Overbalanced wheels, a waste of time ?
Re: re: Overbalanced wheels, a waste of time ?
rks1878 wrote:Jim,
I supose this is just a nice way of telling me you are not interested in it, since updating the reader yourself, is easier than me doing the drill of making a gif and posting it.
Thank you for your sincerety.
robert
Robert, why do you jump to erroneous conclusions? Making a gif is easy. Reconfiguring my old computer after Adobe Acrobat screws everything up is much harder. I've been through that hassle a number of times already. It seems that every custom file reader program thinks it must make itself the default program to read all types of files. Then I must go back and reset everything back to how I like things. Each time it has taken me a few days to find and correct all my settings.
PDF files are great for the printing industry. They are lousy for use on the internet since a PDF made with a newer version seldom runs on an older version reader.
Neo
Post by Neo »
Jim or anyone can you please clear one thing up for me...If it where possible to restore the weights in a rolling ball overbalanced wheel to their original starting position, would the wheel continue to turn? Not in Theory but in practice.
The power of The One...
Jim, if you don't know about it already you might like to try Foxit Reader - it's a great little free PDF reader that doesn't screw with your system (no installation required to run it)...
http://www.foxitsoftware.com/pdf/rd_intro.php
rks1878
Post by rks1878 »
Jim,
I have let Adobe know about your problem. It seems very un-customer friendly for Adobe products to be doing that to you.
Everybody else: In Adobe Acrobat 7.0, and I suppose earlier versions as well, there is a clipboard viewer in the "Window" drop down menu.
robert
Robert (The Carpenter's Boy)
M
Post by M »
Techstuff said:
...there is no place On Earth to hide from gravity
Thats true !
I don't know if the research for gravity waves has been succesfull,
I haven't heard anything about it.
Up to now gravity can't be shielded. ( There may be some dubious claims )
Maybe this will never happen !
Interesting, that one can produce artificial gravity by rotating masses...
How would you shield a wheight at the end of a rotor from its centrifugal force ?
Wouldn't it be possible that gravity is only the result of a dynamic process ?
rks1878
Post by rks1878 »
One place to hide from gravity on earth, maybe, is one of those airplanes that astronauts train in where you see them floating around relative to the cargo bay.
I understand gravity eventually will find you though.
robert
bluesgtr44
Post by bluesgtr44 »
Rob...lol...Yeah, I bet that if that "controlled gravity situation" they created ever happened to be "uncontrolled.."...
Steve
M wrote:Up to now gravity can't be shielded. ( There may be some dubious claims )
I think you have things backwards. Gravity is the affect of shielding. When you have a big massive object such as the Earth blocking the flow of ether energy you get gravity. Gravity is a "push from above" caused by some of the "push from below" being blocked by the Earth.
This is just my Ether Energy theory, Think about it. It makes a lot more sense to me than gravity being some mysterious action at a distance.
ken_behrendt
Post by ken_behrendt »
I have done much thinking about gravity in my time. It is truly one of the most mysterious forces of nature even though it is the one we are most aware of.
In my model for gravity I imagine it as a force that results from the interaction between "streams" of subatomic gravitons that exit the surfaces of macroscopic objects at light velocity.
On the microscopic level, individual gravitons are continuously emitted from all of the subatomic particles in an object which has mass. The huge numbers of these particles being created per second then assemble themselves into discrete "streams" upon exiting the object. These streams, being composed of subatomic particles as, I believe, also are electric and magnetic fields, are not visible to the eye. However, these streams can be considered to have some rigidity to themselves so that if something deflects their outward "flow", they can relay force back to the object which is emitting them.
Outside of two objects with mass, their graviton streams will overlap and interpenetrate each other and this situation causes them to refract or bend each other from their normal trajectories. In my model of gravity, it is this mutual refraction or bending of the emission pattern of graviton streams from objects which then causes forces to be relayed back to the objects that will cause them to accelerate toward each other until they collide. That is, it is this mutual refraction of emitted graviton streams which creates the force we call "gravity".
Interestingly enough, this model can also rationalize the property of inertia that objects display. In this case, the acceleration of the object by an outside force causes its emitted graviton streams to bend away from the direction of the object's acceleration and this then causes a force to be relayed back to the object that resists its acceleration. This force increases with the mass of the object because a more massive object will be emitting more graviton streams from its surface than a less massive object. It is this force which makes an object "feel" sluggish as we attempt to push it and accelerate it in a given direction.
