[url]https://climate-cycling . com/[/url] and the experiment is [url]https://climate-cycling . com/?page_id=33[/url]
And yet I consider the attacks against me to be in support of white supremacy because I am 1/2 Norwegian. Let's face it, my Father ran from Nazis for his life. So as a disabled Veteran who served Honorably in the U.S. Navy, why do I have to be afraid of "real" Americans for? I let this YouTuber
[url]https://www.youtube . com/watch?v=3zXnV_1Ftps&t=360s[/url] know that when Americans could've said we can work together, instead they said let's attack him. And improved seawater desalination could help many farmers. At lest life is good in Texas. They have heat in the winter and electricity for air conditioning in the summer. That's free market enterprise. Would they pay as much for water?
p.s., I was involved in the killing of 6 people. It wasn't my fault. What has been made known publicly about the incident.
[url]https://www.wearethemighty . com/mighty-history/uss-kitty-hawk/[/url] And as we all, serving in the military can result in someone dying. It's not called the Peace Corps. for a reason. And in the military for better or worse the unit shares credit.
p.s.s., when Australia had its bushfires in 2019/20 and then in 2021 Texas had its Big Freeze, those 2 events might be related. I'll simplify things for you guys.
The bushfires kept the hole in the ozone layer over Antarctica from occurring in their summer/fall. So gasses like SOx and NOx migrate north to the Arctic where they formed a hole in that ozone layer about 1 year later which coincides with Australia's summer/fall.
That would've shifted the polar jet stream south because the stratosphere was unusually cold over the Arctic. That allowed for the Arctic to warm. And
what are the odds that if someone takes the time to work at and learn something they can? And yet if things work out for me then those who attacked me supported what exactly?
And Walt, if Australia has more bushfires like those in 2019/20 which is likely, Texas could have another Big Freeze.
And with attacks against me, those are obvious. What isn't obvious is how a weight gets its force from swinging. In mathematics the inverse is always true.
A downward swinging weight generates force. When a weight is swinging upwards, its counter torque decreases at an exponential rate. If you consider trigonometry, distance from the axis of rotation while being equal does not allow for resistance or negative torque to be factored at a 1:1 ratio.
What has to be considered is the gravitational effect as a sin theta * 9.81 m/s. Basically a weight at bottom center if 1m * 1 kg is 9.81 nm. A weight 90º perpendicular to the axle and gravity is the same except for what trigonometry states. 90º = 1 while at bottom center represents 0. The weight at bottom center is basically having no mass until it starts rotating upward. If you get into physics and basically suborbital and orbital mechanics at a most basic level then you'll understand why.
Clim
Re: Updates
Post by Clim »
With the incident between the Russian submarine and the USS Kitty Hawk, I was assigned to 3MMR (main engine room).
Our fuel tank was ruptured and a boiler was shut down. I went on the watch following this. A ruptured fuel tank could have killed
everyone on watch in 6 seconds.
A water hammer can rupture a steam line that has over 1,200 psi of pressure at 986ºF/530º C. For the crew members who
were not assigned to 3MMR, this was an after thought. If you were assigned to that engine room, taking a boiler offline because
of seawater in the fuel is very serious. You simply do not take a boiler offline. That hurts military preparedness. That does come
first.
p.s., the phone talkers on board ship passed on and heard all information. What the media has made known is what officials have said.
With me, I really didn't care until my Mother sent me the front page of the Seattle Times. Then I thought "It really did happen".
p.s.s., if you've never seen a steam line being affected by a water hammer, it's like someone pointing a gun at your head with it cocked.
All it needs to do is to fire and then everyone is dead.
And Thankfully I am reminded of these things.
etc., Could you imagine going on watch and hearing 45 minutes ago we killed ourselves some Russians? When you go on watch at about 03:15
hours (3:15 am) you never expect to hear that. And it was "we" killed 6 Russians. And "we" also had to shut down one boiler because it wasn't safe to operate.
