Math
Da Ewe
Re: Negate Inertia.
Post by Da Ewe »
WaltzCee wrote: Sat Mar 25, 2023 7:04 pm hear, here, a bit more wheel talk.
This is my theory, do the math!!
As far as perpetual motion goes, it's actually leveraging mass into motion which is realized as torque. Bessler's Wheel uses a neat trick. When the wheel rotates, a line wraps around stationary disc. This increases the distance between the fulcrum and its weight. Technically speaking the only worked performed is rotating the wheel. And you'll disagree with that. w = m*d, right? For the line attached to the weight to perform work, its length needs to change between point A (fulcrum) and point B (weight).
And Newton (1687, First Law of Motion) did say that an external force can change a body's motion. In this instance, resistance is a force. It negates inertia.
This is why I'll need to move out of the U.S. And when Amy Pohl finds out I might've been able to help
her but handicapped people are the problem, I think she might have a serious talk with her grandfather
about the people he and his friends support.
Perp Alert
Da motionless pee pee Ewe wrote: Sat Mar 25, 2023 7:45 pm . .. .. .
& This is why you should be banned, James. You put yourself out there, that's fine.
Yet you want to drag others you don't even know into your insane drama, not so fine.
You should be banned, again.
JUBAT
Re: Math
Post by JUBAT »
I'm in agreement - this guy is delusional and I think it's time to let Scott know he's back again.
Da Ewe
Re: Math
Post by Da Ewe »
JUBAT wrote: Sat Mar 25, 2023 8:17 pm I'm in agreement - this guy is delusional and I think it's time to let Scott know he's back again.
What did you say I needed to do JUBAT? Have respect for people who have no work to show?
That's being delusional. When people say they should be considered knowledgeable when they
say "I think". It is interesting that credibility is not earned.
As your friend said, Bessler's Wheel cannot work because perpetual motion is impossible. And yet
where are you guys? In a perpetual motion forum of all places. And when you don't seem to know
math, it's your belief in yourself that makes some of you guys right.
And one day I will know who Scott really is. Then he can explain why he didn't support a disabled
Veteran of the U.S. Navy pursuing Bessler's Wheel in a forum supposedly for realizing Bessler's work.
Oh, I know, I wanted "green dots". That's actually true. Credible got "green dots" Literally did happen
by their friends and that showed who knew math, science, engineering, etc. as voted by their friends.
That system allowed for extreme cronyism and ruined this forum. Why no one in here that is liked
builds. Besides, can Scott or you guys keep me from having Bessler's Wheel built? You can't. And then
how people like wally boy constantly harass me because I'm 1/2 Norwegian will have people wonder
why that's allowed when Bessler himself wasn't ethnically pure.
How both myself and Bessler have been treated will show nothing has changed in over 300 years. And
all bans are for is to condition people to be controlled by guys like you who are in here.
And what's funny is that everyone in here knows Aldo Costa's machine works https://www.youtube.com/watch?v=rsBplmMDcRQ&t=3s
And yet it is still posted in here it's not possible. That is the true definition of delusional behavior and shows I
am being attacked for being 1/2 Norwegian. That is bigotry and why I got red dots. Some people liked my being
in here because I actually showed my work and that is why I got banned. I tried working with and getting along with
pure English speaking people. And I have to accept that is a mistake on my part.
JUBAT
Re: Math
Post by JUBAT »
It's your behaviour and not your heritage that people can't stand, but so far you will not recognize that's what the problem is. You've come in here blasting about being 1/2 Norwegian and I've told you before - nobody cares about your heritage. It's your constant contradictory statements and statements that make it sound like you've solved the wheel when you have not. You talk like you know the answer, but it's one failure after another. If you spoke with humility and without judgement and said things more like, "Well I know my previous designs have failed, but I'm going to try this again and see if this works," then people would be more supportive. Get it through your head that you have not solved the wheel and regardless of whether others are trying or not doesn't change that fact.
You carry on like you've solved it, dug up old grudges, and basically your behaviour and how you conduct yourself online is what turns people off.
Don't be so pompous and you'll go a lot further with people. So far it's been nothing but bunch of talk with absolutely no working wheel to share for it.
We don't give trophies for good tries.
Da Ewe
Re: Math
Post by Da Ewe »
JUBAT wrote: Sat Mar 25, 2023 11:33 pm It's your behaviour and not your heritage that people can't stand, but so far you will not recognize that's what the problem is. You've come in here blasting about being 1/2 Norwegian and I've told you before - nobody cares about your heritage. It's your constant contradictory statements and statements that make it sound like you've solved the wheel when you have not. You talk like you know the answer, but it's one failure after another. If you spoke with humility and without judgement and said things more like, "Well I know my previous designs have failed, but I'm going to try this again and see if this works," then people would be more supportive. Get it through your head that you have not solved the wheel and regardless of whether others are trying or not doesn't change that fact.
It's not my behavior. Hold it, you are right, it is my behavior. I actually build. It's like you said, I should respect people
who do not build. And it is because I am 1/2 Norwegian. I was told that because I am 1/2 Norwegian I will work for Americans.
Kind of difficult to miss a blatant statement like that. An example is if I wish to post in this forum I will be taught what it means
to be an American and shown why America is the greatest country in the world. It's because the U.S. is a capitalist country
which means it exploits people.
After all, when ab hammer posted that I couldn't use cancer as a reason not to work for Americans and I refused to work for
Americans and their friends, I got banned. Thank You for reminding why I am not liked here and why it is acceptable for people
to troll me. Also if you have no work to show or that matter anyone who has no work to show should not be criticizing my work
which you are defending. You're putting conditions on what work should be valued when you've never built anything that anyone
has seen.
