I found this today:
http://www.nets.pl/~metozor/metoz.html
It's a hydraulic machine by Polish inventor Zygmunt Orlowski.
max
METOZ
re: METOZ
There is an error in logic. I did some quick calculations. The distance which one cylinder drops is not the same distance which the other cylinder rises. So during deflection fluid moves out of the area above the pistons and into the atmosphere area. During straightening fluid moves out of the high pressure tank and into the area above the pistons. It will work until the high pressure is used up.
In other words it's a hydraulic motor running off of the high pressure.
re: METOZ
Jim...
the inventor claims in the explanation that both pistons surfaces are equal. Also the mouvement distances are the same. System is hermetic - only one of two valves are opened at once and the water is not compressible. There are no pressure losses (inventor claims).
I think there is a larger site about this in English:
http://freeenergynews.com/Directory/Gra ... index.html
max
max