And to support rlortie and AB Hammer and their 50 years of experience together, between my parents and their 51 years of experience together they had 6 kids. rlortie and AB Hammer likewise should have kids to remember them by. Still, 50 years together is less than 51 like my parents. And they should be commended for thier love for each other.
Just an FYI, there are some thing some of us would like to forget. And as far as the Russian submarine goes, I really have no need to remember that.
It could've been much worse and while it wasn't, some people want to go there or places like it. I simply don't have that need.
Re: Updates
Clim
Re: Updates
Post by Clim »
Walt, you just proved white supremacy. When you consider AB Hammer https://www.ksla . com/story/37863650/an-arklatex-man-endures-a-series-of-unfortunate-events/
and then with the picture you showed of me, I think the difference is obvious but I use LSD? And 11 years ago he called me the world's ultimate fraud which orpheus . org and many people approved of. Really? Oops, both his mommy and daddy were "real" Americans.
And yet I've been banned for building while those who attack me have never been banned. That makes the purpose of this form suspect. It isn't to realize Bessler's work as advertised.
Clim
Re: Updates
Post by Clim »
I won't bother posting in here any more. AB Hammer is better than me. 190 lbs. vs 330 lbs., he's got it.
Who can make coffee for a guy in the morning? ab hammer and his friends. Who has no work to show?
What was it ab hammer said? Weebles wobble they don't fall down but in a wheel case they don't roll over.
And in a perpetual motion forum never banned but is very well respected. What is the real purpose of this
forum then? ab hammer can be trusted. Yet he said perpetual motion is impossible so why is he a trustworthy
person?
I even have a saved post of his where he said Bessler's Wheel should not revolve around me and I expect people to bow down before me.
And as ab hammer told me when I had cancer, some people have it worse than me and no one cares about me. Walt has proved that.
And in 2018 he was in the news showing people that living in a nice home and having a nice truck to drive is having it bad. And yet he is
revered. I might build one invention just to show ab hammer could've made a couple of hundred thousands of dollars working with me yet
he and his friends want my life ruined.
That is what's disturbing. It has nothing to do with making money but only about ruining the life of someone with severe complications from
cancer who isn't a pure American. Yep, some things are worth more than money.
p.s., what some people will find disturbing is when ab hammer told me I can't say cancer. When I had it I wanted to discuss things with people
who weren't like him. He told me I could not tell him no. And then in 2011 when he called me the world's ultimate fraud he said that when I said
cancer it was like I was punching him in the nose and then saying I wore glasses.
It is interesting how he was the victim when he said he would not work with me because he refuses to share information with anyone. And in that 2011 thread, rlortie actually said everything was his fault because he started it. rlortie and his arrache build group told me I was not allowed to build and that
they were helping me by forcing their will on me.
If I am successful it will be odd that those who had a no build policy they enforced were considered as highly credible.
Clim
Re: Updates
Post by Clim »
Even if what I'm building works, just to understand the basic idea could take someone 3 or 4 months to understand it.
Kind of why I have an issue with not having been allowed to explain it, discuss it, etc. while I've been working at it. And
then to consider the math, that would take more time. As for building it, another year or 2 to become familiar with the
woodworking.
Kind of why I'm confident about what I'm building now. The prototype worked but who wants to see a prototype.
And then if it works we'll be back to when Bessler was arrested for being a fraud like me while also not being ethnically
pure like me. And then he would've had a working wheel like me but he was the problem like me.
That'll only show that in 300 years nothing much has changed.
Re: Updates
Promise?
Clim
Re: Updates
Post by Clim »
Tarsier79 wrote: Sun Jun 19, 2022 2:50 am
Promise?
As you and your friends (not everyone in here is your friend) have shown Tarsier, all you know is to attack someone.