One really nice aspect of my approach to gravity is that it provides for the possibility of switching "off" the normal gravitational and inertial properties of matter. How? Simple. Just build a device into the object which can emit the complementary subatomic particle, the antigraviton, in sufficient quanties. When this is then done, the individual gravitons in the normally emitted graviton streams from the object will be strongly attracted to the individual antigravitons in the artificially generated and emitted antigraviton streams. Both types of streams will literally break up and form a shower of individual graviton / antigraviton couplets. These couplets are unable to relay any forces back to their source objects. The result? The source object will suddenly lose all of its gravitational and inertial properties. It will become weightless and inertialess.
This, of course, can have enormous benefit when constructing air or space craft. Did you ever wonder how those UFOs reported managed to display the kinds of astounding aerobatic performances that they do? Well, I'd say that they are probably already using this advanced form of gravity technology. Hopefully, we of Earth will soon have it available for our own use...
M
Post by M »
Yes, I like that ether theory, too.
And furthermore, it would give us a media for electromagnetic waves
Another question ( for me ) is where does matter get its energy from ?
Ether in that context could be the source, because it absorbs a part of it,
what creates a zone of under inflation around matter.
This graviton theory is littlebit complicated...
How should emitted particles create an attraction force ?
In macroscopic dimensions objects collide and then fly on in different directions.
It's affect would be more that of a push..
And where does materia get its endless energy supply in that case ?
Ken also mentioned Inertia in his theory.
The graviton streams bend away from the direction of the object's acceleration...
If an object moves with a constant speed, gravitons should bend away, too
( you said they were slow, and they must be slow, so slow that they bend away by the slightest impulse )
A moving mass in that case would tend to slow down and finally stop.
Don't know if Ether would stop the movement of an object...
Maybe Jim_Mich can tell us.
All matter is composed of ether energy. Matter is a standing wave in the flow of ether energy. If you have a smooth flowing river and made a wave that moved up stream at the same speed the water flows, then that wave would appear to stand still. It would be what is called a standing wave, because it stands still and doesn't seem to be moving. Unlike a river that flows in only one direction ether energy is three-dimensional and flows in all directions. Matter is a three dimensional standing wave in the ether energy flow. Matter is pure compressed ether energy.
Just like our world the ether energy world is very complex in that it has many frequencies and wave patterns. Magnetism is a spiral pattern where ether energy that passes through the magnet is caused to rotate. Imagine a fan in the middle of the magnet. As ether energy passes through the fan it gets spun into a spiral pattern. If you observe the spin head-on from one end the energy coming at you and the energy going away from you are both spinning the same direction. But if you turn the magnet and look from the other end they are spinning the opposite direction. When the energy hits the fan inside another magnet then it either hits the fan blades and pushes the fan backwards, or it passes through the blades because they are spinning the same direction and excess ether energy from the other direction pushes the magnet.
I use the term 'energy' when talking about ether energy because it is the closest English language word I can find to describe the multi-speed multi-directional multi-frequency multi-pattern vibrational forces about which I speak. It is quite probable that there exist living beings that are composed purely of ether energy. It is also highly probable that the essence that gives humans the ability to think and remember is an ether energy entity that comes and resides within the human body until it is released by a process that we call death.
These are just my opinions. I will not try to coerce anyone into thinking my way.
graham
Post by graham »
Possibly an eternal soul . An existance before birth , and after physical death .
Wheeler
Post by Wheeler »
What I see is particles coming from the solar wind, or direct from the sun.
Simple and clearly available for use to use.
Jims theory almost matches my theory.
It was a bit of a surprise to me that you would suggest I send you information after your continued support of the process normally taken and you always point to in Patent it yourself.
JB Wheeler
it exists I think I found it.
Jon J Hutton
Post by Jon J Hutton »
Jim,
One of the most interesting reads on the subject of magnetisim I have done is on the guy that made the corral castle. The latest theory is the guy using magnetisim levitated rocks weighing many tons....anyway he wrote a small book also available by web search on over 2 years of experiments on magnets....it is incredible interesting. He tells of a way by using a permanent magnet to store electricity......a recent rebuild of his storage device proved it to work.....If you have never researched corral castle it is well worth anyones time. He wrote other books but the one on magnetisim is the most credible imo.
jim_mich wrote:Gravity is the affect of shielding. When you have a big massive object such as the Earth blocking the flow of ether energy you get gravity. Gravity is a "push from above" caused by some of the "push from below" being blocked by the Earth.
In that case the earth can block the sun's gravity, so you will be heavier in the afternoon and lighter at midnight...or reversed, don't know it yet; at least there should be weight differences
but hmm, something tells me this is not right.
Maybe gravity (graviton) is energy trying to spin faster than the speed of light, and in doing so is contracting space?