It's like the American who saw Aldo Costa's wheel in person and then said it wasn't good enough to earn the $10,000 prize
he was offering for a working overunity device. Same thing you just said about pursuing Bessler's Wheel, no actual work matters,
only a working wheel. That means that you want me to build it for you. I don't owe you anything. After all, I am delusional, right?
And that's for thinking I've realized Bessler's Wheel which can't work because perpetual motion is impossible.
And as I mentioned, I could've built Bessler's Wheel while posting in here but I was criticized for having to learn what Bessler knew.
And yes, that is because I am 1/2 Norwegian. If I was one of you guys then you'd like my work. 😊
Re: Math
  • And yes, that is because I am 1/2 Norwegian. If I was one of you guys then you'd like my work. 😊
    Top
This is a dubious claim at best. People know James's mom was an Appalachian hillybilly, and that end of the human genome has difficulty figuring out some rudimentary ideas concerning relationships, etc.
James's claim of being half noweenie-ian is as believable as if he claimed to have a working wheel idea.
Show me the DNA test. Probably a distant cousin
JUBAT
Re: Math
Post by JUBAT »
The only way anyone here would like your work - is if it worked.
Building a wheel is NOT the same as a working one. Your efforts towards that goal are commendable and no one is putting you down for that, but before you can accept a reward and praise for anything you've done - it needs to work. Get that? It needs to actually self sustain. Publishing a youtube video of you spinning your wheel by hand and watching weights move isn't going to cut it.
We don't care if you're Norwegian. We don't care if you're Norwegian. We don't care if you're Norwegian.
Show a working wheel. Show a working wheel. Show a working wheel.
We don't care about AB Hammer. We don't care about AB Hammer. We don't care about AB Hammer.
Good for you that you are attempting to build the Bessler Wheel. (x3)
Despite what I'm saying, you are totally convinced that you are right - that we are all a bunch of Norwegian haters whose hate is elevated by attempts at building a non-working Bessler wheel.
Okay - have it your way.
Retard.
Re: Math
Used perpetual motion machine for sale!!
Hardly used.
Anyone buying this?
JUBAT
Re: Math
Post by JUBAT »
How many kroners is he asking? Kroners or Dollars?
Re: Math
Bitcoin?
James has shifted his bidness model to Ken B's Hail Mary one.
  • Claim success without evidence.
His habit of trolling John Collins thinking he's going to put a wedge between a grandfather & his granddaughter, what can I say.
I personally won't tolerate that. I think more people should stand up and lock arms.
The more frauds that come along like James claiming success w/o evidence the harder it's going to be for the one who really figures it out.
It's obvious James is money motivated, yet wants to look over everyone's shoulder to see their work.
If one builds, but James doesn't see it, did they really build?
I despise those frauds.
do the Math, dummie
Re: Bessler's Wheel Solved!!
WaltzCee wrote: Sat Mar 25, 2023 5:22 pm
a lunitic boasts & wrote:p.s., it is nice being able to say that a psychiatric hospital found me to be a sane person and yet the tag suggests that I am not. I think I will agree with professional psychiatrists on this one.
we need a second opinion.
The claim was once 110% handicapped.
maybe 10% mental, I'd believe that, low end of the range
Da Ewe
Re: do the Math, dummie
Post by Da Ewe »
WaltzCee wrote: Mon Mar 27, 2023 8:00 pm Image
Wouldn't this be simpler? I mean if you know the wheel's moment of inertia then how to know what the overbalance will do?
That needs to be greater than the work it takes to create it. Otherwise entropy will decrease movement of the wheel.
People have told me before that I have to prove Noether’s theorem wrong. I don't. She was also Jewish.
Symmetries imply that certain quantities are conserved. Entropy cannot be prevented. Her equation states under certain
circumstances there is no entropy. That's never been found to be true. And now you just helped me to understand why a
respected Jewish mathematician was wrong.
Perpetual motion is based on gravity. That is the opposite of entropy. However when I show that Einstein made a mistake, it
will increase the value of his work. This has to do with his 1915 paper on relativity.
With what I posted, it takes work/energy to create an overbalance. That quantity is subtracted from the work/energy that an overbalance creates/generates.
It's in the math.
Da Ewe
Newton Was Wrong
Post by Da Ewe »
With Noether's Theorem, how to consider if subatomic particles are passing through a space shuttles skin
into the craft itself? In a trip to Mars, it's said that a 3 feet thick layer of water which in space would be ice
would limit the effects to observed neutrinos on Earth.
Her theorem could help to show when shielding prevents the exposure to particles in space do not allow for a change over time.
With the attachment, Newton was simply wrong. He should have said;
g = Gm1/r^2 = a = Gm2/r2^2
.......................2a...................
Why 2a? When 2 planets have their gravity acting on the same point in space equally, the effect is 2 times the acceleration
while no change takes place over time. About the only other example of where Noether's theorem can be applied.
And this obviously leads into Einstein's 1915 paper on relativity. I think for now you guys will do well to accept that Newton made
a mistake because he had no one to proof his work. Thing is, nothing in the universe is static. However this understanding would
give a new meaning to Noether's work because it would show that once an equilibrium is found, change will still occur.
p.s., because m1 and m2 are different masses, they will not share the same r value. This makes a (acceleration of gravity)and not r (radius) the constant.
f (force) is equal to a. This is because f = ma and yet force is determined by radius. Why acceleration replaces force when considering this.
