Sam they are all connected and in communication. US routinely comes into Canada to seize documents, inventions or UFO's. The US arm is long. Do you really think you are going to get past Five Eyes?
https://www.history.com/news/nikola-tes ... sified-fbi
I guarantee everyone none of the patents under wraps are for free energy machines that would crash the economy.
If your invention contains the words ‘death ray’ or similar language you should certainly expect a visit from the intelligence community, and be prepared for questions, lol.
daxwc,
What can I say; when I'm wrong I'm wrong-----------------Sam
Ecc1: I guarantee everyone none of the patents under wraps are for free energy machines that would crash the economy.
Is that the same guarantee that you gave on all the energy was accounted for in SIM’s then Fletcher found an error? Or a different guarantee? 8P
It’s the same thing whether you’re talking about a sim or a patent.
You can ask your friend what it thinks the secret patents are for if you’re curious.
FWEIW,
There is a possibility that a patent examiner wouldn't recognize the true value of a working wheel and, simply let it issue. Even on this forum most people say that Bessler's wheel was weak and, have little or no regard for it. Not taking in account that it was still only a prototype,(made mostly of wood), and meant for proof of concept only.
They perceive things exactly as they are, completely unable to see beyond that. Which, has been the same with a lot of new inventions------------------Sam
Ecc1, I asked my friend about your guarantee and it said you are about to commit a “"breach of guarantee" since those kind of guarantees can be considered a subjective claim rather than an objective guarantee.
I'm just going to keep this short because I want to get back to being productive.
I'm with you daxwc you are telling it more like it is.
As for the patent office they can go whistle into the wind as far as I'm concerned.
These discussions though are not helping us with the wheel so my next posts will be about that.
I'm getting back to my lever problem.
Just to recap I need to overbalance the yellow main weight with a small enough blue lever weight so the inverted pendulum can exist.
If you are someone who has jumped straight to the last post please go to the earlier posts to understand what I am attempting to do.
Here is the overall picture.
Here is a close up view of the left hand mechanism.
I should point out that these simulations are larger and heavier than normal for me. I usually pick sizes that I can make for real. The crossbar the weights are on is larger than it needs to be and the holes in it are unnecessary. The main parts are the weights and the beam holding the yellow weight.
Here is the simulation for the left mechanism.
The thinking is this. The blue weight can't overbalance the yellow weight because the yellow weight is too far from the pivot. Therefore the yellow weight swings the mechanism around till it reaches the position you see on the wheel. At this point its as though the blue weight had levered the yellow weight upwards.
Bessler work out 318.zip
(11.11 KiB) Downloaded 21 times
Here is a close up of the right hand mechanism.
Here is a simulation of the right hand mechanism.
Bessler work out 319.zip
(22.49 KiB) Downloaded 40 times
Here is a simulation of the wheel when the weights are in position proving that the inverted pendulum exists.
Bessler work out 320.zip
(23.82 KiB) Downloaded 25 times
