Lifting One Weight Higher Than Another Drops
Watch the last 5 seconds of this 31 second video. The arms or CoG is about 1 meter from the axle.
When the weight on the right starts to drop, it is below the level of the axle. When the wheel stops
rotating, the weight at bottom center is above the level of the axle. It is lifted higher than the distance
the weight on the right dropped. That is an "impossible" mechanical advantage.
Would you constantly attack someone if they wouldn't give this to you? And the energy shortage
in Europe changes what a working wheel means. And it is possible that my build will be finished next
week. A working wheel will let me ask why it was okay for me to be attacked while working on this.
I doubt Stefan Hartmann who owns overunity.com and overunity.de as well as orpheus.org will have
a good answer except to say that I was the problem because I was expected to give my work away
for free.
And as I said, watch the last 5 seconds of the video, a weight is lifted higher than another weight drops.
That is simply impossible.
https://youtu.be/1ezerfk63fY
for free.
Re: Lifting One Weight Higher Than Another Drops
Nous avons compris le principe!!
Mais nous ettendons toujours la fin du montage pour voir la roue tourner.
We understood the principle!!
But we are still at the end of the assembly to see the wheel spin.
Il pourrait être terminé la semaine prochaine. Demain, je monterai le cadre. Alors je n'aurai pas besoin de m'inquiéter
casser les espars (bras). Dans le forum scientifique, quand je l'ai expliqué comme un avantage mécanique,
Je leur fais savoir que je suis soit un menteur et une fraude, soit un avantage mécanique a été réalisé.
Vous êtes la première personne que je rencontre qui comprend le principe.
It might be finished next week. Tomorrow I'll rig the frame. Then I will not need to worry about
breaking any spars (arms). In the science forum, when I explained it as a mechanical advantage,
I let them know that I am either a liar and a fraud or a mechanical advantage has been realized.
You are the first person I have met who understands the principle.
Hi Soon !
Take a look at a half-pipe skateboarder’s “higher” performance concept : https://dribbble.com/shots/3807436-
…as an elastic pendulum (mass-spring ) playing a “double drop”/including radial acceleration.
…then,with this additive “bonus natural push”/pumping rotational inertia , make a simple test with a rotating -tumbling pendulum (spring—sliding mass-spring) as this net-proposal : https://stack.Imgur.com/y8N13.png
Al_ex
Al_ex
Your wheel will not work. Everything it does is possible. It rotates further due to an imbalance, as pointed out before (Tolerance in building). You will not be able to sustain the imbalance over 360 degrees.
Pour éviter le frottement du câble sur la came vous pourriez mettre une rampe à galets.
To avoid the cable rubbing on the cam you could put a roller ramp.
dont forget that there is an additional weight and torque of the g-clamps on the right , for calculation.
Please help me any Engelsk spicking peoples. Imma need a tudor for a quick Engelsk lesson.
What does soon mean?
No buddy wanna heppa me with a queek Engelsk lesson.
what sa mattah me? no buddy wanna kiss my butt.
will you kiss my butt, Soon?
imma still not know what soon means
Is it cold in Texas? I checked. It's 23º F. Want to know why? The ozone layer is recovering. This shifts the jet stream
and allows for arctic blasts. Get used to it. Oops, you have that capitalist system down there, right? The colder it gets the more
gas companies goes offline the higher the prices goes to discourage heating your home. God Bless Texas!! Just not an issue
for me when my gas prices are responsibly regulated. In fact because it's cold outside I even turned up my thermostat above
what I usually keep it at. I can afford it. Might crank it up to 78º tomorrow. Nothing I have to worry about.
With what I was building, I think I actually figured out an easy solution to the bearing problem. Being attacked for showing
my work and building has slowed things. It's like what does a treadle have to do with Bessler's Wheel. Might be why he
referred to the main part of his wheel as a grindstone. But forum members rejected a grindstone as having anything to do with
Bessler's Wheel.
I do need to thank you for showing me that in 2011 I was on the right track but people wanted to discuss words. I mean mpeg,
jpg or png? And what's the difference between a kb and a mb? Can you help me? Today it's usually .wav or mp3 and mp4. or
even TB and that's terabyte and not Tom Brady or the Tampa Bay Buccaneers.
How did this work out?Sep 07, 2022 8:29 pm
It could be finished next week
Did we ever settle on the meaning of soon?
I assume the definition changes but rest assured it means at least 7 months.
Sure looks like what I saw on that xray.
Why the Right Lubrication Is Important
It's becoming clear what this maniacal genius is doing. His video has been running for 7 months, but no interest.
Description
Fri Mar 31, 2023 4:35 pm
Ken B.
Description
- Why the Right Lubrication Is Important
Free Energy Systems
- 8 Likes
Aug 13, 2022
In the short time he's been here this timeI went from using grease for the axle bearings to using oil. I am currently making oil seals for all of the bushings and bearings on the new build. I have Manila rope on order and am hoping it is not a supply issue. I'll need the Manila rope to rig the wheel. If it is a supply issue then I'll most likely braid imitation sinew.
- 160 Replies
- 8849 Views
Ken B.
Agreed. I bought Ken's e-book and after I got it, I thought was a bunch of wordy bs - I'd been had. I can't get over his Y- shaped lever infatuation.
This Bessler wheel stuff seems to attract all kinds of crack-pottery. There is a certain psychosis that it seems to attract. I'm not perfect, but I believe the wheel didn't violate any laws of physics - just harnessed the forces within in a clever and obvious way.
