Supplies
Flywheel
Supplies
Post by Flywheel »
I'm interested in building a Universal 6 ft in diameter wheel. Does anyone know where I can buy big sheets of hard clear plastic? I'm hoping to have the rim be solid and the 2 faces of the cylinder be clear so that I could observe what's happening on the inside.
Also does anybody know where I can buy small dense weights? Perferable a type of store cause I don't want to pay like a million dollars worth of shipping.
re: Supplies
cannot help you on the plastic, as for weights I suggest the following.
I am sure that your home state has a number of metal recycle yards.
At least once a month I cruise through one of these local establishments.
Some of these also sell and fabricate new material. If I cannot find what I need in the junk pile, they let me pick up small pieces from their cutting stations.
Round, flat, bar rectangle, it is all available. When I built my flywheel it had a 2-3/4" axle bore. I picked up from their floor two pieces of 2-3/4" stock for $1.50, brought them home and center drill a !" hole in them for reducer bushings.
Another trip produced 20 8" four spoke aluminum hand wheels such as found on a table saw for raising and lowering the blade. For these I paid $1.00 Ea. Avoid copper, the scrap price is compatable with pre-1970 gold prices. Lot of copper wire theft in my area.
re: Supplies
Call an architect from the yellow pages & ask him where you can source sheets of acrylic. As for small dense weights. I have found a couple of industrial wheel & pulley suppliers. They specialize in supplying all sorts of wheels & pulleys for commercial applications. Hand operated fork hoists, trolleys, gurneys, car jacks, etc. They have shelves of metal wheels of all sizes & weights, some with bearing, some just pre-drilled depending on intended loading. One set of V pulleys I got form an industrial electric gate manufacturer.
Alternatively make your own from recycled lead melted with a butane burner & cast into a mold of some sort. I source my lead from dive & fishing shops.
Flywheel
re: Supplies
Post by Flywheel »
Lucky for me next weekend is bulk waste day where people throw away huge stuff that normally the garbage men wouldn't take.
About the lead weights, isn't lead a little expensive, and isin't melting lead hazzardous to your health?
jupter
re: Supplies
Post by jupter »
for dense weight try a tool shop they should have scrap pieces.
carbide is very dense and needs diamond wheels to cut it.
a shop that makes cutting tools would be the place.
wheelmaster
re: Supplies
Post by wheelmaster »
Let your fingers do the walkin. I looked up and called every machine shop in my area. A couple allowed me to go through there scrap pile and take whatever I wanted.
As for the plastic well that sounds expensive. Also metal weights scratching on the sides would make it look bad over time.
"I then reminded him to harness the horse in front."
- Johann Bessler
Flywheel
re: Supplies
Post by Flywheel »
thanks for all the replies!
I had to scale down my wheel to about 2 and a half feet in diameter due to budget, good tools, and space.
1 whole side is plexiglass and I'm going to put some sarann wrap on the inside that I can replace once in a while, so the plastic shouldn't get scratched up that much.
so far I've made both faces of the cylinder, and I want this wheel to be 3 inches thich, does anyone have an Idea for how I can make the rim? I don't have a wood steamer and I want to be able to put notches into the rim. Thanks!
