under your nose
Ray Duku
under your nose
Post by Ray Duku »
is obvious that the sole person who is doing innovative work and sharing it is nicbordeaux in his post in the thread will JC publish his secrets he give you three potential PM yet you do not see because you do not want to.
C'est pourtant evident.
re: under your nose
Hmmm...
I wonder why your IP address matches nicbordeaux.
Cant be him though as it is against the rules and no pole was started 8))))
Sock Puppet??? Somebody is in trouble...
LustInBlack
re: under your nose
Post by LustInBlack »
Poor thing.
Ray Duku
re: under your nose
Post by Ray Duku »
OK
nicbordeaux
re: under your nose
Post by nicbordeaux »
How does one "resign" from this forum if one wants to ? There doesn't seem to be a "delete my account" option, were one to want to use it.
Know what, I thought there might be some intelligent people here, willing to share knowledge, and accept that they don't know everything, therefore be open to suggestions. There are some, but they are overwhelmed by a few bullies who get upset about the pecking order. Quite honestly, none of the regulars here stands even the most remote of chances of ever building anything of use, it's really sad, and the only solace I have for having dropped ideas is that maybe out there amongst the least vociferous of the members somebody with an open mind has got a grasp. Also of solace actually is that the bullies with the loundmouths wouldn't know OU if they stepped on it so even if they were carpet bombed with blueprints of a working device, they wouldn't recognize it :)))
So basically, to any AH's trying to pick on a particular member, just remeber this : you are of absolutely no import or significance whatsoever :)
Ciao
LustInBlack
re: under your nose
Good Bye then (Raie Du Cul) .....
Ray Duku
Post by Ray Duku »
If you run brain.exe / think it appear to you that there is more than one member in a family using computer ?
LustInBlack
re: under your nose
Ton nickname est tout autant stupide.
If a second member of a family signs up for a second account then their first posting should be an introduction such as, "Hey, I'm whats-his-name's mistress. I think his ideas are super great!"
Otherwise one of the first things that are looked when a new member arrives is their IP address to see where they are located. If they post from the same IP address as another member then they are most likely using the same computer, and are usually a sock puppet.
LustInBlack
re: under your nose
This guy is french Jim, and his nickname is translated to : "ass crack" ...
neptune
re: under your nose
Post by neptune »
@Nicbordeaux. Non Illigitimus Carborundum .{ Dont let the B@stards grind you down ] I personally value your original ideas , your practical experiments , and your bohemian sense of humour. I believe I am not alone . Please do not resign.
MuffinMan
re: under your nose
Post by MuffinMan »
I would like to second that.....not that I understand everything Nic is talking about at times. I do appreciate the alternative point of view which is opened up from Nic's posts.
"There is no such thing as coincidence....be well"
re: under your nose
Everybody gets frustrated with this quest from time to time, some even get overwhelmed, some feel underappreciated or undervalued or misunderstood.
Most want some level of respect from a community if they want to be part of it long term - the choice is yours, stay or go - nobody holds a gun to anyone's head demanding you stay - if you want to stay & gain a measure of respect then be sincere, clearly articulate ideas & arguments [to the best of your ability], use drawings & pictures, or video's, to enhance your descriptions & ideas & get your message across - help analyse & focus others thoughts by making meaningful comment on other community members ideas [perhaps less articulate or developed than your own] - these are no guarantees that any ideas or seeds sown will take root however, even if you think you have ploughed the furrow & prepared fertile ground - it's just as likely to prove barren for the majority of ideas - that's because there is not a critical mass behind them i.e. the thoughts or arguments have not been persuasive or conclusive enough to motivate people to contribute or build experiments based on your ideas - they probably need further work & development.
Many here, including myself, take a hiatus from this site & quest from time to time [I note Martin's thread this morning & completely understand his conflicting pressures] - whilst this is a serious hobby most of us have to make a living as well, so we contribute & do what we can, when we can, & we have family's who can get marginalized quite easily, so it's important to maintain perspective.
If you want to have an idea taken seriously then just think about two things before presenting your idea, it will save time & angst.
1. what is the source of the energy that will make this wheel rotate ?
2. can I provide a proof of principle experiment to show the excess energy that I will liberate ?
If you can do those two things you will hold the floor - if you can't do at least one of these two things then your idea is likely to be lumped together with the other nefarious ideas that never made it to critical mass.
Eventually someone, somewhere in the world, will propose & build an experiment that is conclusive proof of free energy - I look forward to that day, then I'll take a rest before looking at ways to improve the principle & performance [if I can].
Gregory
Re: re: under your nose
Post by Gregory »
LustInBlack wrote:This guy is french Jim, and his nickname is translated to : "ass crack" ...
Lol, good one.
