AP Geometry
AP Geometry [Hold]
Hello All
Based on resent posts that the principle of 'Why am I reading this?' results in not supplying a working PM.
However it does hint at a clue that the AP Wheel could indicates a titled pendulum is a way forward. [IMHO]
This threads purpose is to present how to go from the AP Wheel to a 3 Dimensional presentation were 21.7 and 98.3 from the AP Wheel
is the only ration that work to 1. cover the area in the AP Wheel and 2. fit the mechanical dynamics present in a titled pendulum.
Now you can ask for clarification on what is present within this thread 'as is'. Or continue in your own area of study.
I wish you well on your endeavours
Re: AP Geometry
Hi TTIF
Some will know what TTIF is but in this case the Interested Few is Very Few.
The abstract image is of a stick wood 50cm long by 10cm square section.
The three circles things are large wireframe cylinder only 2mm thick.
Two where rotated one along the X and the other along the Y axis.
The third middle circle like thing was titled along the corner to corner diagonal.
Made to intersect the cross over points.
All this was done to find the unique values of the AP Wheel sectors that satisfied the rule of making this conjunction.
So the White Sector is 17.5 degrees and the Black Sector is 102.5 which total 120 degrees. A third part of the AP Wheel's 3 part symmetry.
This blender analysis is better than my last attempt which produced 21.7 and 98.3.
Re: AP Geometry
Hi TTIF
agor95 wrote: Tue Jun 04, 2024 6:57 pm
To clarify X & Y are rotated by 17.5 and the corner to corner tilt is 102.5 degrees.
