** A Machine so Simple and Easy to Understand and Construct .. **
"It more than fulfils the requirements of an almost countless number of learned prescriptions as to what any credible device laying claim to Perpetual Motion status must perform. (page 30) Indeed, this long-sought and much desired machine, or so-called Perpetual Motion. (T.N. - pure artificiale quoad durantem materiam is added after P.M. – this Latin phrase is then described a few lines later, marked *) is a revolving wheel,
which is able to run, by means of its own innate momentum, *…
" DT 195 Karl Proclamation 27 May 1718
His Highness, who has a perfect understanding of mathematics,
assured me that the machine is so simple that a carpenter's boy could understand and make it after having seen the inside of this wheel, and that he would not risk his name in giving these attestations, if he did not have knowledge of the machine...'
- letter from Joseph Fischer to J.T. Desaguliers, 1721.
His Serene Highness assured me to the contrary, and that the machine was very simple...'
- letter from Willem Jacob 'sGravesande to Sir Isaac Newton, 1721
From : JC’s PMAAMS? (pg 143) .. Jean Bernoulli (1667-1748) responded to 'sGravesande's publication. ...his Serene Highness
was quoted as saying to his ministers, that he believed the machine to be a true perpetual motion machine, and in addition,
it was so simple and easy to construct that he was amazed that no one had managed to invent a similar machine before Herr Orffyreus.
– letter from Jean Bernoulli to ‘sGravesande ..
Comment .. The one-way swingers assembly very easy indeed dax .. either as you say using off-the-shelf ratchet devices, or buying one-way bearings and fitting a lever-weight to them etc - it is absolutely no effort to prove that you can put your hand on the rim of a vertical disk with any number of equally radius spaced one-way swingers and give it a quick shove to full arms length ( while not letting it go ) - i.e. the 'pump and dump cycle' - some bottom swingers will swing up and latch on the pump gaining GPE, and some will swing up and latch on the dump also gaining GPE - at completion of that manual cycle test there is torque about the axle from the swingers GPE gained and wheel COM displacement overbalance ..
As stated it does not involve any overt MA and Law of Levers lifting - it requires 2 sequential Inputs of equal but opposite Momentums to the wheel disk - I proposed that the very first private wheel prototype used the external pendulum connected to an axle crank to achieve this Momentums Inputs by speeding up and then slowing down the wheel rpm ( 2 halves of 1 cycle ) ..
And could I have been able to reliably sim a one-way bearing action it would be easy to optimize the pendulum length and crank ratio and placements etc to find an optimal smooth sine-wave rpm pattern .. at this time it is not reliable but I will continue to work on it - I can build individual ratchet and pawls etc but that adds huge complexity to my sims which will crash them, hence looking for a proxy method that works and doesn't crash the sim thru complexity issues ..
But of course that is not the problem here - many will be waiting for me to reveal my MOI changer device that also pumps and dumps the system momentum by actively cycling MOI .. that will be my next step in this thread, as I explain my Toy's Page analysis resulting in my second and internal all-goes-around-with-the-wheel ( AGAWTW ) Prime Mover mechanism ( crosses, pulls, and weights ) - which has a more familiar feeling to the public display wheels with no visible Prime Mover ..
I have to say that my biggest problem here was always going to be explaining where the excess energy came from, and 90% of my thinking over a long time was around this - and why I developed the simple comparison sims with metrics that I shared to show that in certain 'local' situations energy can be effectively annihilated or manifested - knowing full well the potential ramifications to the COE Law and WEEP - as I said previously the math to tie potential COE 'anomalies' to earths rotational momentum and balance the books is above my pay grade ..
Saying it and showing it are one thing - to reset mine, let alone anyone else's thinking, to understand and accept the possibility is another thing entirely ..
Have a great Xmas and NY to all ..
