Unmechanical Perpetuum Mobile
Katuschik
Post by Katuschik »
I the engineer from Russia
I have the version of the unmechanical Perpetuum Mobile .
If will be of professional physics ready to penetrate in a question, I shall be glad to discuss.
VergingOnDone
re: Unmechanical Perpetuum Mobile
Post by VergingOnDone »
Welcome to the Bessler site, we would be glad to hear about any info that can enlighten us with PM or free energy so to speak. What have you discovered?
Welcome Katuschik, tell us more.
Katuschik
Post by Katuschik »
Thank for goodwill.
The subject of conversation is very much combined and “only professional physicsman”, having very deep knowledge in physics of space, physics of time, theory of a relativity Ejnshtejn.
The theme will require a lot of time.
It is necessary stage by stage to pass a number(line) of well-known physical themes. To discuss questions above which earlier to you it was not possible to reflect.
If in a forum really is of professional physics and they are validly ready to take part in discussion, I am ready to begin from physics of space.
( I bring apologies for quality mine English).
Katuschik
Post by Katuschik »
CONTENTS:
1 Commentary about functions-characteristics of substance. During many centuries scientific theoretical basis is created and founded by analysis of well-known physical processes. This method of approach permitted to achieve great results but didnÂ’t give any chances to solve all the problems before the science.
The author of this article tried to work out the method of calculations,founded not only on study of well-known theories and physical processes,but on the creation of
Complex of functions-characteristics of substance.
From authorÂ’s point of view ,he could solve this problem and turned out brilliant argument of right solution. From his point of view, he has made the following:
1 to pick out the first properties of substance
2 to work out methods of lead-in of static part of functions-characteristics of substance into virtual volume.
3 To work out the methods of activization of virtual volume.
4 To turn out the full scheme of formation of waves and fractions.
5 To pick out conditions of mass formation
6 To work out the algorithm of building of mathematical model of substance
7 To determine the components of gravity.
8 To pick out parameters of physical processes, which are available to use.
All indicated tasks are solved according to common characteristics of substance. They
are valid not only for real indices of material world but they can use to calculate the processes in material world ,which has got differences from substance.
This informational basis permits to work out the methods of use and schemes of following devices:
1 Scheme of device ,which change the index time in limited space
2 Scheme of opportunity for material object to reach the speed imminent to velocity of light.
3 Scheme of device, which can form gravity.
4 Scheme of conservation of material object in space.
5 Method of extraction of energy.
6 Scheme of non–fuel power unit.
7 Scheme of device, changing chemical elements.
For the best comfort of designation of theme under discussion, we can consider
the following logical succession: molecular physics, chemistry, which is closely connected with physics, organic chemistry, biology, and etc.
(continuation depends on only development of science).
LetÂ’s consider this logical succession in opposite direction: from chemistry to molecular physics and etc.
After molecular physics there is a section, which is designated like “science about substance”.
Practical part of this section consists of informational part about functions-characteristics of substance, their static and active block.
Static block of functions-characteristics of substance consists of material conditions and limitation expressed by mathematical formulas and corresponded to static condition of private case of substanceÂ’s existence.
Active block of function-characteristics of substance consists of material
conditions and limitations, expressed by mathematical form. Material conditions and limitations reflect the complex of interaction of material parts ,forming the substance and exist in some volume like reflection of real possibilities of substance.
When complex of functions-characteristics of substance virtual volume makes itself more active, the process of non-stop transformation of the first static block of functions begins. This process is reflection of cycle of substanceÂ’s existence.
Operating with active block of functions-characteristics we have an opportunity to determine every branch of physics, what we are interested in, and then during this process we can consider different branches of chemistry, organic chemistry and etc.
In author’s opinion, active complex of functions-characteristics of substance in virtual volume is a base, which can use in capacity of logical provision with artificial intellect, which is capable of self –developing.
COMMENTARIES: HOW TO DETERMINE THE SUBJECT OF STUDY.
Let’s introduce new conception “volume task.”
“Volume task” –is a complex of conceptions about essence of real phenomenon, having some
theoretically possible solutions. The complex of conceptions is a base for scientific assertions and laws. The example of correct (sound) decision of “volume tasks” is the transition of people’s imaginations: from flat surface of the Earth to the Earth-planet. Incorrect decision of this task was a basis for development of such sciences like: geography and astrology and different unaccountable disparities had appeared.
Nowadays on physics there is great number of such disparities which are consequences of correct decision of volume tasks. Here are some of them:
I Mass of photonÂ’s peace.
II Disparity of laws of classical mechanic to relatival mechanic.
III Impossibility of designation of gravityÂ’s components.
IV The arguments of sublimation of cometÂ’s tail.
V Disparity of molecular processÂ’s duration to the law of conservation of energy.
VI Argumentation of waveÂ’s formation.
The author of this article is sure that he has discovered the correct decision of “volume task.”
The decision of one of them he would like to introduce to your attention.
