A gravitywheel with just strings and weights!!!
re: A gravitywheel with just strings and weights!!!
raj wrote;
I would very much appreciate to have your comments coming in here, just to make this waiting easy for me.
P.S I am only waiting for my patent application filing date and Application Number, as a safeguard for my idea, before making it public.
You need not feel alone, I am also awaiting patent info from Kenya Africa. Not on my own design but of a Kenya resident. I am beginning to believe the word 'expedite' is not in their dictionary!
Ralph Lortie
greendoor
Re: re: A gravitywheel with just strings and weights!!!
Post by greendoor »
raj wrote:Greendoor mentioned force x time as compared to force x distance. I believe there is something in here to do with my design. My physics knowledge is poor, even though I am a MATHS graduate. Can somebody explain the difference between the two entities.
Would there be a time difference between a weight fixed to the rim of a vertical wheel moving downwards 45 degrees with the force of gravity and the same weight swinging on a string through 45 degrees.
Your answers are crucial to me at this point.
Hi again Raj. From studying this site, you will see that my personal theory (regarding Gravity being the source of motive power, 'accumulating' Momentum, etc) is not necessarily respected around here. I have been very influenced by Pequaide, who I respect very much, but others also have issues with his theories too.
Which is fine. There are several other members who have their own theories of how excess energy can be created, and these could possibly be valid too.
There are also some outright skeptics who have nothing positive to add, and it's debatable why they frequent this site.
There are ways of categorising different personality types, and how different people approach the same problem. Its very interesting to see different strong personalities approaching this Bessler problem, and there are strengths and weaknesses with all different approaches.
If there is any truth to any of the various theories, I suspect that they may turn out to be different ways of describing the same thing. Just as Momentum is Mass x Velocity, but can also be described in terms of Force x Time. It isn't immediately obvious that these are the same things and directly related, but it can be shown with mathematics.
So take what I say about Force x Time with a grain of salt. But I do believe there is a solid Newtonian logic to my preferred theory, which gets confused when we try to convert everything into the more modern terms of Energy and Work.
To answer your question, from my biased viewpoint:
Yes - there is a huge difference between a weight fixed to the rim of a wheel, or the same weight swinging free. The fixed weight is forced to accelerate the wheel - and therefore the force of gravity acting on that mass is diverted into accelerating a greater total mass. For this reason, it will move slower than the free-swinging weight. BUT - in my view - a slow fall means that the force of gravity is available for a much longer period of Time before it has to climb back up again. Although the final Velocity of the wheel is slower, the amount of Momentum acquired during the fall is much greater.
For some reason, not everyone here is of the opinion that larger amounts of Momentum are useful. Despite the law of Conservation of Momentum, and the fact that we can transfer momentum between different masses and achieve higher or lower velocities with correspondingly lighter or heavier masses.
I would suggest everyone get very familiar with Newtons Cradle and Impact theory - especially between dissimilar masses. And then compare with the Bolas principle, and the yo-yo de-spin principle. They are significantly different, even though they are all methods of transfering momentum from one object to another. The difference is Force x Distance compared with Force x Time.
Ultimately - in a working Bessler wheel, we need falling weights to develop more Energy in falling than they need to rise and reset again. Conventional physics can't see any way of doing this. Personally, I believe the secret is a Slow Fall (acquiring more Force x Time) followed by a Fast Rise (using less Force x Time).
Pequaide's thread about Creating Energy in the Lab goes into a lot of detail about the basic theory required.
raj
Post by raj »
Hello greendoor. I believe your theory is promising, at least with regards to my gravitywheel design.
When I conceive this gravitywheel idea, I was using only my logics to solve a problem. You see, I enjoy working on things impossible.
The problem I was solving was how to make some weights change their positions on the wheel before the rest of the weights, which would have an effect on the center of gravity. This would reset the weights earlier than they would otherwise reach equilibrium.
This, I am sure, relates to Force x Time instead of Force x Distance.
And my gravitywheel design is looking very good to me.
Logically speaking, your theory makes good sense to me.
Trevor Lyn Whatford
Post by Trevor Lyn Whatford »
Hi raj,
not just string and weights, I have looked at this and found that rope is good for taking the weight out on one side of the wheel but I use wheel segment, shaped weight catch compartments to roll the weights back towards the axle on the other side! this design puts the weight onto the rope at just past 12 O,clock which puts the weight onto the ropes fixing position at the outer rim of the wheel then at 6 O,clock the rope become slack and by 8 O,clock the weight has rolled back to what I call the weight catch.
I have not had the time to build a full wheel, but I have built a quick 2 weight wheel that came to rest with the rope side at 5 O,clock so it may even work?
Looking at the drawing of a 18 weighted wheel there is still a geometry problem wherein there are only 8 rope suspended weight on that side but 10 weights on the catch side, but as the rope is connected to the wheel at twice the distance off centre to the weight catches side it is in my view worth building a six foot wheel I will let you know if it works.
