@ All who likes to play with magnets.
Magnetic manipulation.
A few simple test, using low carbon steel and nylon spacers for magnetic shielding and steel alone to achieve total repel.
http://www.youtube.com/watch?v=d0d_wTHPvy0
shielded magnets from repel
http://www.youtube.com/watch?v=5oqH4F_PNjs
total_repel.AVI
http://www.youtube.com/watch?v=jmPd3AOfsDw
total_repel3.AVI
http://www.youtube.com/watch?v=v62E_cNeOJI
Several simple test can lead us into a better direction. May these help.
re: Magnetic manipulation
Sorry you are not 'shielding'
The long pieces of steel redirect the flux from the faces at the arrow point to the other side rather than going more out the center of the point side
Get a sheet of magnetic line viewer and you will see
terry5732
That is the reason for 2 low carbon steel plates. The first one redirects and the second creates the shielding effect. That is the reason I call it magnetic field manipulation. These are old videos I did a couple of years ago. My camera had no sound, I just decided to share the videos to help with new ideas if possible.
Hi alan,
if you want 100% shielding superconductors is the only one, but they need a input of energy to keep them cool, I was the first one to come up with the idea of using superconductors as a rotating shutter system to control the magnetic flux to make a all magnet motor.
I dropped this one in the early 90s because of the need for cooling!
Regards Trevor
Regards Trevor
Greetings Trevor
I did these test a couple of years ago is or close to it. I have a design I may try later using the effect. I find your use of superconductors very interesting. But to make a magnet wheel to run with out input would say something. The other reason I keep it simple is due to gravity wheel studies dominate what I do in my hobby. Another way to look at it is to fully explore as much as possible before looking for answers in other places outside the set peramatures.
Talk to you later
Talk to you later
Hi Alan,
I thought this maybe of interest to you,
I believe that attracting magnets with percentage shielding and distance escape are the answer take a look at my magnetic motor on my web site! www.real-free-energy.co.uk
To get the feel for this design get two long strong magnets and try to make a T with them! You will see that one of the magnets will run from the weak point to the strong point, but when on a rotor as it is pulled to the strong point it is moving away from the other magnet (stator magnet) and all that is needed is a percentage shield covering the strong point! This is because at the time of one magnets escape the magnets behind it are being pull to the strong point to repeats the cycle.
The down side is that the large stator magnets are a custom build at about £2,000 each and that is why I have not built it yet, these large stator magnet would also make vast improvements to the V gate designs and any other weak point to strong point designs.
I will build it in time but I have to many gravity builds stacking up.
Regards Trevor
Edit, Attracting magnets do a lot of work before they hit the problem! a repelling magnet hits the problem before it does any work!
Regards Trevor
