found a way for offset ballance by holding one----------
Wheeler
Post by Wheeler »
Hello all
I just found a way to fix the offset balance
on a dryer.
Here it is:
Lay on your back, and open the dryer door.
Now put your foot on the edge of the opening and push up.
The dryer will pick up easily because of leverage.
Now it is easy to spin the threaded bolt legs up or down, because you can hold the dryer up 2 inches or so.
Warning;
Don't push too hard, cause you might pull the vent hose off.
Ain't that cool! No tools required.
JB Wheeler
it exists I think I found it.
Oxygon
re: found a way for offset ballance by holding one----------
Post by Oxygon »
Wow, that was random
But, I see your point.
Wheeler
Post by Wheeler »
Thanks Ox
Im working on a way to do the same to the washer, but without any tools, it is a hard one.
Anyone know a way to do this without holding it up with one hand?
If I can crack this one, I may go to more complicated things.
PS she also wants the lights fixed in the living room, but as you know Bessler research first then lights when I get some free time :)
JB Wheeler
Sounds like a job for a pry bar.
winkle
Re: re: found a way for offset ballance by holding one------
Post by winkle »
Wheeler wrote:Thanks Ox
maybe a fulcrum with lever on top
it might be that if you jump on that lever hard enough you could get a couple of spins on that warsher
maybe get some wheel ideas
you know kinda kill two birds with one train wreck
the uneducated
JB,
Most washing machines only have adjustable legs on the front while the back is considered "self-leveling after getting the front adjusted.
Put one overly fed house cat in washing machine and set for the spin cycle. This will provide you with the out of balance pulsation that will take the weight off of the front legs. Adjust, as it is jumping up and down.
Note this may take more than one spin cycle, but do not worry, cat will not mind as long as you do not open door.
If you do not have a cat, I have one that was dumped on me by an in-law that I would be more than happy to loan you!
Wheeler
Post by Wheeler »
I not sure I can trust you guys
Jim
(Sounds like a job for a pry bar.)
winkle
(maybe a fulcrum with lever on top
you know kinda kill two birds with one train wreck)
(Put one overly fed house cat in washing machine and set for the spin cycle. This will provide you with the out of balance pulsation that will take the weight off of the front legs. Adjust, as it is jumping up and down.)
I thought about all three ideas and I really didn't want to put out any work to do it.
Then it came to me. Or should I say I caught the idea Ralph suggested!
We have two cats
I like one of them:0)
JB Wheeler
mickegg
Post by mickegg »
If you have enough room to the front of the machine you
could try using a garden fork as a lever.
Insert the tines under the front lip and gently raise the handle.
A wooden block might be useful under the raised handle to hold it in position.
Put an offcut of timber WIDER than your hand under the lip as a safety
measure while your fingers are underneath..
A great craftsman would be that man who can "lightly" cause a heavy weight to fly upwards!
Take care!
Mick
winkle
Post by winkle »
just remove a few walls and you could get at it with a forklift
the uneducated
LustInBlack
Post by LustInBlack »
Remove the door and use it as a lever.
Less weight to lift !
Wheeler
Post by Wheeler »
Good idea but then the door is broke.
Remember think before you act!
I like the fork lift but some of us don't have access to one. (I didn't go for the washer/dryer/forklift option when I bought them).
We must find a way to adjust the legs using our own body as the leverage tool.
I hope to find the answer. If I do I will post a photo.
JB Wheeler
LustInBlack
Nah you don't break the door, you use it between two cushions, good as new!
Forklift stinks
Wheeler
Post by Wheeler »
Yea but!
ya gota put the door back on later to use the washer.?
I think I have an idea!
But first I want to try it.
JB Wheeler
A resourceful construction worker would never be seen without his OSHA approved steel toed shoes on.
Simply tip the top of the washer back and stick your toes under it, meanwhile the spouse does the leg adjusting.
Steel toed shoes can very handy for many uses, I find them great for lifting 4X8 sheets of MDF. Simply set it on your toe and then you can get your hand under it.
Wheeler
Post by Wheeler »
I wanted my girlfriend to try what I thought might work, and get a photo of her when she did it, but she said;
(IM NOT DOING THAT)!!!
So I may have to try to take a photo of myself while I do it but the effect would of been better if she did it.
Ralph I know about the steel toe, but remember no tools!
Leverage is the answer though.
JB Wheeler
