@Silvertiger
Cool indeed
Remember no absolutes in this fictional universe.
So the speed of light is in relation to the region it is located.
Also a photon's phase, which is like a rotation, can travel faster than the speed of the photon packet.
Note.
Nothing travels faster than light the void can travel faster than light.
So anything in that void region travels with it as a reference frame.
Much Too Do About Nothing
re: Much Too Do About Nothing
There has been some new research in creating photons circling each other.
https://en.wikipedia.org/wiki/Photonic_molecule
This is the dawn of particles quarks etc.
Just done a quick article acceleration reading of Quantum Mechanics.
So disappointing; it's like a house with walls and a roof and no foundations.
The quick read was from this book
Quantum Mechanics - The Theoretical Minimum
ISBN 978.0.141.97781.2
This new book is the history form the people involved.
Quantum Theory - A graphic guide to science's most puzzling discovery
ISBN 978.184046850.2
I had a block on the nature of photons. There needs to be a process that keeps the local vibration from spreading out.
Well if a photon is a compression wave then the magnetic induced wave circles around the direction of the compression wave.
As the electric wave transitions onto a magnetic wave the form is a twisting spiral. This corkscrew path forwards is reversed on the backward part of the vibration.
At some point the type of corkscrew clockwise or anti-clockwise collapsed to one type.
That is the cause of the predominance matter over antimatter.
So photons are confined to the direction of travel by the electric longitudinal compression wave and the transverse spiraling magnetic wave.
Re: re: Much Too Do About Nothing
If we think about it the light that reaches us from the edge of the expanding observable universe is red shifted due to this expansion.daanopperman wrote:agor95 wrote:Good Question; I used the same paradox on gravity waves.
The compression is on the small scale, very small scale.
You are correct if we were inside the void then compression would effect the distance. That would effect us who are doing the measuring.
The same thing happens in reality with the measurement of the speed of light at near light speed.
Hi agor95 ,
Would this not only be for someone outside the frame of reference , wrt light .
But if a void is compressed , all frames should be equal , whether inside or outside , unless the void is moving at lightspeed .
These compression event are small vibrations either in amplitude or if that is large then the region is small.
Can you think on the true story.
A junction was setup with traffic lights with a quick cycle.
So only two cars could pass the junction from each road at this cross-road.
Very frustrating.
However a mile down the road traffic was moving slowly and smoothy towards the junction.
Normally the stop/start would be seen more than a mile from the junction with a normal cycle duration.
The conclusion from a distance what is local vibration is smooth and measurements outside the frame of reference is the same as within.
For within the observer is affected as well as the ruler.
Outside the local vibrations are not observed.
Also any effect does travel at the speed of light; the compression p-wave.
Gravity
Frank Wilczek Time Crystals
This person is explaining a concept that will get him a noble prize.
It very dry so you may stop watching, but he does choke when he state perpetual time crystals.
https://www.youtube.com/watch?v=JYZMqtD ... avidBurman
That could cause him not to get a noble prize.
Ha - just check he got the nobel prize in 2004.
Obviously for the perpetual motion crystal :-)
Summary
A crystal has a repeating atom pattern in 3 dimensions.
A quasicrystal has a lattice structure but does not repeat.
A time crystal has a repeating pattern in the 4 dimension in time!
The is more viewer friendly
https://www.youtube.com/watch?v=5l1KxgH ... SSpaceTime
Extra 'vibration of the void'
https://www.youtube.com/watch?v=YS3TldQ ... tuteEvents
Summary
Summary
The Void
No Infinities
Movement
Compression - electric field
Wave Dynamics
Interactions
Gravity and Temperature
Initial Energy
Speed of the void & Energy
Entropy, Evolution & Superconductive
Evolution & Entropy
Dark Mater & Dark Energy
Photonic Molecules
Quantum Aetherodynamics Conjecture
No Infinities
Movement
Wave Dynamics
Interactions
Initial Energy
Evolution & Entropy
Photonic Molecules
Could gravity, dark matter & dark energy be one of the same thing?
https://en.wikipedia.org/wiki/Aether_theories
We have Aerodynamics [https://en.wikipedia.org/wiki/Aerodynamics] were atoms in a gas work to create a force.
Could other forces be derived from the interaction on a electric field with itself?
The concept of Aether was kill off in the 1900. It's odd Cosmic background radiation [https://en.wikipedia.org/wiki/Cosmic_ba ... _radiation]
shows we are travelling through this radiation. It's all about the degree of sensitivity.
Regards - Natural Philosopher