You really don't seem to understand math, engineering or science. What is it ab hammer said? I'll show you how to get
a wheel without doing any work? Am not sure why such an attitude is allowed. He gets more respect for that than I do
for building. This tends to make forum members like yourself Wagners. Because Bessler built it Wagner was out to ruin his
life. It is odd how a Wagner is credible in this forum. After all, I am the world's ultimate fraud, right? And yet ab hammer
has this work to show;
https://overunity.com/6474/ab-hammers-g ... keel-grid/
And yet I'm the fraud. And as anyone can see, I stayed out of ab hammer's thread yet he's in all of mine. As he said, he's
defending his credibility.
p.s., if Bessler's Wheel allows for using hydrogen fuel cell technology to desalinate seawater, ab hammer could've been a part of that if
he could've worked with a disabled Veteran who served in the U.S. armed forces and is 1/2 Norwegian. But that's not what he wants.
You know, to be known for doing something worthwhile. And here in the U.S., there is drought as well as aquifers west of the Mississippi
River going dry. Not your concern nor ab hammer's. It's like I let Kate's Ag know, when people could've worked with me instead they
chose to attack me. States like Montana, North and South Dakota as well as Wyoming might benefit from desalination. You know, so
farmers can grow crops. You should look at this link rather than post something meaningless. https://www.climate.gov/media/14568
And I might move to Australia. And while Tarsier won't like me I think most Australians will. After all, I might know science that
hasn't been done yet.
Clim
Re: Updates
Post by Clim »
I'll give a quick overview of seawater desalination. The hydrogen/fuel cell process is about 60% efficient.
Because of volume, a pressure head to generate electricity is possible. Then all of the electricity generated
by the membrane in the fuel cell and hydroelectric energy goes back into generating hydrogen which releases
2O (2 oxygen elements or 1 molecule which would be O2).
The deficit in current needed could then be supplied by an industrial build of Bessler's Wheel. Basically
something that might stand 4 stories tall and weigh over 100 tons. If that can happen then if desalinated seawater
can be processed for as little as 50 cents per 1,000 gallons of water then a solution to freshwater shortages might
be realized. And that would be a problem, right?
And then to pump the water inland, more Bessler Wheel motors could be built to supply the energy. Then the
question becomes how much will it cost to generate 1 kWh of electricity? That's 1,000 watts x 3,600 or 3.6 million
watts.
Clim
Re: Updates
Post by Clim »
A couple of pics of the stand and one of the wheel (it's a test fit) on its assembly jig.
https://photos.app.goo.gl/8rQ7vSoWUqQZd83TA
And it is a lot of work and it'll take me a while to finish assembling the spars. I think I
managed to finish making the last of the parts that I'll need this morning. The reason for the
new build is who would want to see the prototype?
p.s., now it should be finish the build and see if it works like the prototype suggested it will.
This only shows that research and development is necessary but never allowed.
Re: Updates
It won't work. The prototype video actually showed that it wont. If only I knew some method of writing down numbers or drawing diagrams to show why?
In spite of the way you treat people, I do feel sorry for you. You clearly aren't getting the help you need.
https://www.merriam-webster.com/
Definition of narcissistic personality disorder
: a personality disorder characterized especially by an exaggerated sense of self-importance, persistent need for admiration, lack of empathy for others, excessive pride in achievements, and snobbish, disdainful, or patronizing attitudes At its most extreme, snobbery can be a symptom of narcissistic personality disorder, a condition marked by grandiosity, a need for admiration, and a preoccupation with power and prestige.— Adelle Waldman Those with narcissistic personality disorder exaggerate their own importance, aided by success fantasies.— David G. Myers
https://www.mindsettherapyonline.com
The narcissist cannot take blame for things that have happened because that would require them to view themselves as individuals capable of making mistakes. Their beliefs of superiority and grandiosity would not support the narrative that they could be flawed in some way. Even when they are to blame for something, and the evidence is staring them in the face, they are incapable of accepting blame because this leads to feelings of shame and then narcissistic injury. When the narcissist begins to think that someone will blame them for an action, they go into self-preservation mode and will deflect all blame from themselves and onto someone else.
https://my.clevelandclinic.org
Long-term counseling is the primary treatment for NPD. It helps you gain greater insight into your problems and learn what changes you can make to:
Relate to others in a positive and rewarding way.
Develop healthy self-esteem.
Have more realistic expectations of others.
