Use A.I. to crack Bessler Wheel-revolutionary new way of using Text-to-Image A.I.
neuberlintourist1
Post by neuberlintourist1 »
So far my results are definetly able to improve.
IF SOMEONE COULD PUT ALL OF BESSLERS CLUES AND MTS INTO A ARTIFICIAL INTELLIGENCE PROGRAM; IT POSSIBLY COULD SOLVE IT.
Like the TV-Series: Auf der Suche nach Atlantis | Hunting Atlantis- where they feed all Infos into a A.I-Program, which its A.I. helped narrow down the possibilities.
We need something like this and feed it with Besslers Books, Clues and all MTs.
There are few different Websites:
1. Nightcafe (Web): The Simplest Free Text-to-Image AI Converter - https://creator.nightcafe.studio/text-to-image-art
2. Starry AI (Web, Android, iOS): Text to Image AI Art With Granular Control - https://www.starryai.com/
3. Dall-E Mini (Web): Get a Taste of the Famous OpenAI Dall-E - https://huggingface.co/spaces/dalle-mini/dalle-mini
4. Dream by Wombo (Android, iOS): Simple, Free, Unlimited AI Text to Image Art Generator - https://www.wombo.art/
5. Pixray (Web): AI Text to Image Generator With Custom Codes for Geeks - https://replicate.com/pixray/text2image
Try using different words.
My results so far:
-Searchterm: Johann bessler wheel
-Searchterm: Self moving Wheel
DALL·E 2
Just very very, i mean very curious to see that the Text-to-Image A.I. puts out almost an exact replica (12 in terms of Numbers of Sprokes compared to the 13 spokes of the gentlemens magazine wheel) of the 1751 Wheel published in Gentlemens Magazine, entitled A self-moving Wheel:
I did not feed any more information to the A.I. only just the 3 Words: Self moving Wheel
Try out your results using the Search Words Self moving Wheel
Last edited by neuberlintourist1 on Tue Nov 22, 2022 8:51 pm, edited 6 times in total.
neuberlintourist1
Re: Use A.I. to crack Bessler Wheel-revolutionary new way of using Text-to-Image A.I.
Johann bessler wheel peacock tail https://creator.nightcafe.studio/creati ... CaX4LpJiYh
Perpetual overbalanced wheel like Johann bessler wheel https://creator.nightcafe.studio/creati ... 8iJMjREygB
Last edited by neuberlintourist1 on Thu Dec 22, 2022 8:39 pm, edited 1 time in total.
Une sugestion de roue Paon!
Il faut rechercher la bonne synchonisation des couronnes de logements pour compenser les changements d'états et obtenir un couple moyen.
A Peacock Wheel Sugestion!
It is necessary to seek the good synchonization of housing crowns to compensate for the changes of states and obtain an average couple.
Notice the Peacocks tale appears to be lifted at the bottom and extended at the top. A peackocks tale is beautiful, but will not work in OB because the bottom shift appears to be horizontal. If we turned the Peacock tale on its side, the lift would be vertical and it would rotate.
The fact is: Besslers prime mover needs to add energy to the system. I 100% believe Besslers prime mover was something that was able to lift weight. Lifted weight is perfect to power an OB wheel. This fits in perfect for me that he found the answer where everyone else had looked... IE, he needed OB to convert PE to KE.
Besslers prime mover either had to be OU, or a hoax using water or air pressure.
I dont want to sound negative like i am bashing what other people think are clues , its just that imo , i think he meant it was a marvelous thing to behold a mechanical functioning wheel no matter your point of view from the side or front , he was proud of it.
johannesbender wrote: Fri Dec 23, 2022 12:18 pm i think he meant it was a marvelous thing to behold a mechanical functioning wheel no matter your point of view from the side or front , he was proud of it.
Sometimes the basic human factor of pride and achievement is the motivation to a sentence.
P.S. I wonder if the movement of a Peacock's tail rather that it's shape has been disgusted?
They do open up, close down and vibrate the open display as they try and enclose the pea hen.
