Stronger vision of imbalanced
I feel like I have to make it up.
Here we have a mass spring system drop 1/4 circle.
If we attached a small weight to the big weight, the torque profile have greatest dip at the bottom.
If we wired the small weight with pulley and strings. The torque profile is greatest on the side.
Re: Stronger vision of imbalanced
Hi Leafy !
Take a look about “half pipe skateboarder’s physics” ,then play his performance….with his mechanical equivalence ( elastic/spring mass pendulum ).
With a spring you can play/add and release …the rotational inertia
Al-ex
Al-ex
Thx Alex
Just want to make the remark , the amount of creativity around this subject never ends.
One moves closer to the center the other moves further from the center.
They takes turn gravitating each other.
They barely move with one crossbar.
When configured 3 pairs of weights, it looks familiar.
By adding 4 stoppers mid way, one way net torque is achieved. This wheel should turn counterclockwise.
There seems to be a longer imbalanced on one side than the other
Never mind, they seems balanced. I now believe conservation of energy is there for a reason. It might be possible, but I decide not to tamper.
Vertical ramp. Maybe
Hi
Is this what you are thinking about?
Ho do not worry on breaking any conservation rules.
An accelerating device has access to an energy source that has lots to spare.
Exactly Agor95 :)
Pulling strings on roller
Roller ramp mix
8 oil drops with a twist.
Connect strings from one roller to another
