Gravitational shortcut
Re: Gravitational shortcut
JB: Countering the forces is possible but its the reset thats always the issue
True. But if it counter balances through 360 degrees then it doesn’t need a reset. It just needs a weight swap at different PE.
I get your point daxwc , look at the first couple of animations i posted they come from 360 degree capable designs , even my lever was 360 degree capable except i did not use 360 , torque is the same at the same opposed angles so 360 is not an issue .
Last edited by johannesbender on Sun Jan 26, 2025 8:53 am, edited 2 times in total.
Zhyyra
Post by Zhyyra »
Thanks for sharing some of the awesome work you have done JB.
Zhy
Persevere to succeed.
