- ken_behrendt
Robert...
With all those crosses and Stars of David, it sounds to me like you have a very complex design to your "GPW". I do not think I would have persued a design to that level of complexity because, since I'm out to replicate Bessler original design, I would be prevented from doing so by the "Carpenter's Boy Law".
It sounds to me that you, like I recently have, are slowly reaching the conclusion that using a separate set of shifter weights to shift a set of drive weights is yet another dead end. The two sets of weights just produce a composite CG that eventually takes up permanent residence directly below the axle of the wheel.
amen
Working Model 2D
No, it is simple.
As I was building all others before this design, it soon became obvious, that they weren't going to work.
This one though, becomes more obvious it will work as I get farther along with it.
Still no failure..................
For the Glory of the Lord
Amen
Amen
Robert (The Carpenter's Boy)
Yes!
Found some small turnbuckles on google that I'll useto adjust spacings inside the GPW
"Good news".
Still no obvious failure happening.
Worked more on completion only briefly last night.....
Can't wait for mail order turnbuckles. Got some small enough at Home Depot tonight.
Made a cover for the open side of the wheel.
Will know for sure in a couple days, success or failure.
The excitement is building! Good Luck!
For the Glory of a Judeo-Christian God.
Amen.
Amen.
I'm not sure he was joking.
... then let's hope he has a sense of humour :)
I'm dead serious.
I'm sorry to hear that. Will you reconsider your decision?
