Roxaway59 wrote:
Hi Fletcher, its a bit difficult working out how to interpret some of the things wrote by Bessler.
Hi Graham .. it is difficult, because he never ever intended to give accurate instructions, to building, or teaching, his "proper method of mechanical application" .. he was well skilled in wordsmithing and distraction imo and used every opportunity to do so ..
However, I did cherry-pick yesterday's Wagner and B. rebuttals because they can be insightful imo ..
** ( fwiw - I think Christian Wagner is one of the unsung hero's of the B. story, who is a convenient foil for B. to use, and dump on )
In this case B. actually uses Wagner's words ( not his own ) .. to paraphrase, Wagner said using weight shifting implements and applications ( i.e. using MA techniques ) is an impossibility because the act of weights transitioning causes the wheel to jolt and "hunt" ( and waste energy ) i.e. this results in a non-regular rpm .. he was saying that B's. wheel had an
unnaturally regular clip and
were too fast for weights having to be shifted around internally - he then says even if you could manage it the weights would have to be raised upwards
"in a flash" -
these are Wagner's words .. B. uses Wagner's words and flings back at him ( and the readers ) that indeed they do need to be raised up "in a flash" just as Wagner said .. B. is mocking him and imo also being misleading by using Wagner's description of an impossibility to be raised in a flash ..
W. knew very well, as we all know, that any weights requiring lifting ( whether rapidly/fast, or slow) takes SOME time, especially if the vertical height gain required gets greater ( for more torque, acceleration, and rpm ) etc ..
My proposition is that B's. weights were not raised up "in a flash" at all, but were raised up, just not using the usual and well know MA applications - he discovered a new method of mechanical application that caused the weights to spontaneously rise up on demand - as I said in my last post he discovered an arrangement of mechanical Self-Excitation generated from a Positive Feedback Loop of mechanical interactions - that were not of the same DNA as per Mechanical Advantage techniques of ubiquitous machines, tools, implements, and applications available and comprehended by Wagner et al ..
In short, even B's. weights had to be lifted, but in the physical sense of 'in a flash' is indeed impossible and impracticable - tho metaphorically they conveyed a sense of the lifting required to achieve a fast acceleration and rpm that Wagner could not emulate with MA techniques and applications in his much slower spring-wound replication attempt ..
