I restored twice this thread (then visible again into the last posts list).
This is the second time where this whole thread has been deleted.
Nevertheless this thread is still stored in the system (go to 'albums', then on the left list 'path_finder', and click on the last picture at the end of the page, and click on the drawing in the post).
Is there any censoring now in this forum?
What is strange is this: when you make what is written above, the thread is restored but in the "general discussion' section only.
The function 'Posts from previous' don't work any more (display locked) if you change '1 day' by '5 days' p.e.)
The both threads are present (with the same title) and the second one (restored) is no more available for the next reconnection. It seems to be a data base problem related with the deleting of messages including some attached files (wich are not deleted and therefore allowing the restoration under some circumstances). Helpful for Scott?
This message should be in the 'Tech support' section now.
But there is no way at my disposal for moving it nor changing of section.
I apologize for the disturbance.
- path_finder
- path_finder
Dear scott,
Apparently you deleted the good one.
Nevertheless many thanks for your intervention.
The both are now restored. If necessary I will complete the good one (not this one, but the other located in the 'general discussion' section).
There is an improvement to do in your software (a delete of a thread don't suppresses also the eventual attached drawings causing a trouble in the data base)