Your psychotherapist may also recommend medications to treat symptoms like anxiety and depression.
Clim
Re: Updates
Post by Clim »
That is so good I am going to save it. Thank You!!!
p.s., interestingly enough, I had someone tell me they've never seen my YouTube channel before and while they said they weren't being rude,
they wanted me to take down my video and do it in a way that was personally pleasing to them. I blocked them from my channel. It is sad though
that it's not possible to discuss the mechanics and math behind my build. I think that's why people "can't see it".
And for you Tarsier;
Matthew 7:5; You hypocrite, first take the plank out of your own eye, and then you will see clearly to remove the speck from your brother’s eye.
Yep, according to Jesus when people attack me it is to hide their faults. And yet I got a lot of work done today. I feel good about the progress that I'm making. And with much THANKS to ab hammer Bessler's Wheel revolves around me because ab hammer wanted me to have it all to myself. Why he wouldn't let me work with other people. He wanted to show how American Christian leadership is what the world needs and he's just the man to show the world. Unfortunately it takes more than an understanding of the Bible (see my quote) to be productive as a person. It takes a willingness to learn.
As Jesus said;
Matthew 7:24 “Everyone then who hears these words of mine and does them will be like a wise man who built his house on the rock. 25 And the rain fell, and the floods came, and the winds blew and beat on that house, but it did not fall, because it had been founded on the rock. 26 And everyone who hears these words of mine and does not do them will be like a foolish man who built his house on the sand. 27 And the rain fell, and the floods came, and the winds blew and beat against that house, and it fell, and great was the fall of it.”
In today's world it is IMO essential to understand math and science in one form or another. Otherwise how to prepare for a changing world?
Re: Updates
I wasn't attacking you. I was inviting you to look inwards and hopefully seek some help. Maybe everyone else are not the problem.
You should block this website on your browser, because it is clearly not good for your mental health.
Clim
Re: Updates
Post by Clim »
Tarsier79 wrote: Mon Jun 20, 2022 12:38 am I wasn't attacking you. I was inviting you to look inwards and hopefully seek some help. Maybe everyone else are not the problem.
If this forum isn't good for my mental health then I'd say it's because I'm allowed to be attacked for no reason. Unless it's because I'm
1/2 Norwegian. This is where if this build works as I anticipate it will, could it help to make desalination more economical? Yet you do
attack me. So I don't get along with ab hammer. He's the person who refused to work with me. He should accept responsibility for
believing that perpetual motion is impossible. And yet I am in the wrong for pursuing perpetual motion, nay I say, Bessler's Wheel in a forum
supposedly devoted to his work. I think people will find that strange to say the least. Ban James, he's disrupting the forum. Why, what's he
doing? He's actually pursuing Bessler's Wheel. OMG give him red dots stat, maybe he'll get a clue and go off somewhere and die. I never got
the clue. My bad.
Clim
Re: Updates
Post by Clim »
Tarsier, I think the reason I am banned and never ab hammer is because he was diagnosed with emotional health disorders.
According to ab hammer, the Veterans Administration is treating him or has treated him. That would not excuse his behavior.
Google has saved posts he made that have been deleted. And he makes some pretty wild claims that have nothing to do with
anything except for him saying how good he is or how poorly he was treated.
And yet if I want to pursue Bessler's Wheel so I can have necessary surgery, why does that offend people? After all, you're
claiming I have mental illness when I would've liked to have worked with others on Bessler's Wheel. That doesn't suggest mental illness.
Attacking someone who is handicapped actually shows a complete lack of empathy. And yet the forum owners and moderators of these
forums finds that acceptable but not pursuing Bessler's Wheel.
Since no one has been allowed to work with me on Bessler's Wheel it is difficult to give credit for my working through a serious medical
issue which requires surgery. And yet it is okay for me to be attacked because I need surgery and I'd like to discuss my work on Bessler's
Wheel but am not allowed to.
What I am reminded of is when my Father lived in Norway when it was occupied by the 3rd Reich. Pretty much what I have to tolerate. That's
why I say white supremacy.
