Cosmic Energy Electricity Generators
- LustInBlack
re: Cosmic Energy Electricity Generators
Tseung: What is your purpose in life!?
I have now got permission from the Company Yuen Fat Development Ltd. of Hong Kong to show pictures of the prototype that is already in USA.
This prototype will be tested by at least two famous USA universities well before October. If things go as planned, the prototype will be shown in St. Louis at the Renewable Energy Conference.
Here is the picture and my planned introduction speech.
Have fun.
Have fun.
- ThirdGen.doc
- My planned introduction speech in Oct.
- (21 KiB) Downloaded 403 times
- MrTim
(What's with all the batteries...?)
I have consulted extensively with my esteemed colleague Dr. Mindlebender (Ph.D, Ph.M., B.S., OBE), and according to his astute (and always 100% accurate) findings, the electronics used in your motor are flawfully overdesigned and can easily fall victim to a fatally massive ESD (Electro-Static Discharge) that your device will spontaneously produce (which is why it shall irreversibly fail.) In his respected opinion you should immediately switch to decidely simpler (and more coefficient) vacuum tubes, which have more robustness and are not as prone to lurking ESD failure before you attempt what could turn out to be a catastrophic public demonstration. Also, Your device does not appear to be ISO 9000 compliant. That standpoint alone will be extremely unacceptable to the exigencies of the engineering community, whom you woefully seek to overwhelmingly convince otherwise....
This is the First Generation Cosmic Energy Electricity Generator from Mr. Song. It was first video taped in Feb. 2000. This invention and the second one won the Gold Award from the Chinese Patent Office in 2005.
The working principle is rotation of partially shielded magnets that cut the horizontal component of the magnetic field of the Earth. It consisted of 3 cylinders. The first one generated enough energy to drive the second one. The second one generated enough energy to drive the third one. The third one generated 400 watts - enough for demonstration.
This particular prototype would go direct into a Science Museum, as it had no commercial value.
- LustInBlack
Why did you modify that last picture ?!
This is the Second Generation Cosmic Energy Electricity Generators from Mr. Song. It was also videotaped in Feb. 2000. This invention and the first one won the Gold Award from the Chinese Patent Office in 2005.
The working principle is rotation of partially shielded magnets that cut the vertical component of the magnetic field of the Earth. In addition, the rotating cylinders also cut the gravitational field of the Earth. It generated 20,000 watts. That was a big surprise to Mr. Song who did not understand the theory at that time.
This prototype kept “burning the electronics”. It had no sensing mechanism to reduce the Pulse Force when the external electric load goes down. It would not be shipped to USA as we do not want the machine to burn up in front of the World.
The picture shows Mr. Song with a Reporter and a Camera Person. The person on the RHS is Mr. T. F. Song.
This is the famous Dr. S. Y. Liang car. It was videotaped in Sep. 2003.
Note the size of car engine compared with the size of the car. This particular car engine shown next to a Marketing Manager was 28Kg and could generate 188 HP.
The car engine used ICs. The major problem is in going uphill. The power rapidly decreases with the angle as the principle is cutting the gravitational field of the Earth.
The effort is now focused on using this as a Electricity Power Station. There will be no need to tilt the engine.
The videotape will definitely be available in St. Louis but the actual car is only a "may be". The inventors are working on the 5th generation that would have no problem climbing uphill.
This is a variation of the Cosmic Energy Electricity Generator. It uses the ions in the air as fuel. The Inventors are Mr. W. K. Chan and Mr. M. C. Kwok. The operation is as follows:
1. When the device is turned on, it would start the action of some catalysts to create ions.
2. It will also pump air in and out and lead the ions from the air to add to the created ions. Positive and Negative ions are separated.
3. If the density of ions is high enough, cause the ions to recombine to generate electricity. Internal Spark will occur. Thus this invention is nicknamed “Lightning in a Box”.
4. We can think of the machine as providing the ignition and uses ions in the air as fuel. It could generate 1,000 watts.
5. This machine was presented to the Senior Officials in Beijing in October 2005. It also suffered from unreliability. The Electronics kept malfunctioning and the continuous operation could only be maintained for a maximum of 10 days as of July 2006.
ROTFL - wipes tears from eyes. Pitiful Photoshop, but hilarious stuff! - LOLThe car engine used ICs. The major problem is in going uphill...
I've been studying the information supplied by ltseung888 quite closely. Using some easy to find supplies I have constructed a simple generator based on his 'child on a swing is over unity' theory. It is now powering my whole house.
I also believe that a child playing on a see-saw could be an example of a time travel device.
I have attatched an image of my generator. Please note that you do not need a child to generate power but you will achiece a Baby Power Unary Induction Boost of 1.5 if a child is used.
Hey dummy! put the motor in the car cross ways, it will not know if it is going uphill or down. Just do not drive around corners or mountains with sloping roads, :0)The car engine used ICs. The major problem is in going uphill. The power rapidly decreases with the angle as the principle is cutting the gravitational field of the Earth.
Is it possible to move this thread to the 'Jokes" section?
LIB, keep up the good humorous input.
- LustInBlack
Hahehaha ..
I appreciate the input Ralph ! 8]
But Damn ! That guy could walk 1 thousand miles just to distribute the good news....
He should build himself a plane and fly here in canada so I can see his electrical motor using 4 batteries as a power source.
Btw, I wonder how much time it takes before his motor goes ballistic and sends a coil right into my eye .. I bet he built a force field just for that..
- LustInBlack
Some might be interested in the second website of Lawrence Tseung :
http://www.geocities.com/goldfield001/
After seeing the car picture and the flowers, it made some sense (goldfield).
Still, this website is quite strange, the powerpoint documents talk about making money by advertising .. And there is this comment : "Technical details will not be explained" ..
To LustInBlack
Great. You found the other website on Fluid Mechanics. I like to focus on science and not personalities. I do not care whether Joe Newman married an 8 year old or an 80 year old. I do care whether his machine works.
In a way, I enjoy the humor from this forum. The discussions with the Professors are too serious and too dry. Make more fun.
The other website also shows that scientists could have been wrong for centuries on the concept of pressure when the fluid is in motion. Pressure has been regarded by scientists as a scalar quantity – meaning that it has no direction.
However, scientists carried the same idea to moving fluids. It totally contradicts our common sense observation that wind exerts different force in different direction. To be more exact, a cube of gas can have different amount of gas molecules coming in and out at each of the 6 surfaces. Thus the existing scientific theories of Fluid Mechanics might be in error. Do not have blind faith in Scientists including myself.
An accidental experiment done on that site led us to the path of Extracting Energy from Still Air. From that, we advanced into the much more challenging field of Extracting Energy from Cosmic Energy Sources – including still air, floatation, gravity, magnetic, electric etc.
The true scientist should always challenge the existing theories scientifically. Re-examine the underlying theories and accepted assumptions.
In the case of the Bessler Wheel, the First Law of Thermodynamics or the Law of Conservation of Energy is NOT wrong. However, scientists did not see the fact that Gravitational Energy could be lead out in the case of the pendulum under the action of an External Pulse Force.
- LustInBlack
Well it's impossible to tell from here if what you say is true or not.
Unless, you prove it by simulation into WM2D, it's possible to see a result.
Or unless you come in canada and make a demonstration with a dyno.
And please, build your model into wm2d so we can see exactly what you are talking about .
