I have a question ??
please come and share your thoughts.
http://www.besslerwheel.com/forum/viewt ... 51#p191815
all ideas welcome
Leafy
Re: I have a question ??
Post by Leafy »
Third idea because you should have a blast.
I keep getting this now…
Please post it in James L's blog!!!!
Please. :)
Phishing at Bessler Wheel, Leafy ??
Leafy wrote: Tue Dec 27, 2022 7:21 pm Third idea because you should have a blast.
Why should att suspect phishing pages at Bessler Wheel??
Leafy
Post by Leafy »
It’s gone now. Magic.
Well, I guess more power to perpetual motion.
Dr.Wlazlak
Post by Dr.Wlazlak »
I have a Question:
Did the Bessler Wheel Spin one direction only: because I seen a drawing that show people being lifted by a rope
Did The Bessler Wheel turn one direction using the bricks of weight going down using a rope, then wind the rope back up and lift the bricks
winding the rope back and forth on the shaft as the wheel turned one direction then the other.
This brings forth the third question does how big was the Wheel?
A Second Energy may have been made by spinning the water in the drum and compressing Air baffles and using that stored Energy in springs to
allow for the return rotation to be more for each direction returned. Depending how fast it turned and how big the dim. was.
This is totally possible to recover a second energy if this is so.
Tom
This will answer some of your questions:
http://www.orffyre.com/measurements.html
Besslers first wheels spun in one direction. The latter spun both directions. The wheels did external work. According to Besslers writings, we do not believe they were recycling power.
JCs books are available quite cheaply:
https://johncollinsnews.blogspot.com/p/ ... raphy.html
Dr.Wlazlak wrote: Fri Jan 20, 2023 4:47 am I have a Question:
Tom
The first wheel was one directional which self started when released , people claimed he used a spring , then he made the newer wheels bi-directional but needed a push in the direction you would have wanted it to turn to , so they could spin in either directions whether doing external work or not , and if you think about it there is no way you wind a spring up to last longer and have more power or energy than the distance and force the rope raised and dropped its load , that's against the laws .
Last edited by johannesbender on Fri Jan 20, 2023 9:00 am, edited 1 time in total.
