quantum pendulum idea from a nut case
this nut has this theory, but also i have heard of a few people replicatring his rv over unity motor so its hard to tell, jim might enjoy this bit of info, ill leave his details of his over unity device at the end
the nut cases idea
'Take a 1 inch PVC pipe, orient its ends towarn N,S poles take an string and a 4 onz weight you can slide up or down, tie string to top of pipe swing it and adjust it to swing from east to west ..
If you adjust it to 1.6 cycles per second it will never stop as it will feed on earh rotation charge ....
as pendulum swings to the east it takes energy from earth rotation to the west as it goes up and mass increases as it swings back it takes extra acceleration in its swing toward the west and mass decreases gaining height each times it suings until it reaches 1.6CPS sincronizing with earth motion subharmonic ..
dont Screwed planet earth giving this away .. as all is needed is calculate pipe circumference weight mass and cord lenght ...
energy used can stop earth rotation .. if used in great quantity..Looks like a joke but device works , its called quantum pendulum ..
secret is string tries to wrap around pipe as weight goes east gaining kinetic mass and energy from earth movement west as tries to go into ascending spiral (logaritmic)toward the east Earth rotation serves as energy pump to the pendulum motion wile earth reduces rotation proportional to the pendulum energy gain .. infitesimaly small , but built a billion of them with a few trillion tons of force
they can truly "rock the earth"' -end
hectors device
is here
http://www.theverylastpageoftheinternet ... verter.htm
first prototype used to test a 3PH generator–rotoconverter combo,Power input: 240 W to Prime mover (Being touch by unseen witness at left) .
Generator required 380W for excitation at 120VAC (Being touch by my person).
the nut cases idea
hectors device
is here
re: quantum pendulum idea from a nut case
im not game to try his pendulum idea..
if any body else can please let me know.
i just found a follow up to this with a bit more of a description..
That is in the basic manual study of how civilised worlds destroyed
themselves in early evolutionary development using gravity wheels
& giroscopic energy capture.
as the menacing giroscopic thrust is affecting earth now, the
verticaly mounted machinery and non- ecuator oriented rotation is
messing up earth rotation if something can cause polar shift is the
chineese Dam 16, million pound each vertical rotor generators &
hydros ..
Who needs quantum pendulums when you can have other safe
methods .. True, generators and rotating machinery shafts
are better oriented in a shaft north south orientation , if you go to
any motor machine shop you will notice big motor bearings are allways
worn in the gyroscopic pressure point earth rotation produces ..
no such wear is noticed in properly oriented machinery ....
rotor top must rotate toward rising sun (east ) and bottom toward
west ... its funny but you truly spare a few extra watts doing
that ... ( and lower your bearing maintenance cost ) stabilizing
earth on the way ..
A rotor spining that way also will weight less in relativistic terms
due to low virtual ballistic orbit and centrifugal vertors relative
to earth rotation and gravitic flux ..
Just compute the factors , you will see I am right ...
as funy as it sounds keep this notes as the future science will
prove me right in every word I have said ..
Gyroscopic dissruption of earth rotation is more dangerous than
global warming or any other menace earth had faced ... as we can
loose our moon & invade venus orbit ....
hydros ..
earth on the way ..
- MrTim
Re: re: quantum pendulum idea from a nut case
Well, heaven forbid if all the rotors were rotated the opposite way. Why, they might just speed up the Earth, and we'd all be flung into space!epistemologicide wrote:i just found a follow up to this with a bit more of a description..
earth on the way ..
jonathan,
what does he mean ''Take a 1 inch PVC pipe, orient its ends towards N,S poles take an string and a 4 onz weight you can slide up or down, tie string to top of pipe swing it and adjust it to swing from east to west ..
whats the pipe doing swinging around a magnet gate around the north and south, or just swinging with the string holding it in your hand?
can any one draw a picture?
i cant understabnd what he means by orient?
m-w.com: orient: 1b: to set or arrange in any determinate position especially in relation to the points of the compass
I think he is hard to understand because he is nuts Epi, but I'll humor you. This is what I'm guessing he means:
- pendulum.JPG (1.94 KiB) Viewed 21724 times
hang on why is north pointing side ways? shouldent it be up?
being west?
and how do you adjust the revolutions to swing in the paramenters hes suggested? with your hand?
im still un clear what he means.
being west?
The picture is 3D, we're standing up and looking toward SE. You get it to swing at 1.6Hz by having the string be 9.7cm long I guess. He's crazy Epi, you can't make sense of it because he's crazy!
i still havent got a clue where to start. how to configure the poles etc, or the pipe. ill mail him and try and get clearer instructions.
guys can any body resolve some clarity on this, i emailed hector with the full details and description provided by jonathan.
here is the response i got.
Is west- east string winds itself in ROUNd circle as pendulum
descript orbital path in 1.618 spiral toward circle center proportional to its radi.. one inch steel ball strung in 1.5 diameter circle
swing to wind on horizontal to it from west to east as it does it
gains energy from earh rotation and does not stop, just need to adjust
distance from 8 to 12 inches.
This is a way to interpret it (though of course it means nothing since he can't form even the simplest sentence): the pipe is stationary, and the weight hangs from a string. When the weight swings it follows a lop-sided path.
- He'sCrazyEpi.JPG (1016 Bytes) Viewed 21582 times
- Pipe Swing animated by Jim_Mich
- PipeSwing.gif (44.23 KiB) Viewed 21635 times
That's what I was trying to show, yes.
i still have no idea how to build this. whats new :D lol
guess its another thing ill have to ask sevich about and or and engineer...
Hi Epistemologicide,
the construction can not work, because there is no disturbance(oscillating force) force. When the weight is turning, like a turning cylinder, and rolling against a courved board, then in will work. So the disturbance force is absolutely neccessary. I will sent you an email showing the curved board.
the future has begun
