The Terawatt-Research-LLC 'momentum transfer' concept
path_finder
Post by path_finder »
The previous web site of Terawatt has been fenced. I have all former pages and videos in my archives.
Few years ago they built several prototypes based on rotating weights, transferring the momentum into a chain of cells where the energy was stored thanks to spiral springs.
The rotational energy is therefore transferred from cells to cells, and if the system is looped you can obtain an overunity (certified by TÃœV and UL).
The principle is explained here: http://peswiki.com/index.php/Directory: ... g_Symmetry
What is interesting in relation with the Bessler wheel is the use of the impulse from springs for the increase of the momentum.
I don't know why they seem to have abandoned the pure mechanical original concept, using now a new design including some magnets.
The patent is here: http://www.freeenergynews.com/Directory ... 311_a1.pdf
The question is: did Bessler use a similar concept by transmitting the momentum 'pilar after pilar' between his weights subsets ?
path_finder
re: The Terawatt-Research-LLC 'momentum transfer' concept
just two shots from a video published earlier in the previous web site.
Bill_Mothershead
Post by Bill_Mothershead »
You Peswiki link had a link:
http://pesn.com/2010/07/14/9501672_Tera ... ereotypes/
..which has a picture of a motor/generator combo with
magnet coupling somehow...
which reminded me of a new link on peswiki
http://www.besslerwheel.com/forum/posti ... ply&t=4268
which is about "magnetic cogging" which is in my mind best described
as just a gear but instead of metal teeth grinding on each other,
they use magnets (nothing touches).
It escapes me on how this is overunity...but there is a 9 min
video (some of it is just a slide show, but some of it is live action).
Somebody went to a lot of trouble + expense to build this
very smooth looking equipment.
Like I said. I have NO clue how this could be overunity.
