Zeroing in on Bessler's wheel
Sam Peppiatt wrote: Sun Aug 21, 2022 11:25 pm However, as always have to build it first, to see if it will work------------------------------Sam
That is one option. You could draw it up and declare the dimensions are masses?
The value of three is the improved torque stability.
Working through the math's help save you time and money.
However if you are building for pleasure then go for it.
agor95, Ridicule me all you want but, be careful, I'll sick Waltcy onto you----------------------------------------Sam
Sam Peppiatt wrote: Mon Aug 22, 2022 1:17 pm agor95, Ridicule me all you want but, be careful, I'll sick Waltcy onto you----------------------------------------Sam
You could draw it up and declare the dimensions and masses?
No Ridicule intended. A good drawing allows someone to create an illustration.
neuberlintourist1
Post by neuberlintourist1 »
You might wanna have a look into this http://www.heizungsvergleich.de/bessler/zweizwei.html
nevberlintourist1, Beautiful! But, I have no idea how it works; my level of understanding is pretty low-------------------------------------Sam
neuberlintourist1
I just saw that there’s also an English version: http://www.heizungsvergleich.de/bessler/two_two.html
nevberlintourist1, Yes, I saw that. I think it's a much too complicated for me to grasp. The red line must be a cam and, the red dot a cam follower; beyond that I'm lost-----------------------------Sam
Robinhood46
Post by Robinhood46 »
The red dots are the weights Sam. The red line is just an imaginary line to show the path of the weights. This allows you to appreciate the difference between one side of the axis and the other.
Robinhood46, I'm all wrong! I could probably figured it out, if I spent hours and hours. I just don't have the time to devote to it. A long time ago you had a wheel inside of a wheel, a hex shape I think. What became of that---------------------------Sam
Robinhood46
Sam, If you are talking about the real world build, the one that had tin cans with varying levels of sand for the weights, it failed miserably. The sand is probably in a wall somewhere stuck with cement, the tin cans may have been melted down to make an ashtray, or are in some landfill somewhere rusting. As for the wood, my guess is that it got cut up for other things getting progressively smaller and smaller until it was finally reunited with the tin cans at the landfill.
George Kunstler worked a lot on a hexagon in a wheel too, and we haven't heard from him recently, so maybe he succeeded and he has been killed off by the men in black? or more probably, his attempt failed miserably too.
Robinhood 46, Yes that was it. My old wheels get canablized. They never get a decent burial; the poor things--------------------------------Sam
Sam Peppiatt wrote: Mon Aug 22, 2022 9:45 pm Robinhood 46, Yes that was it. My old wheels get canablized. They never get a decent burial; the poor things--------------------------------Sam
My old wheels are a figment of my imagination. They get a sky burial.
But agor your wheels never fail, always spinning in the sky----------------------------Sam
Robinhood46
My thoughts go around in circles perpetually, does that count?
Robinhood46, Yes they should count. Maybe agor95 can wright a song for us; "Ghost Wheels in the Sky", he seams horribly smart--------------Sam