This is pat pending GB0904074.2 filing Date 10th March 2009
raj
Post by raj »
Hello Trevor!
I do not think that strings, ropes, wire or chains matter so much. It is the free swinging ability that matters.
I would have loved to see to design, if you could post it here, since your idea is already protected by your pending patent application.
I am only waiting for my patent filing date and patent application number, after which I shall gladly show my design to the world. Then I shall quickly know if my design is really worth something. My patent application is only to put my idea on official record.
Incidently, the first time I started some thinking on Perpetual Motion Machine was in England as an Open University Student in 1977.
Trevor Lyn Whatford
Hi raj,
I will build it first then I will you tube it even if it does not work, as you will all see why it works or why it does not work, the biggest problem is ego as in the past some of my builds have been very nieve.
What we should all do is show our mistakes and show why they did not work to pool our Knowledge of what does not work to stop a lot of people going over old ground and bring a working model closer as we build on the pool of Knowledge, hopefully I can start the wheels turning with this one (pun intended).
Trevor wrote:What we should all do is show our mistakes and show why they did not work to pool our Knowledge of what does not work to stop a lot of people going over old ground
LOL Telling someone that their idea will not work is useless. They will never believe until they build it and learn first hand.
Read Principles of Unworkable Devices. then browse the The Museum of Unworkable Devices both by Donald E. Simanek. You will find most any PM idea there.
Trevor,
I agree with jim_mich.
It is always a 'newbie who is dead set that they have a runner, they do not take the time to review what has already been tried as they are self sold on the fact that theirs is a winner.
I have been known to offer tutorship to those showing aptitude and the desire to learn. It usually starts with them sending me an idea that they are sure without doubt is a runner.
I can tell them that it will not work, if they question my opinion, I highly recommend they build it. It is the only way they will clear their doubtful mind freeing themselves to advance their innovative skills.
Trevor Lyn Whatford
Hi jim,
I agree with what you are saying, but the idea of a failure pool was to stop people thinking of failed designs in the first place thus there would be no reason to tell them anything as they could see for them selves.
Trevor Lyn Whatford
Hi Ralph,
I see you still have your sense of humour!
raj
Post by raj »
Hello everybody. I appreciate reading you in here.
My design is the simplest of all designs I have seen on the net ( after hours of searching). The nearest design in simplicity is Besslers' MT 19.
From what I have learnt, I know that Bessler's wheel was a very simple machine that even an apprehentice boy could have built it by just one glance at it. Even Bessler is on record saying that his idea is so simple that his asking price for divulging his secret would not be justified.
Most of the gravitywheel ideas on the net look far from that simplicity that Bessler presumably achieved.
My design uses only strings and weights, and it does have to be a wheel in that sense.
I feel one could tell whether it will work or not just by looking at its design with an analytical mind.
The secret, if you might call it that, is as greendoor has mentioned is the time factor of each weight takes to change position on the wheel, as it rotates.
But this just MY IDEA, right now. The result of all this suppositions need to be analysed.
And I shall need all of you to do that for me.
greendoor
Post by greendoor »
Raj - I suspect that the principle is very simple, and once recognised we will probably see this often in Nature.
The perpetual motion of the stars & plants, the perpetual motion of the atoms and molecules probably work on the same principle.
Man-made machines tend to constrain forces into very simple geometrical shapes, which is probably why we haven't discovered PM yet. Natural motions are hardly ever simple geometrical shapes (perfect lines, perfect circles, etc). The way flowing water behaves fascinates me - you would think that linear laminar flow would be the natural way for water to flow, but it seems to prefer swirling vortexes and clusters into coiling strands ... each water molecules being acted on by numerous forces and taking the path of least resistance ...
Simple designs are likely to have the least friction ... bring on the simple designs!
JuBragg
Post by JuBragg »
Hi Raj,
the best advice I can give from someone who has had many ideas that have worked but never a gravity wheel is to watch the centre of gravity in the top and bottom halves.
Most designs are fine in giving extra weight to one side, such as the drawing linked by Jim-Mitch above, but just looking at it you can see that the majority of weights in the bottom half are in the outer edge of the box, while those it the upper half are on the inner edge, therefore the centre of gravity is way below the axle.
JuBragg
Post by JuBragg »
raj,
I referred to the posting by jim-mich (sorry, the spell check prompted me to put a 't' in it), on page one.
raj
Post by raj »
I am pleased to announce that I shall post my gravitywheel design and full description of how it would work in the next 12 hours, in a new thread.
I do not honestly expect it to go with a bang. I am prepared to told that it is just a fizzle out.
So please, all of you. Look at what I am proposing as a possible gravity wheel, and pour down your comments.
See you all on my new thread.
